Old 02-06-2012, 11:37 AM   #1
whyzee125
My Ride: 330ci with 3 pedals.
Is this noise normal? Video inside. 330ci drivetrain noise
I've had my car about a year now, and it's always made this humming noise in first gear, but it was bothering me more than usual the other night, so I thought I'd take a video of it and see if it's normal. A few friends of mine that have e36's say it's totally normal, but their cars don't do this and really I can't think of another car I've driven that sounds like this. It's not real loud, and it's only noticeable in first gear, but kind of sounds like a dry transmission or something. Fluid is fine, but it's never been changed so I plan on doing that soon. Any other ideas on what this noise could be? Listen closely, it does it mostly between 1500-1700 rpms. Here's the video Thanks guys!
948whp on the butt dyno.
whyzee125 is offline   Reply With Quote
Old 02-06-2012, 11:40 AM   #2
Stinger9
My Ride: '04 330Ci
I'm not getting the noise from the vid.
Can you describe it in more detail?
Originally Posted by whyzee125 View Post
I've had my car about a year now, and it's always made this humming noise in first gear, but it was bothering me more than usual the other night, so I thought I'd take a video of it and see if it's normal. A few friends of mine that have e36's say it's totally normal, but their cars don't do this and really I can't think of another car I've driven that sounds like this. It's not real loud, and it's only noticeable in first gear, but kind of sounds like a dry transmission or something. Fluid is fine, but it's never been changed so I plan on doing that soon. Any other ideas on what this noise could be? Listen closely, it does it mostly between 1500-1700 rpms. Thanks guys!
Old 02-06-2012, 11:40 AM   #3
jasonbimmer
My Ride: 2001 BMW 330xi
is it happening when you let off gas in 1st gear?
like a whirring sound?
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 02-06-2012, 11:47 AM   #4
whyzee125
Yes, kind of a whirring/humming sound. it happens a little when I let off, but actually more when I'm accelerating. turn the volume all the way up, it's a little hard to hear in the video.
Old 02-06-2012, 12:44 PM   #5
Phoenix330ci
My Ride: 04 330Ci Convertible
Yeah can here the noise but it looks like you have other issues there more pressing, like you need fuel, looks like some bulbs are out and you're low on windshield washer fluid.....................hahaha!
Phoenix330ci is offline   Reply With Quote
Old 02-06-2012, 12:49 PM   #6
afstud
My Ride: 02 & 04 325xi sports
in my Xtype jag, this noise was the center drive shaft support bearing, it was annoying, but not too bad to replace. also your one HID that is working is pointing straight at the ground.. haha
afstud is offline   Reply With Quote
Old 02-06-2012, 12:57 PM   #7
Custom3
My Ride: HellRot 330CI
tire noise? throw the spare tire on the front and see if the noise changes....if it does then its tire noise your hearing. I had the same problem when I first got my car.
Old 02-06-2012, 09:43 PM   #8
whyzee125
It very well could be a driveshaft bearing issue. I'll check that out! Thanks. I don't think it's tires, because its only noticeable in first gear, but I will have new tires in the next few days, so I should be able to tell. I filled up on gas today, so that's one issue outta the way. lol thanks for the help!
diff, transmission, whining, whirring noise
