Oil level sensor diagnoses - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-08-2012, 11:53 AM   #1
duckloads
My Ride: 2001 325i
Does anyone know how to diagnose the oil level sensor. I get the red oil light on and off until the engine is warmed up. Oil level is fine.
Is there a place on the engine to put a pressure gauge to actually see the oil pressure?
2001 325i
duckloads is offline   Reply With Quote
Old 02-08-2012, 11:58 AM   #2
snazir786
My Ride: 2000 323i
I have the same problem...I called the BMW dealer and he said its you're oil level sensor that needs to be replace..and i belive he said its under the oil pan, but i never checked.. lol being lazy...
snazir786 is offline   Reply With Quote
Old 02-08-2012, 12:05 PM   #3
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
It would be yellow if if was your level sensor, you are talking about the oil pressure sensor on the back of the oil filter housing.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 02-08-2012, 12:10 PM   #4
engtariq
My Ride: 2001 325i
It would be a yellow light for oil sign at your dash board and it will get on after you turn your car on and it will show for 20 sec then it will disappear.
It is located next to your oil drain plug.
I changed mine two weeks ago do to the same yellow light and it was an easy DIY.
The part is $25 from online and you have to do an oil change because you have to drain the old oil.
engtariq is offline   Reply With Quote
Old 02-08-2012, 12:17 PM   #5
forzam
My Ride: 04 325Ci
Where did you get it for $25? I take it that is not Hella (OEM)?
forzam is offline   Reply With Quote
Old 02-08-2012, 12:29 PM   #6
engtariq
My Ride: 2001 325i
It is an aftermarket sensor and here is the link:
http://item.mobileweb.ebay.com/viewi...d=150730104754
Old 02-08-2012, 12:45 PM   #7
nk_zhp
My Ride: ZHP / E30 M3
You can check the pressure by using the same spot where the pressure switch is located. Which is on the oil filter housing.
'04 330i ZHP - OEM Clears - ///M Strut bar - CoolantSnitch
nk_zhp is offline   Reply With Quote
Old 02-08-2012, 04:13 PM   #8
duckloads
My Ride: 2001 325i
Thank you all so much. Replacing the pressure switch solved the problem.
Old 02-08-2012, 07:24 PM   #9
Hrvat
My Ride: 02 Imola Red M3
From what I read, when it comes to oil level sensor OEM should be used. I guess aftermarket ones don't always fit well and can leak oil
PM ME FOR FREE SAMPLES
Originally Posted by roronoah View Post
so 2004 bmw's dont come with a diff?
Hrvat is offline   Reply With Quote
Old 02-08-2012, 07:43 PM   #10
jdstrickland
My Ride: '94 325iC & '00 323i
YELLOW oil light = level or level sensor.
RED oil light = oil pressure or oil pressure sensor.
Old 02-08-2012, 07:54 PM   #11
engtariq
My Ride: 2001 325i
This level sensor I got was in great quality, fit perfectly and with no leaks.
