Old 02-06-2012, 09:22 PM   #1
cyberlando
My Ride: 2002 M3
Post m3 subframe LSD
is there a differemce with buyin a m3 subframe and lsd from a 2005 m3 vs a 2001 m3.....i have a guy selling it to me for a pretty decent price but the 01 is a little lower...is there any recalls or anything i should keep in mind
it a 3.62 ls m3 diff with axels subframe
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
cyberlando is offline   Reply With Quote
Old 02-06-2012, 09:23 PM   #2
cyberlando
My Ride: 2002 M3
ive been lookin all day but is there any thread that someone has a DIY on the swap for a 330 trying to see how much moddin if any is needed?
Engine:
Interior:
Old 02-06-2012, 09:57 PM   #3
Levim9
My Ride: S54 325i & LSB M3
I don't think there's a difference between the 01 and 05 rear end. Maybe the price difference is because of mileage and just because ones older.
Does your car have a manual transmission? If so, 5 or 6 speed? 5 speed will require a custom driveshaft (shortened), 6 speed will require the use of an M3 driveshaft. I don't know what driveshaft is used for auto or SMG transmissions.
Levim9 is offline   Reply With Quote
Old 02-06-2012, 10:18 PM   #4
cyberlando
My Ride: 2002 M3
i got a 5 speed 330ci the guy said he's gonna send me the whole entire kit control arms m3 shaft calipers and everything for 1400, but the question i have is that if the m3 drive shaft will fit my transmission since i have a 5 speed or will i need to adjest something?
Engine:
Interior:
Old 02-06-2012, 11:46 PM   #5
Levim9
You'll need to have your 5 speed drive shaft shortened.
This guy has a 5 speed 330 and did the M3 rear swap - http://forum.e46fanatics.com/showthr...r+end+swap+lsd
330 swap, differential, lsd
