1999 E46 318i SE - spent some serious money - need some advice (diff/headgasket) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-09-2012, 10:12 AM   #1
NathanLEvans
My Ride: 1999 E46 318i SE
Hi guys, Uk owner hear - hoping I could get some advice from your vast collective experience...
Ok - so about two a half years ago I bought my beamer... cost me 2500 with the 18" alloys. Since then I've spent around 2095 keeping it alive. Im ok with this - 240 for tyres, 600 for pads, discs, shoes, brake pipes etc. and annoyingly far too much trying to get the heater to work/pipes to stop leaking.
Right - that 2095 also includes my most recent payout to date - a rear diff change. Car packed up on the road and I got a second hand diff installed for 685... [PROBLEM 1]
Promblem 1 = The loss of fifth gear. The guys at my garage said I'd loose some top end speed and gain some acc, they didn't tell me it would be like driving at 70 in 4th gear with revs at 5 and a half thousand. I had it in mind to go back to them the following day when I broke down again... [PROBLEM 2]
Problem 2 = Engine overheating in the snow, lots of steam coming from coolant pipe and figured I had a serious leak.. filled it up with water which got me home and took it to the garage... just had a call saying they've fixed the problem - another 120 for the pipe and labour mind (other garage put sealant around it instead) but they came back to me with the final nail.. [PROBLEM 3]
If you're still reading this far down I really appreciate it -
[tl;dr]:
1 - Replaced diff but I'm not happy with diff ratio
2 - Replaced leaking rad/coolant pipe
3 - Called with third problem ....
*blown head gasket*
- They said the leak had been there for a while getting worse. I do a lot of miles in that car and I'd rang up to moan about the diff when infact they were telling me to cut my losses on the car. They were saying it's not worth spending up to a K replacing the headgasket and he said all he can do now is put some sort of sealant on it to keep it going whilst I figure out what to do.
- He's a nice guy and I dont think he's ripping me off as far as garages go - but I have spent A LOT on this car. I don't want to jack it in, but at the same time I can't afford another K on fixing the cylinder head -- and I want my diff sorted and if the garage is adament I should jack it in, they're not going to do much about it right now.
- E46fanatics, I've written a lot and I may be asking a lot, but if anyone out there could give me some helpful information on what to do next it would be so much appreciated. Info like:
- Is runnning with this diff at 6000rmp at 80 bad for the engine
- Is there anyone from the lower part of the UK here who can replace a cylinder head for me at a fraction of the cost a garage would ask
- Can I do anything myself to lower the cost (a lot of the cost I believe would be labour though).
Im sure you can appreciate how attached one gets to his vehicle and this one has been through a lot with me. If I can keep her up and running for just another year or so until I can afford say an M3 I'd be a happy man
From other feedback, it seems i was overcharged for the diff - heres the breakdown: The second hand diff was 350, postage to the garage was 35, work was 180 + 7 for coolant which i subsequently lost. This makes 572 before VAT and 686 after VAT :/
Many thanks in advance guys
Nathan.
NathanLEvans is offline   Reply With Quote
Old 02-09-2012, 11:47 AM   #2
lcoleman
My Ride: '79 Massey Ferguson
Running at 6K all day should be fine, though it will accelerate wear. I would NOT do it.
Your post is unclear, is 5th gear not working, or is the diff ratio just that short?
The head gasket situation sucks pretty bad. You probably did that when you filled with water and kept driving, as it likely overheated enough to warp the head and/or block. You'll basically have to pull the entire motor, have both parts decked, and reinstall. A lot of people swap in a known good engine, but that's even more expensive and not much less work.
I'm not sure what $1K BP works out to in USD, but that doesn't sound like a bad price from what I've seen quoted on this forum.
Old 02-09-2012, 04:24 PM   #3
dferdog
My Ride: 318iSE
1K to get the head gasket done..... ouch! might be cheaper to get another lump off fleabay
1k gbp is about $1600
dferdog is offline   Reply With Quote
Old 02-09-2012, 05:04 PM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If it is head gasket...not arguing, OP, but do you know how he knows? What tests he did?
Guys have done the head gasket themselves, but if the head needs to be shaved, and it probably should be checked, I believe it needs to be emptied out...you could get much of it done, but leave the timing to a pro...if you have one of those around.
Are you seeing oil in coolant or coolant in oil?
You have sputtering on a cold start for a bit?
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 02-09-2012, 05:14 PM   #5
AndyN
My Ride: ESS TS2 325ci
It seems like alot of problems to keep her running! Unless you have some serious modifications to the car I would suggest selling it.
On the other hand if it meant holding on to it untill you have enough money for the M3 then you can get by with it unless the diff is a complete headache!
Also there are a few places in the UK that will completely swap your engine and replace it with a fully reconditioned engine for around 1500
But if it were me I would just let her go and go get the m3 slightly earlier than planned and save yourself money in the long run.
AndyN is offline   Reply With Quote
Old 02-09-2012, 05:18 PM   #6
BeMyWhip
My Ride: 01 BMW 330ci
what was the diff ratio in the rear diff that cause such high revs?
You know you cant go too high with a manual unless you got a 6spd?
you must have had a 3.91...
any idea what it was? Does the person who put it in even know?
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
cylinder, diff, diy, head gasket, pipes
