Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 08-12-2012, 12:22 PM   #81
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
Congrats .
HPF Chris is offline   Reply With Quote
Old 08-12-2012, 04:48 PM   #82
jeff_smg
My Ride: //Turbo M3
Send a message via MSN to jeff_smg
Originally Posted by Cipri View Post
1st place in the national drag championship?
Great :-)
Turbo //M3 E46
jeff_smg is offline   Reply With Quote
Old 08-13-2012, 08:27 AM   #83
manifoldmike
My Ride: 2001 Chevy Silverado
Originally Posted by zbarca2009 View Post
I belive you are talking about the twin scrool setup, when you are talking about exhaust parts there is no inlet as inlet is specific to air induction.It's not a good idea to put twin-scrool turbocharger on a normal T4 flange as you will create a lot of backpressure in the manifold because of the middle split of the turbine housing. Bafta!
Not true at all. All data says otherwise. Twin scroll > All. You'r turbine size is the biggest factor for backpressure. From what I've seen there are no twin scroll manifolds available.
manifoldmike is offline   Reply With Quote
Old 08-13-2012, 12:49 PM   #84
DOC_Race
My Ride: 03 M3
Great job! 42R ftw
DOC_Race is offline   Reply With Quote
Old 08-13-2012, 02:37 PM   #85
Cipri
My Ride: E46 M3 2002
So I can run a twin scroll turbine on a normal T4 manifold?
Thanks Doc, I will go with the 42R.
Cipri is offline   Reply With Quote
Old 08-13-2012, 04:04 PM   #86
zbarca2009
My Ride: E46 M3 VF570
What data?Show us please.
I /// M back...
VF570 inside
zbarca2009 is offline   Reply With Quote
Old 08-13-2012, 04:09 PM   #87
zbarca2009
Don't rush into it and do some more research and you will find out why.
I /// M back...
VF570 inside
Old 08-13-2012, 05:19 PM   #88
DOC_Race
My Ride: 03 M3
What zbarca said.
On the divided issue, I wouldn't run a divided housing with open flange or vise versa for performance reasons. It can be done, and I have seen it executed that way but it was in a situation where the person was working with the parts they had.
I have never seen that type of data recorded, doesn't make much sense to run it this way in the first place. Maybe manifoldmike will have the said data?
Being you already have a custom manifold setup reworking it into a divided version is probably your best option, also giving you a dual gate outlet for better boost control
Old 08-14-2012, 07:36 AM   #89
manifoldmike
I was referring to a divided turbine with a divided manifold. Doesn't make much sense to run a divided housing on an open manifold because you're not benefiting from pulse division from the manifold. if you have a turbo already with a divided housing, you can either port the division in the middle to a fine point or just buy another housing (depending on the turbo, usually ~$350). Divided housing performance is common knowledge. you guys need some data? why don't you search the interweb like the rest of us. I'll try to see if i can scrounge some stuff up, but i assure you, my "data" won't be a engineering talking point or an end all to the argument.
Little info:
http://www.full-race.com/modified-twinscroll/
http://www.turbodriven.com/en/turbof...gnTurbine.aspx
http://www.turbobygarrett.com/turbob...Tech%20102.pdf
http://www.full-race.com/articles/efrturbotechbrief.pdf
Old 08-14-2012, 07:56 AM   #90
manifoldmike
I would like to see some data on backpressure differences between a divided housing and a single scroll housing on an an open manifold with both turbine housings being the same A/R.....
Cipri : Sorry for the thread hyjack. Your setup is pretty awesome.
Old 08-14-2012, 07:59 AM   #91
zbarca2009
LOOOL!I guess you have to read again what I have posted: a divided turbine housing on an undivided manifold will create backpressure because of the divided turbine housing flat split. Read with care before posting bro This was a missunderstanding I suppose and we all agree on one fact: Don't use divided turbine housing on undivided manifold.
I /// M back...
VF570 inside
Old 08-14-2012, 08:02 AM   #92
manifoldmike
sort of. I would like to see some data on backpressure differences between a divided housing and a single scroll housing on an an open manifold with both turbine housings being the same A/R..... I don't think it will make much difference. Like the little difference it would make between going for a small turbine housing to a larger housing. My point was that the performance is in the turbine wheel, not the housing. If the guy has a GT42 in grasp for a good price, run it. the turbine housing, divided or not shouldn't make much difference.
Old 08-14-2012, 08:02 AM   #93
zbarca2009
The turbine housing has a flat middle which the gas flow will straight hit, that is gas flow comming back - > backprssure, you will get backpressure in the manifold, you don't need to be an engineer to understand that.
Mike, the thing is that a divided T70 was getting my EGT very high comparing to undivided turbine housing on normal manifold. Same turbocharger different turbine housing as divided/undivided. Those EGT's were that high because of the backpressure and this was on E36 M52B28 Turbo with 3.5" Cometic HG, not stock S54. This theory worked for me to drop the EGT.
I /// M back...
VF570 inside
Old 08-14-2012, 08:09 AM   #94
manifoldmike
Well... you sort of do, but ok. your claim has no data to back up. backpressure is a funny thing to generalize.
Old 08-14-2012, 08:12 AM   #95
manifoldmike
EGT is not backpressure. but fair enough. not trying to fight you on this, just that the divided turbine comment is unwarranted. i'm sure i've spewed enough crap for today. my vote is is 42 is fine, divided or not.
Old 08-14-2012, 08:14 AM   #96
zbarca2009
Well, I just shared my experience with Cipri who is also my fellow contryman, I guess we don't want to see him worried about high EGT's don't we?
Giving my arguments, if not for backpressure, for what was my EGT dangerous high with the divided and cool with the undivided housing?
I /// M back...
VF570 inside
Old 08-14-2012, 08:43 AM   #97
manifoldmike
so what if your pressure change fro 3:1 to 2:1 with the housing change? you see the difference in egt, but your back pressure is still ridiculous. I used an extreme case here, but you get the drift.
you can tame EGT regardless of pressure with fuel and timing.
EGT is not backpressure... sort of, they are related i will agree with you on that.
Old 08-14-2012, 09:41 AM   #98
zbarca2009
Mike, I am an engineer, you don't have to tell me that EGT can be dropped by timing retard and fuel enrichment, I already know that but is much easier to find out the problem instead of walking around it. As I said, EGT got stable after I changed the divided housing with an undivided one on an undivided manifold. Backpressure is not EGT but can affect EGT as in my case.
So, for my fellow countryman Cipri, get a different turbine housing for the turbocharger. This is the clean and slick way to do modifications at this level on the S54. If you want to play as all our romanians do, go ahead, but it's not good.
I /// M back...
VF570 inside
Old 08-28-2012, 02:39 PM   #99
Cipri
New custom aluminium intake manifold, I'm prepared now to raise the boost to 0.6BAR
This weekend I will go to an airport track in Bulgaria to check new 1/4 miles times.
ID:	466643   Click image for larger version
ID:	466644   Click image for larger version
ID:	466645   Click image for larger version
Old 08-30-2012, 09:18 PM   #100
oddis
My Ride: E28, E30s & E34iX
You've got good drivability there, if your car had been lighter, like an E30 or E28 that thing would be flying on the racetrack.
Propper plenum there too. Well spec'd to do alot more than 0,6 bar 5 mm material?
oddis is offline   Reply With Quote
