Go Back   E46Fanatics > Everything Else > The Off-Topic > Photography
Photography
Closed Thread
Old 06-09-2003, 10:36 AM   #1
MrBull
My Ride: 2000 328i
OT: Processing Photos for Web Display
Seeing that many post photos up on this site, I thought I'd throw a few of my tricks out there that can help fellow E46fanatics & their digital pics. Also, being a photographer, I've tried just about every method & here are the ones I think work best:
(Assuming you're using Photoshop)
Dark photos may contain a good picture Try using the LEVELS command (Image/Adjust/Levels). The window will show a histogram with three triangle sliders. Slide the left triangle to the right, where the first "mountain" of the histogram begins. Do the same with the right triangle, by sliding it to the left. Sliding the center triangle to the left will make your photo brighter, to the right will make your photo darker. I wouldn't move this center triangle too much though - just concentrate on the outer two.
Photoshop Actions can save a ton of time For some time now I've been using actions created by Fred Miranda. I've owned programs that cost hundreds of dollars and they show no noticeable improvement over what Fred's actions can do. And his are priced around $10. While you can purchase actions specifically for your camera model (mine is a D60), you can also check out his Generic ones)Fred Miranda Essential Darkroom Actions
I am in no way associated with Fred's site, just thought I'd pass along a bit of info that many photographers use. Go check his site out - some of the stuff he has is pretty amazing for under $15. The Shadow Recovery action is quite simply, amazing!
2000 328i Steel Gray Sedan Marriage+Child=No More Convertible
Current Mods: 18" GT3 w/Satin Finish * 235/40 Bridgestone Potenza S-03 * Hamann Eyelids * GenV DDE * Clears * Carbon Fiber Roundels * Chrome Gauge Rings * Keyhole Covers * iPod Install inside armrest * Painted headlight trim
| 2004 Planned Mods | Interior trim * Delphi XM installed in headliner * Stealthbox * AC Schnitzer Aero kit (possibly)
MrBull is offline
Old 06-09-2003, 10:40 AM   #2
Clem
Alpha Male
Clem's Avatar
My Ride: Twin Turbo'd Beast
Great info!!!!
Clem is offline
Closed Thread
