Old 03-05-2017, 12:10 AM   #1
Aventador_nb
My Ride: E46 323i
Fuel Pump Change on E46
Hi guys! So I changed my fuel pump today, it was my first time doing it. There's not many helpful videos online. It's one of the easiest things I've done so far on the E46. However, I have a couple of tips.
First, the gasket on the pump is very important and kinda tricky to put on. If you'll leave it on the pump, it's hard to install. Thread the gasket onto the inner tank gasket before you install the pump. It makes life so much easier.
Second, do the job with a low fuel level. I did it with less than 1/4 of a tank. It seems like a common sense thing but with the tank full, it's really hard to work in there.
When I put my pump on the first time, when I slid the pump in, the gasket had moved out of place. I went to fill my tank to the top. My tank started leaking at the gas station, pretty heavily. I got home, only about 1.5 miles away. I took everything apart and realized my gasket mistake. It was quite scary to see all of that gasoline dripping though. Hopefully this helps someone who wants to do it for the first time
Sent from my SAMSUNG-SM-G920A using E46Fanatics mobile app
"If everything seems under control, you're not going fast enough." -- Mario Andretti
Aventador_nb is offline   Reply With Quote
Old 03-05-2017, 12:12 AM   #2
Aventador_nb
My Ride: E46 323i
Do you guys have any clue what this is for? It was under my seat, unhooked.
Old 03-05-2017, 12:15 AM   #3
Aventador_nb
My Ride: E46 323i
For the second time when I was putting the gasket on, I used one of these cable attachments to shut the fuel line. The fuel line was squirting heavily because the tank was full. It fit perfectly.
Old 03-05-2017, 06:40 AM   #4
allikanbe
My Ride: 2013 335is vert
That wire is for shipping the car. It's not used after delivery. You can find out more info if you do a search on this forum. It's been asked before.
There are a few DIYs on changing the fuel filter. http://www.pelicanparts.com/BMW/tech...eplacement.htm
Fitting the gasket correctly is mentioned in probably all the DIYs.
You had me worried about the cable splitter until I read the caption. :-)
Good job on replacing the pump. Did you replace the filter also?
allikanbe is offline   Reply With Quote
Old 03-05-2017, 03:59 PM   #5
Aventador_nb
My Ride: E46 323i
I haven't changed the filter yet. I'll do that soon. Or should I take it to a shop? I don't have a lift to get under the car, apart from a simple $40 jack.
Old 03-05-2017, 06:55 PM   #6
allikanbe
I bought my filter online and took it to a local Western Auto to have it installed. i didn't feel like laying on my back under the car with gas splashing out. It was worth the $40 to have someone else do it using a lift.
Old 03-05-2017, 09:03 PM   #7
Aventador_nb
My Ride: E46 323i
That's what I was thinking
