Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 09-23-2013, 12:17 AM   #181
turbotoy2791
My Ride: 04 m3
Do you have the speed sensor hooked to the AEM, factory cars raise the idle and add fuel above 0 mph when the engine is decelerating. There should be an option to increase idle speed until at a full stop. Might also try raising the deceleration fuel cut off, either rpm or add fuel at lower rpms -1500. Another thing if you don't have a deceleration option, Goto your main fuel map at the highest vacuum and lower rpm add fuel, it will be at a different cell than your idle cell.
I don't have your software or I could give you a better answer.
turbotoy2791 is offline   Reply With Quote
Old 10-30-2013, 02:02 AM   #182
Rudbari
My Ride: m3
Congrats bro,great build .
What was your feedback on trying 4.10 with your kit.
Rudbari is offline   Reply With Quote
Old 10-31-2013, 02:02 PM   #183
Cipri
My Ride: E46 M3 2002
1st and 2nd gears where gone, wheels where lighting up...
I have put now 3.23 gears - which are much better - I can finish the quarter mile in 4th gear.
Cipri is offline   Reply With Quote
Old 11-01-2013, 07:48 AM   #184
Rudbari
My Ride: m3
Oh your on 3.23 now , I feel for street use and track the stock ratio is the best . What you think!!!
by the way great build bro...
Old 12-13-2013, 12:41 PM   #185
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
S54 custom turbo setup
Going full custom: 4" exhaust
More alumium custom to follow: expansion tank, surge tank, oil catch can.
Cipri what mufflers r those?
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 12-14-2013, 03:10 PM   #186
Cipri
Re: S54 custom turbo setup
Custom from Borla.
Sent from my GT-I9505 using BimmerApp mobile app
Old 01-04-2014, 10:49 AM   #187
Cipri
Finaly I fixed the idle issue and stalling at idle, the TPS was not calibrated properly and I found in the AEM tuner software how to make it calibrate by itself.
I had TPS voltage min 0.64 with max 4.16 and now it is 0.82 with 4.24
Old 01-04-2014, 06:08 PM   #188
Twin_Turbo_S54
My Ride: M3
Cipri, you should participate more often, this forum is about to stall and is at idle
Cmon, where are the boosted e46fanatics?
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 01-04-2014, 09:46 PM   #189
nek0
My Ride: e85 turbo m3
nek0 is offline   Reply With Quote
Old 01-04-2014, 11:28 PM   #190
being3
Modded ///Member
being3's Avatar
Make sure the min tps voltage is set so that the tps percentage is never 0.. Should be set at 1 percent at idle. This number can fluctuate with the jumperbox small harness DME side power pins can heat up and cause melting and messes with the connectivity resulting in tps voltage discrepancies and fluctuations...
Old 01-04-2014, 11:30 PM   #191
being3
Modded ///Member
being3's Avatar
I agree its dead lately on the forum.... Let's get some action
Old 01-05-2014, 03:58 AM   #192
Cipri
It's winter, not to much going on
Next week I will send the car back to the shop for:
- Racelogic TC install
- front wheels brake line locker
- new fuel system
- new tune for race fuel, pressure will go now to 26 PSI
Old 01-05-2014, 04:36 AM   #193
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
In general, people just don't have the money to "do" things to their cars, so there's not much to post about. This isn't the only forum with not much going on...
Old 01-05-2014, 11:06 AM   #194
Twin_Turbo_S54
My Ride: M3
Adam,
gtrlife.com and gtr.co.uk both of these GTR forums are full of projects.
I think GTR platform keeps on evolving at a much faster speed.
Maybe E46 related projects continue but not shared on forums?
Old 01-05-2014, 12:13 PM   #195
mdrobnak
My Ride: 04 330i SMG TT STG1
Adam,
Actually, that would go with Adam's argument - the GT-R is a much more expensive car to begin with, thus those modifying it would have more disposable income to begin with. So they can do more with the car they have, vs the E46 platform overall is getting more and more inexpensive. Therefore it's possible that those modifying it likely have smaller budgets to work with.
I think you'll see more after some people get an income tax refund.
-Matt
2004 330i with Technique Tuning Stage 1 Kit, UUC Twin Disc Clutch + FW Kit, Walbro 400 Fuel Pump, Aeromotive FPR, Modified Return Lines, E36 Fuel Filter, Ethanol Content Sensor, 550i Clutch Actuator, Lengthened actuator rod, modified exhaust, and FX-R projectors.
93 Octane - 8.5 PSI : 309RWHP on a Superflow / 3XXRWHP on a DynoJet
E85 - ? PSI : ???RWHP on a DynoJet
First SSG MoTeC M150 Powered 330
mdrobnak is offline   Reply With Quote
Old 01-05-2014, 02:34 PM   #196
Twin_Turbo_S54
My Ride: M3
- new fuel system
Cipri,
good luck with the poject. We are very close to each other, hope to meet you soon.
Old 01-05-2014, 02:59 PM   #197
being3
Modded ///Member
being3's Avatar
- new fuel system
Nice.... Very interested in how racelogic works out for u...u will have to let us know how to set it up for r cars as well as the line lock... U will love running 26psi of boost... Makes lots of torque ...
Old 01-15-2014, 04:05 PM   #198
Cipri
Who has in stock Aeromotive filter part nr. 12304?
I need it shiped tomorrow to Romania.
Thanks!
Old 01-16-2014, 04:25 AM   #199
Twin_Turbo_S54
My Ride: M3
P/N 12302 is on my shelf, I can DHL today, you will receive tomorrow.
Old 01-16-2014, 03:39 PM   #200
Cipri
Thanks for the helo Mert, this filter will need to be adapted on the lines, I don't want to complicate the setup.
Lab22 will send it to me.
