Sponsored by The Tire Rack
Old 02-09-2012, 04:06 AM   #1
CSL323
My Ride: 330Ci
Exclamation 245/40/18 fits OEM style 135?
Hi guys, my rear tires are both needing replacement. I have OEM Twin-Spoke 135s (below)
I'm ready to buy at a set of Kumho KU31's however I really want to go a little larger on the rear. I'm looking at a set sized at 245/40/18.
I want to avoid a lip around my rim. I've never been a fan, really. I'd like it to be flush...
Below are photos of my brother's 323i.
Here is one with the rear tires on 225s...
And this is the upgrade to 255s...
See that lip?
What size should I look at to avoid that?
Thanks.
CSL323 is offline   Reply With Quote
Old 02-09-2012, 04:07 AM   #2
CSL323
My Ride: 330Ci
Deleted a useless post
Old 02-09-2012, 10:43 AM   #3
crazyxzer0
My Ride: 2004 330i
Send a message via AIM to crazyxzer0 Send a message via MSN to crazyxzer0
The tire will have a taller diameter by 0.7 inch. Of course it will fit the rear 8.5 rim. It's not the right size but it will bead on the rim if thats what you are asking.
-Derek
Stoptech Front BBK|M3 LSD|GC Coilovers w/ Swift Springs|UUC TSE3 Exhaust|
My Build Thread
crazyxzer0 is offline   Reply With Quote
Old 02-09-2012, 03:56 PM   #4
CSL323
My Ride: 330Ci
Deleted my useless post...
Old 02-11-2012, 06:16 AM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Wish I could help, but I don't have a clue!
Bump! HTH!
Upcoming comedy shows: April 23, Tierney's Tavern, Montclair, NJ, 7:00 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 02-11-2012, 08:18 AM   #6
CSL323
My Ride: 330Ci
Bump! HTH!
Hey, thanks anyway buddy!
I hope someone can clear this up for me.
See you 'round!
Old 02-24-2012, 10:25 AM   #7
CSL323
My Ride: 330Ci
Alrightie so! I went and picked up my wheels (building a website for progress pics on my car rebuild)...
ANYWAY, I've got 225/40/18 on the front, 255/35/18 on the rear while flush. I might just go 265.
Old 02-24-2012, 03:22 PM   #8
AMAZIN-
My Ride: ///M
Are your four rims all the same size?? Or can you go 255/35/18 even though the front has the same rim size?
AMAZIN- is offline   Reply With Quote
Old 02-24-2012, 09:15 PM   #9
CSL323
My Ride: 330Ci
Apparently not, mate...
I have reason to believe my rears are 9 wide... So they must be staggered!
I figure because my brothers car (above) had that major lip around the rim when he put 255s on (his rims were 8.5 all around) . My car is flush with 255s..
I'll have a definite answer in just a little bit.
I'm not sure why I have to get 35s and not 40s on the rear. I didn't think it'd make a serious difference but apparently it's got to do with balancing the front from the back.
Old 02-25-2012, 11:33 PM   #10
leeshope
My Ride: 04 330i zhp
if those are oem 135s, they should staggered.8 up front and 8.5 rear. that is how mine are anyway.good luck!
leeshope is offline   Reply With Quote
Old 02-26-2012, 06:40 AM   #11
CSL323
My Ride: 330Ci
Ah fantastic! Thanks for that man, they are OEM.
I have had no professional word about the sizing, nor have I measured, it was more of a guess...
Thanks for confirming it though!
Old 02-27-2012, 07:35 PM   #12
SpoiledBrat
My Ride: 330Ci zhp
Are these the 8" 135m's? 245/40 will have a lip as you call it. I have 235/40's on my fronts and they have a small lip, but not even enough to avoid curb rash. 225's are oe, but have the most slightly stretched look. As for the rears, 255/35 is stock and won't have any lip. Hopefully I didn't mix up any of the profile %'s. Too many numbers.
SpoiledBrat is offline   Reply With Quote
Old 02-27-2012, 10:11 PM   #13
Blocked Out
My Ride: Imola 330i M-Sport
The rear should have 225/35/18 or 245/35/18 on the 8.5" rim. 245/40/18 will be too tall.
The "lip" is not a size type thing, its a brand thing. Some tires have the "lip" some dont, some have a round sidewall some have a square sidewall. You should get the CORRECT tire size for your rim width.
In your case its 225/40/18 on the front which is 8" wide and 255/35/18 (245/35/18 very hand to find and more expensive then 255/35) on the rear 8.5"
Original BMW Teile ///
IMG_1725
Old 02-28-2012, 12:52 AM   #14
CSL323
My Ride: 330Ci
So should I go for 255/35/18 on my rear again?
That's what's already on the rim, but I need to replace both NOW.
Old 02-28-2012, 09:07 PM   #15
Blocked Out
Yes.
IMG_1725
Old 02-28-2012, 09:12 PM   #16
mq124
My Ride: slow and sorta low
different tires sit on the bead of the rim a little differently so its not just the tire size that causes that lip over the rim that you see, that has a lot to do with the tire build itself (of course it will be more dramatic with bigger sizes). Possibly look for pics of the actual tires you want to see how they seat on the rim?
mq124 is offline   Reply With Quote
Old 02-28-2012, 09:52 PM   #17
TerraPhantm
My Ride: M3 & ZHP
+1; my 275/35 bridgestones sit almost perfectly with my 18x10 rears, but my current pilot super sports of the same size look ever so slightly stretched.
Old 02-29-2012, 12:17 AM   #18
CSL323
My Ride: 330Ci
Purchased Kumho 255/35/18. Thanks
