The Showroom
Old 02-08-2012, 09:31 AM   #41
francogt1
My Ride: E30 M3
Send a message via AIM to francogt1
take me for a ride ill sit on your lap
_DSC7278sig
francogt1 is offline   Reply With Quote
Old 02-08-2012, 05:04 PM   #42
awm3trantg
My Ride: Individual M3
Originally Posted by WhatsBFc View Post
Minimum size for an adapter is 15mm. And the varrsToens come highest offset of +30
So if I wanted a set of 9.5fronts and 11" rears bbs lm reps
And got 15mm adapters
I would need the offsets to be at at least et30?
So hypothetically 9.5 et35 with adapter will be 9.5et20
11 et35 with adapter will be 11 et20
Aren't Porsche offsets in the range of high 30s-high 50s?
I really want a set for my p car
Please can u let me know my options
awm3trantg is offline   Reply With Quote
Old 02-08-2012, 05:19 PM   #43
HIGHcard
My Ride: honda civic
Thanks gents!
-My C4S is speed yellow under the vinyl
-The area around the exhaust tips weren't wrapped because they're metal heat shields
-The LM's are in the US somewhere on a 996 RSR
-You can run 8.5+32F, 11+25R on a WB 996..The 2.2.2's are 9.5+30, 10.5+22 with 15mm ADAPTEC Speedware adapters all around..You can shave some mm's off the back pad if you really want a higher offset..
HIGHcard is offline   Reply With Quote
Old 02-10-2012, 10:19 AM   #44
awm3trantg
I see.. i wonder if this same concept would work for mine, i have CS not a 911 WB. so im assuming mine is a little narrower than yours my friend...
im hoping to stay with in the 20-30mm range for the fronts at 8.5-9.5 width and as for the rears, i think the lowest offset i could go is in the 20s with the width of 10.5-11" wide wheel
any more advice would greatly be appreciated
thank you
Old 02-10-2012, 02:59 PM   #45
SW222
Banned User
My Ride: is silver and slow.
Originally Posted by francogt1 View Post
take me for a ride ill sit on your cawk
SW222 is offline   Reply With Quote
Old 02-11-2012, 11:20 AM   #46
Dan99
My Ride: 2001 330xi
i will one day own a Porsche
Dan99 is offline   Reply With Quote
Old 06-28-2012, 12:53 PM   #47
adonis_bimmer
My Ride: HartgeSL4G!
Send a message via AIM to adonis_bimmer Send a message via MSN to adonis_bimmer
cant see pictures!!!!
adonis_bimmer is offline   Reply With Quote
