Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#1 |
car 323i 99 AT 253K+ miles.
So, after coming home form work yesterday I deiced to tackle low+high+fog lights coding with ncs expert changed in GM Code:
FH_ABSCHALTKRITERIUM ece Code:
PROGRAMMPARAMETER_LSZ_1 ece PROGRAMMPARAMETER_LSZ_2 ece PROGRAMMPARAMETER_LSZ_3 ece PROGRAMMPARAMETER_LSZ_4 ece PROGRAMMPARAMETER_LSZ_5 ece PROGRAMMPARAMETER_LSZ_6 ece PROGRAMMPARAMETER_LSZ_7 ece PROGRAMMPARAMETER_LSZ_8 ece PROGRAMMPARAMETER_LSZ_9 ece PROGRAMMPARAMETER_LSZ_10 ece PROGRAMMPARAMETER_LSZ_11 ece PROGRAMMPARAMETER_LSZ_12 ece us PROGRAMMPARAMETER_LSZ_13 ece us So today i move the car to start work on fixing the sunroof (shade clips ordered) moved car to better location and notice transmission error and CEL get code with inpa and 146 CAN Moment interface and 8 Signal air flow meter, DIS only showing .3v from MAF put 1v on the MAF harness and inpa responded as did the car (near stall) at this point looks like the MAF is dead. So has anybody ever run into and issue like this after coding I doubt it's related but the timing seems suspicious, I did recode car to a old config had no effect and info from navcoder shows Code:
2/3/2012 12:04:24 PM.078: 80 09 BF 13 10 01 00 00 00 00 34 2/3/2012 12:04:24 PM.078: IKE --> GLO : IKE sensor status: Trans_Emergency_Program Motor_Running Last edited by mo5; 02-03-2012 at 10:40 PM. Reason: typo |
#2 |
My Ride: 2001 3 Pedal M54b30
I once was messing with INPA on my parents 330i and after i closed the program, it came out with a random check light as well. I just cleared it and it never came back. Maybe that is the issue? Other than that i've messed with NCS expert on my car many times and i've never had an issue like that.
However as far as the coding goes, your lcm is too old to code teh highs + lows + fogs. I had the same issue on my 01 until i upgraded the LCM to a newer one. |
#3 |
The above LCM setting worked I have working high+low+fog, it just disabled the running/ID lights to only function as directional (euro) and for SIDEMARKER_US to work I would need a 02+ LCM; the MAF is on the way, I assume everything will be fix once replaced, I was just curious about the coincidence.
#4 |
Replaced MAF, car is running fine.
| Tags |
| cel, errors, lsz, ncs expert, transmission indicator |
