Old 02-07-2012, 10:01 PM   #1
jeagolf
My Ride: 04 330Ci Vert
Different E46 Daten Files Question
What are the major differences between the DATEN files for E46 found in V39 verses V44?
Looking through software there is V39, V40, and V41. I don't think V43 and V44 has any E46 files.
Do you need to use different winkFP, progman, DIS depending on which DATEN files you have?
Thanks,
Jim
jeagolf is offline   Reply With Quote
Old 02-08-2012, 08:37 AM   #2
jared_wiesner
My Ride: 1999 328i (M54b30)
As far as I am aware, the only difference between daten file versions is that they are updated lists of software. So, higher number daten files contain newer model software and revisions of software not in previous versions.
I think you are correct in saying that by V41 there were no longer any revisions to E46 software. Those daten versions can be used just the same in winkfp, etc. (They are identical to the revisions found in later daten files)
jared_wiesner is offline   Reply With Quote
