Old 02-07-2012, 05:10 PM   #1
mack89
My Ride: '02 TIAG 330i 5spd
Symptoms of Neutral Safety Switch/Position Switch Failure?
Hey all,
My car's been having a good rest in my garage ever since the transmission failsafe kicked in. Check this thread for more info
http://forum.e46fanatics.com/showthr...1#post14050950
Anyway, last night I tried to drop the car at the local BMW indy shop despite the fact that gear's stuck at 5th, but I wasn't able to start the car. One click, that's it. Just like the symptom of dead starter. (Starter's been replaced few weeks ago)
Interesting thing is that when you wanna shift the gear from P to R/N/D without starting the engine, you need to put your key on acc2 position and depress the brake pedal, right? But this guy just moves freely. I don't even have to depress the brake pedal. Wtf.
My technician thinks that it's not mechanical problem, and judging by this new symptom, I'm suspecting that neutral safety switch(position switch) has failed, presumably caused all these issues. Does anybody know the symptoms of failing that part? Part# is 24107507818, #9 on this pic
Please let me know!
Thanks a zillion
mack89 is offline   Reply With Quote
Old 02-07-2012, 10:08 PM   #2
mack89
anyone?
Old 02-08-2012, 02:00 AM   #3
BMWUSMC3051
My Ride: 2000 BMW 323i
Lol my friend I have the same problem even BMW was lost when I told them what was wrong good luck if u get anything anything please let me know I posted almost the same ? Like 2-3 months ago good luck. One thing I can say is pending on the year of the car it could just b a software update at least that's what BMW said also u could jus by the sensor like 180$ drain tranny fluid remove pan n filter n replace it the reverse putting it together that's probably what I'll do its next to the bell housing accessible
BMWUSMC3051 is offline   Reply With Quote
Old 10-17-2012, 11:19 AM   #4
bargainfinder
My Ride: 2002 BMW 318i Step
Have you ever managed to find a solution to this problem. My 2002 318i Step Facelift is doing exactly the same thing.
bargainfinder is offline   Reply With Quote
