General Off-Topic
Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average.
Old 12-01-2012, 06:53 PM   #381
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
The lighter that comes with the Herfador deal is garbage
I'm having trouble maintaining humidity in my humidor, and I think it's because the air is so dry in my apartment. I have ~15 cigars, the humidifying puck, a humicare pillow, and a shot glass of water and it still hovers ~60%. Any ideas?
Old 12-01-2012, 07:39 PM   #382
mando3
My Ride: 3 series
is your hydrometer calibrated correctly?(with the salt test or any other method), did you take your time to breake in the humidor? you can try a shot glass with destilled water in addition to the humidifying pack to temporary raise the humidity, then remove it when it reaches the desired point, that sounds like it might help but honestly I've never tried that before
Edit: are you talking about the plastic humidor in the deal?
mando3 is offline   Reply With Quote
Old 12-01-2012, 10:59 PM   #383
MB469
My Ride: Nothing cool
Try an electric hydrometer, those are accurate and inexpensive. I had an issue like yours with my smaller humidor, just would not go above 62 when fall season started. I finally gave up and upgraded to a larger humidor with electric device, problem solved, I didn't want my "special" cigars drying out. But like the other poster mentioned, get another hydrometer to see if the analog one is even accurate, I never trust those ones. Also, as stated above, make sure the humidor is seasoned first.
MB469 is offline   Reply With Quote
Old 12-02-2012, 10:17 AM   #384
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
I tested it with another analog and a digital one and they were all within a few % of each other so I know it's fairly accurate. It would stay around 70-72% before the air got dryer a couple weeks ago
Old 12-02-2012, 10:49 AM   #385
vamusclebuilder
My Ride: 93' 325iS & 00 323i
Drew Estate Java this morning with my coffee. VERY easy draw, light taste and kind of refreshing with my cup of coffee.
vamusclebuilder is offline   Reply With Quote
Old 12-02-2012, 12:33 PM   #386
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
*NWS GIF REMOVED*
*GIF REMOVED*
**You make me so horny.- Tim330i **
Old 12-02-2012, 12:47 PM   #387
budman
-not a mod-
budman's Avatar
My Ride: ..
Gurkha Special Edition Spec Ops
Sent from my damn phone
-Gunnar
budman is offline   Reply With Quote
Old 12-02-2012, 02:55 PM   #388
scott087
My Ride: 03 330xi
Check the seal on the humidor too.. If it isn't a glass top, put a bright flashlight inside when it's dark in the room - - you can check for leaks by seeing if you can see the light seeping out anywhere. Also, I've wiped down the edges of one of my humidors where it seals with a rag lightly dampened wih distilled water. This slightly swells the wood that makes the seal and can tighten up the seal and hold the humidity in.
Also.. I'd agree that the lighter that comes with the Herfador deal sucks. It's extremely cheap in look and feel, but it seems to work well. Still and awesome deal regardless.
scott087 is offline   Reply With Quote
Old 12-02-2012, 03:44 PM   #389
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
From cigar.com
"Fluctuating humidity levels commonly occur throughout all humidors; it doesn't matter what shape, size, or brand of humidor you own, you will always have small fluctuations in humidity on a week by week basis. The biggest fluctuations occur when the seasons change, which is why it is incredibly important to "season" your humidor four times each year as the weather changes, especially when winter arrives. Why is this so important during winter? When the outside temperature drops and becomes very cold, the amount of water the air can hold drastically decreases. When this cold air enters your home and warms up, it can now hold more water, which drops the relative humidity inside your house, thus directly affecting your humidor's humidity levels by causing them to drop as well. Since the warmer air can now hold more water, your humidor will need "seasoned" again to reintroduce more moisture to your cigars and in turn, restore your humidor's humidity level to the proper 70%. When re-seasoning your humidor, don't be afraid to add additional humidification elements."
I had always heard of seasoning a humidor as introducing moisture into the wood when you first get it. It makes total sense, but it never dawned on me just why it was called seasoning
Old 12-03-2012, 04:15 PM   #390
evolved
My Ride: 2011 BMW 335d
I'm completely naive when it comes to cigars, so I'm asking for some help.
I'm wanting to spend a max of $60 on some cigars for my brother-in-law for Christmas....any suggestions on good samplers? I was cruising around www.cigar.com since some of you have referenced it in this thread.
Is something like this any good?
http://www.cigar.com/cigars/viewciga...catid=samp_var
Edit: If I could find one that includes a little humidor or herfador, that would be ideal.
Present
2014 Jeep Cherokee Trailhawk V6
Past
2011 BMW 335d, 2011 BMW 135i, 2006 Mazdaspeed 6 GT, 2000 BMW 323ci, 2003 Evolution VIII, 1995 Nissan 240sx w/ SR20DET
evolved is offline   Reply With Quote
Old 12-03-2012, 04:20 PM   #391
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
http://www.cigarsinternational.com/p...ASST02&cat=215
humidor deal
http://www.cigarsinternational.com/p...p?item=sp-ca42
http://www.cigar.com/cigars/viewcigar.asp?brand=1440
*NWS GIF REMOVED*
*GIF REMOVED*
Old 12-03-2012, 05:29 PM   #392
mando3
My Ride: 3 series
Hey Griffin, I've seen the last deal from cigar.com a few times but everytime I go into it, its always showing the full retail price, do you need an additional code or something?
Old 12-03-2012, 05:32 PM   #393
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
it looksl ike that one expired. They are normally only good for a a day or two.
*NWS GIF REMOVED*
*GIF REMOVED*
Old 12-03-2012, 05:53 PM   #394
mando3
My Ride: 3 series
cool, I don't even know what I want another humidor for, one of those deals that seems so good to pass hehehehe
Old 12-03-2012, 08:14 PM   #395
budman
-not a mod-
budman's Avatar
My Ride: ..
I just picked up a new humidor.. in the process of seasoning it.
-Gunnar
Old 12-04-2012, 02:43 PM   #396
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
never had one of these travel herf-a-dor before. I noticed there is a a spot humidifer part in the top of the case. do you add distilled water it? What is the trick to use it?
*NWS GIF REMOVED*
*GIF REMOVED*
Old 12-04-2012, 02:46 PM   #397
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
I'm guessing that's what you do. It's the same material that comes with regular humidifiers, that dense green foam that florists use. I'm assuming you saturate it and you're good to go.
Old 12-04-2012, 02:49 PM   #398
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
i read on a couple of forums to not use the one in the roof. It can over humidify. that if you put some sticks in they will be good for about 4 days. anything longer to use a pillow.
*NWS GIF REMOVED*
*GIF REMOVED*
Old 12-04-2012, 02:57 PM   #399
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Hmmm I'll have to read up then.
Old 12-04-2012, 04:35 PM   #400
mando3
My Ride: 3 series
CAO italia, enjoying the nice weather watching top gear and having coffee
Rate This Thread
