Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 03-31-2013, 04:54 AM   #121
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by Cipri View Post
Aeromotive A1000 fuel pump + controller with custom surge tank and fuel lines
Hmmm....
Old 04-02-2013, 07:17 PM   #122
JD04330i
My Ride: 2004 330i
Does anyone have a DIY walk through for a turbo install for an 04 330i? Looking to piece together a turbo for my DD and don't really want to have my car down for a long period of time. Also anyone know where I can get the ECU flashed by shipping it to them?
JD04330i is offline   Reply With Quote
Old 04-02-2013, 09:59 PM   #123
Commanderwiggin
My Ride: 900rwhp Turbo M3
Ebay
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 04-02-2013, 10:35 PM   #124
02PRUV
My Ride: E46 M3 Turbo
Originally Posted by Commanderwiggin View Post
Ebay
Yep here:
http://www.ebay.com/itm/NEW-ELECTRIC...26002c&vxp=mtr
Quick install DIY and no tuning required. 15% power gain. Meets all your criteria
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 04-03-2013, 02:00 AM   #125
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
On a more serious note: A Technique Tuning kit is the only complete solution, and it is excellent.
Old 04-30-2013, 12:06 PM   #126
Cipri
My Ride: E46 M3 2002
Problems with the subframe
ID:	503162   Click image for larger version
Cipri is offline   Reply With Quote
Old 04-30-2013, 02:54 PM   #127
MalibuMafiaV
My Ride: E60 M5 & Stg3 AudiS4
Just weld the rips yourself. That's what I did. I just keep an eye on it and if it rips again I'll just weld it again lol. I don't give a crap if it looks good or not, it works and that's what matters.
TheMalibuMafia.com
Instagram
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i - ST GT35R
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
MalibuMafiaV is offline   Reply With Quote
Old 04-30-2013, 03:49 PM   #128
Cipri
S54 custom turbo setup
The car is at a professional welder, he will repair it and make also the reinforcement work.
The problem is that this will delay with a few days the project...
Old 04-30-2013, 04:08 PM   #129
02PRUV
LOL that doesn't work it just hides a crack. You need to fix the problem. It's not a case of "I can't see you, so your not there" that will cause more damage.
Rides:
Old 05-13-2013, 01:53 PM   #130
Cipri
New setup: Hoosier Quick Time Pro DOT - 26x11.5-15
Mods:
- E46 330 rear trailing arms + brakes
- custom metal 15" rims
Here are some pictures:
ID:	505397   Click image for larger version
ID:	505398   Click image for larger version
ID:	505399   Click image for larger version
Old 05-13-2013, 02:11 PM   #131
basar13
My Ride: Z4M, R8, 525xd, STI
Sweet.... loved it.
basar13 is offline   Reply With Quote
Old 05-13-2013, 02:23 PM   #132
Twin_Turbo_S54
My Ride: M3
Cipri,
We should meet man. Are you in Bucarest?
Sweet color and sexy tires.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 05-13-2013, 03:35 PM   #133
Cipri
I'm very close to Bucharest, maybe we could meet here or in Sofia at the next drag race.
By the way, do you know the Turkish transport company Mert?
Old 05-13-2013, 03:57 PM   #134
Twin_Turbo_S54
My Ride: M3
Cipri,
Which Turkish transport company?
Old 05-13-2013, 04:24 PM   #135
Sedan Hussein
My Ride: e46
Mods:
I'm digging it.
Sedan Hussein is offline   Reply With Quote
Old 05-18-2013, 12:52 AM   #136
Cipri
Just started the car yesterday after the engine built.
I have put also a new vanos unit and still I receive vanos errors from the DME. At idle some times the car goes very quick in high AFR (15 to 17), I ha the same problem before the engine built and was thinking it's the vanos unit...
What else could it be? What logs should I make?
Old 05-18-2013, 02:38 AM   #137
Twin_Turbo_S54
My Ride: M3
injectors may be damaged
spark plugs may be damaged and misfiring
coils may be misfiring
lambda sensor may be damaged, your actual afr values may be spot on but 02 sensor may be off.
check for leaks and all connection hoses / clamps.
Old 05-18-2013, 10:11 AM   #138
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
2 things to look at: What does ur throttle read at idel? Needs to be around 2 percent.. aem hates to be a 0 percent and causes weird things .Also the fuel table might need richening up at 900 to 1200 rpm... Try adding 1% then see what happens to Afr.
As for logs: 02 feed back. O2. 02 target, Throttle , Tps voltage , rpm. Send them to me. Also add cam 1 and cam 2 advance
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 05-18-2013, 11:20 AM   #139
being3
Modded ///Member
being3's Avatar
I'm sure u know this but ill check. AEM causes Vanos codes in dme. Cams Over retarded / out of range etc.... These r normal.. What codes r u getting? If u do the logs with the cams I can check to see how there r moving and if they r within range
Old 05-18-2013, 01:44 PM   #140
Cipri
I will make all the logs and send them to you, also post here the vanos codes.
To explain in details what happens with the AFR: I start the car and the AFR is normal at 13-13.5, after I accelerate a few time the AFR drops to 15-16, after a few more accelerations the AFR comes back to normal 13-13.5, after acceleration also the RPM drops for a few seconds to 500-600 and then goes to normal just that AFR is going to 15-16.
