Old 02-09-2012, 11:42 PM   #1
Hobbit382
My Ride: 99-328i 00-323i
600whp s52tu e46 build thread
Ok so I guess its time to start this.
S52 block bored to 86.5mm oring'd
S52 head machined to accept m54 dual vanos
JE pistons 9:1
Eagle rods
Arp 2000 rod bolts and head studs
Factory head gasket (installed dry)
M50 intake manifold modified to accept 540 throttle body (3 1/4")
Zhp cams (248, 248)
Safety wired oil pump nut
Spa t4 manifold
Tial 38mm wastegate
Hks ssqv bov
Turbonetics 72mm hurricane series (compact housing)
24x12x3 intercooler
E46 m3 tranny and rear end
The car
Hobbit382 is offline   Reply With Quote
Old 02-09-2012, 11:47 PM   #2
Hobbit382
The engine
The block
Old 02-09-2012, 11:54 PM   #3
Hobbit382
The head
Pistons rods
Opn
Intake
Cams
Old 02-09-2012, 11:57 PM   #4
Hobbit382
That's all the pics for now goodnight
P.S. I didn't post the tuning method on purpose, saving that for another thread.
Old 02-10-2012, 12:28 AM   #5
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I like !
When do you think it will be done ?
Side question: The 540 drive by wire throttle body you have, do you have any idea if it would work from an electrical stand point with a 330Ci, as in plug & play ? I understand some port matching would need to be done to the 330 intake manifold.
Rob
SUMMIT POINT WV 1:24:229 SCCA
Old 02-10-2012, 12:57 AM   #6
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
in for trap speed. Yesterday you didnt know what engine you had. Today, you built it. I expect drag results tomorrow.
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 02-10-2012, 01:52 AM   #7
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
+1
Would be good to see some video from the Texas Mile as well.
Old 02-10-2012, 04:08 AM   #8
basar13
My Ride: Z4M, R8, 525xd, STI
http://forum.e46fanatics.com/showthr...343&highlight=
Good luck with the build
basar13 is offline   Reply With Quote
Old 02-10-2012, 11:06 AM   #9
NickG
My Ride: 2011 BMW 550i M-Spor
I think this will be a very cool build. Basically a 3.2L M54 engine without the DISA intake manifold.
Julio, didn't we discuss like 2 years ago? You're late to the party man!
Nick
For Sale: 2005 BMW 330i ZHP with Technique Tuning Stage1 Turbo Kit
NickG is offline   Reply With Quote
Old 02-10-2012, 12:40 PM   #10
Hobbit382
haha im not god...
Old 02-10-2012, 12:42 PM   #11
Hobbit382
dont forget the larger intake and exhaust ports...
Old 02-10-2012, 12:46 PM   #12
Hobbit382
Rob
thats the plan...
hopefully have the n/a version up and running by next weekend for break in, then turbo after i get a new clutch and injectors, and fab up the exhaust and intercooler piping.
Old 02-10-2012, 01:41 PM   #13
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Originally Posted by Hobbit382 View Post
thats the plan...
You mofo... Saw this thread and was like ahhhh I see what you did there. Can't wait to see it up and running!
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 02-10-2012, 02:09 PM   #14
ZeroSum
My Ride: 05 325
Awesome - really interested to see how it turns out.
ZeroSum is offline   Reply With Quote
Old 02-10-2012, 02:13 PM   #15
mike@maximumpsi
My Ride: 02M3T
I wish I didn't see this. Now the gears are turning again.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 02-10-2012, 02:57 PM   #16
Hobbit382
haha thats how I felt when I first thought of this however ive been told someone else did it somewhere in europe. so i guess im not the first one to do it
Old 02-10-2012, 03:10 PM   #17
Activ3
There's also a car in Miami with the conversion done. The shop bought the wrong motor but made it work to replace an overheated m54. The car you're referring to in Europe had it done right though, and from my understanding made gobs of power
Old 02-10-2012, 04:00 PM   #18
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
First page... and
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 02-10-2012, 09:37 PM   #19
Hobbit382
any links? also how far along are you on your build?
Old 02-16-2012, 06:10 PM   #20
Hobbit382
Update
