south bend clutches - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-05-2012, 09:16 PM   #1
thatmexican32
My Ride: 99 323i
south bend clutches
okay so i know im going to be told to do research but i did some and i couldnt find much.i want to know if anyone is using a south bend clutch and if so, how do you guys like it? what other clutches are any of you guys using that have lasted? my 323i's clutch is slipping bad now.
thatmexican32 is offline   Reply With Quote
Old 02-06-2012, 12:20 AM   #2
jacobs323i
My Ride: blown 323i
i have a stage 3 segmented kevlar from clutch masters with a lightweight flywheel with less then 6000 miles on it held power great and had like oem pedal feel. I upgraded to a m3 tranny so i have it for sale for cheap! pm me if ya want it.
jacobs323i is offline   Reply With Quote
Old 02-06-2012, 07:55 AM   #3
TxZHP04
My Ride: ESS TS2+ ZHP
A new OEM clutch should last you well over 100k miles. Unless you have a real need (ie, you have a heavily modified motor), a stock clutch and flywheel are your best bet.
Old 02-07-2012, 01:14 PM   #4
tinkwithanr
My Ride: '00 323i + '75 2002
Is that the same one you sold over the summer?
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
