Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 02-16-2012, 05:19 PM   #21
Gheybe
Gheybe's Avatar
My Ride: C6 Z06
Gheybe is online now   Reply With Quote
Old 02-16-2012, 07:53 PM   #22
chris b.
chris b.'s Avatar
My Ride: 2010 335i zmp
04' 325i sedan RIP, will be missed...
02' 325i sedan aw sport..sold...
07' 335i zsp....traded in....
10' 335i zmp...being beaten!....
95' m3 cosmos/dove 5sp...new project!
chris b. is offline   Reply With Quote
Old 03-04-2012, 12:05 PM   #23
Hobbit382
My Ride: 99-328i 00-323i
I ran the car last night for the hell of it. Currently it has the stock 328i throttle body, maf and intake w/ old oem filter. Factory exhaust and all the settings on the piggy back are set to zero as far as performance. So basically a completely stock setup minus the 3.2l with zhp cams and m50 manifold. Car weighs 3580 with me in it and ran 15.01 @94. Pretty slow... But based on hp calculators 232 rwhp. I feel it's broken in, and now ready for the e85, 540 throttle and turbo...
Hobbit382 is offline   Reply With Quote
Old 03-04-2012, 05:54 PM   #24
autospeed_01
My Ride: 2000 328Ci
Subscribed! and pm'd you on the emanage lol.
autospeed_01 is offline   Reply With Quote
Old 05-13-2012, 08:54 PM   #25
Iceman00
My Ride: ghey
Probaly not, but that is very awesome!
Old 05-13-2012, 09:44 PM   #26
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: Evo, 330Ci, Xterra
I am super interested in this.
Sent from my Kindle Fire using Bimmer App
^No longer looks like this
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 05-14-2012, 09:39 AM   #27
Hobbit382
why do you think that?
I actually think its very spot on compared to a few pulls against some modded e36 m3's but who knows for sure. I'm finally ready to put the turbo on (took a little longer than expected) I'll be putting on the hpf aem and taking it down to the dyno for for the last N/A numbers and then bolting up the turbo and fabing the downpipe, and charge piping.
Old 05-14-2012, 12:32 PM   #28
bluejeansonfire
ninja editor
My Ride: shaken, not stirred
Send a message via AIM to bluejeansonfire
I don't know, I have a tendency to agree. 232whp is about what I estimate I made when I was running 100mph trap speeds in my full weight car, or perhaps I made even less power, others have trapped more with similar weight and 230whp. 200whp yields around 94-96 depending on plenty of factors. both stock e46 330ci and e36M dyno similar numbers in the 190-210whp range. some e36s can't trap but 96mph, others trap 99+/stock. There's a significant variance in what people call stock, and dynos- that difference alone provides enough variance in hp that this question is moot. But 15.0@94 is just a very thin hair faster than my completely stock e36 325i nonvanos.
But who cares!? this project is low compression. The entire point of this thing is to have a charger attached and to fulfill the numbers claimed in the thread title. NA numbers are meaningless.
2001 330ci TT turbo
e46nonm.com | TechniqueTuning.com | Precision-Sport.com
bluejeansonfire is offline   Reply With Quote
Old 05-14-2012, 02:40 PM   #29
Hobbit382
Your right, I just think n/a numbers are interesting considering it's a completely hybrid motor. But anyway we shall see numbers with a turbo soon.
Old 05-31-2012, 10:38 PM   #30
kevbot
My Ride: 325ci
hey Alex its Kevin from work. I just now found out you were doing this build, and its epic! Do you have any updates yet? And when are we doing my car next?!
kevbot is offline   Reply With Quote
Old 06-01-2012, 09:20 AM   #31
10psie46
My Ride: e46 non m
Good luck with your rear subframe, all that power on these cars it will break sooner or later.
10psie46 is offline   Reply With Quote
Old 06-01-2012, 09:25 PM   #32
mestupmonkydude
Modded ///Member
mestupmonkydude's Avatar
My Ride: 328i
IMO I would have welded the oil pump nut instead. Just like how PEI330Ci did on his build.
mestupmonkydude is offline   Reply With Quote
Old 06-04-2012, 09:20 PM   #33
Hobbit382
Unfortunately when you weld the nut it weakens the shaft. There have been a few people that have still had oil pump failure after welding the nuts. Imop safety wire is the best bet on the oem pump
Old 06-05-2012, 05:41 PM   #34
bimer21
My Ride: stick 325i
moreeeeee
bimer21 is offline   Reply With Quote
Old 06-05-2012, 06:27 PM   #35
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I drove the car for a couple of weeks like that....then pulled the pump off as part of a rebuild.
It now has a completely different kind of pump on it....no nut.
Old 11-30-2012, 08:53 AM   #36
aggieE46
Keep it clean
aggieE46's Avatar
Uh... bump. Woke up thinking about this
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 12-03-2012, 08:30 PM   #37
Lezz21
My Ride: 1999 323i
For the 540 throttle body. are you using complete drive by wire or the semi electronic(wire/computer).
Lezz21 is offline   Reply With Quote
Old 12-27-2012, 02:12 AM   #38
E46inthe206
My Ride: 2003 BMW 330Ci
What's the deal with this now? I'm interested.
5-Speed 2003 330ci - Sport, Premium, Winter packages.
Name of Owner: David.
E46inthe206 is offline   Reply With Quote
Old 12-27-2012, 10:01 AM   #39
Think0rz
My Ride: 05 AW M3
safety wire ftw cant wait for updates
Think0rz is online now   Reply With Quote
Old 01-29-2013, 05:30 PM   #40
Hobbit382
sorry guys its been a while. Ive been slammed with work, working 12-14 hour
days at times and dealing with a custody battle with my kids so haven;t really had much time for toys. The car is still running as a daily driver (on e85) but still naturally aspirated. I plan on getting back into it here as soon as it starts slowing down again.
