Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 05-19-2013, 12:47 AM   #141
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
S54 custom turbo setup
Originally Posted by Cipri View Post
I will make all the logs and send them to you, also post here the vanos codes.
To explain in details what happens with the AFR: I start the car and the AFR is normal at 13-13.5, after I accelerate a few time the AFR drops to 15-16, after a few more accelerations the AFR comes back to normal 13-13.5, after acceleration also the RPM drops for a few seconds to 500-600 and then goes to normal just that AFR is going to 15-16.
Her r some of the codes that AEM gives
DME codes
10: Crankshaft sensor
19: Ignition coil, cyl#1
17: Ignition coil, cyl#2
18: Ignition coil, Cyl#3
34: Ignition coil, cyl#5
33: Ignition coil, cyl#6
32: Ignition coil, cyl#4
29: Mass air flow sensor
15: Exhaust camshaft VANOS retard Valve
16: Exhaust camshaft VANOS advance valve
48: Intake camshaft VANOS retard valve
43: Intake camshaft VANOS advance valve
B8: Intake camshaft VANOS position control
B9: Exhaust camshaft VANOS position control
AE: Air-fuel adaptation cyl#1-4
AF: Air-fuel adaptation cyl#5-8
4F: Exhaust gas temperature sensor
89: Jet stream pump
4D: Intake air temperature sensor
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 05-20-2013, 12:29 AM   #142
being3
Modded ///Member
being3's Avatar
Just started the car yesterday after the engine built.
I have put also a new vanos unit and still I receive vanos errors from the DME. At idle some times the car goes very quick in high AFR (15 to 17), I ha the same problem before the engine built and was thinking it's the vanos unit...
What else could it be? What logs should I make?
Check to Make sure ur 02 FEedback is set to no more than -5% to +5% Also ,make sure the 02 sensor gain is calibrated to ur sensor with the engine running to compensate for ground noise. ( u can use ur AEM serial gauge and compare it to ur AEM 02 gauge... Adjust till they r the same .. If its not the actual AFR will be fighting against the AEM ems and it will fluctuate....
Old 05-20-2013, 04:43 AM   #143
Cipri
My Ride: E46 M3 2002
What is "Camshaft 2" in AEM, is it the intake camshaft? Because for this my tunner can not modify the angle of the axle, even if he puts in the map a certain angle - the axles remain at same position.
For Camshaft 1 is working perfect, also all sensors are working.
Anthony, I have sent you the log.
Cipri is offline   Reply With Quote
Old 05-20-2013, 02:27 PM   #144
Cipri
Who has the electric scheme of the HPF AEM?
It seems the output from the AEM for intake camshaft is not working, I know it is PVM10 and we can not locate it. Is it possible to switch it to another output?
Now was the perfect time for me since HPF is out of business...
Old 06-04-2013, 02:46 PM   #145
Cipri
Cams issue was fixed, it has been one semiconductor fried.
I'm still having issues with the car, pretty annoying ones:
- Voltage read from AEM is less with approx. 1 volt compared to an external voltmeter readings
- throttle with engine running is having a small blank spot where I push the throttle and AEM doesn't read the TPS sensor, with engine stopped and only ignition on the readings are perfect
After engine is warmed and in normal working temperatures the AFR goes crazy at idle and also when slowing down during driving (intersections, traffic lights) the engine stops - I need to restart it and push a bit the throttle to not stay at idle because it dies again.
Maybe someone has some hints for me.
Old 06-13-2013, 11:10 PM   #146
turbotoy2791
My Ride: 04 m3
Check your grounds AEM, engine, and chassis
turbotoy2791 is offline   Reply With Quote
Old 06-13-2013, 11:26 PM   #147
turbotoy2791
My Ride: 04 m3
Hi Cipra,
Are you able to get another header flange or have a bluprint of the flange.
Old 06-14-2013, 01:29 PM   #148
Cipri
Test setup for the engine build, everything is working ok now
ID:	511041   Click image for larger version
ID:	511042   Click image for larger version
Old 06-14-2013, 06:20 PM   #149
being3
Modded ///Member
being3's Avatar
Glad things worked out for u man hp and torque come on way up there.
Old 06-14-2013, 07:06 PM   #150
Commanderwiggin
My Ride: 1000rwhp Turbo M3
Edit nvm...was thinking of a different project.
Old 06-17-2013, 01:27 PM   #151
Cipri
I was at the strip in this weekend, because of the big turbo I can't have hard launches, only 2.0 60ft with 120 mph exit speed and 12.2 1/4 mile time.
Is there any possibility for LC on AEM v1? I realy need to build some boost for better 60ft time, I'm running Hoosier Quick Time Pro DOT 26x11.5x15
Old 06-17-2013, 01:31 PM   #152
Commanderwiggin
You can have a 2 step rev limiter with anti-lag with the V1.
Old 06-17-2013, 01:56 PM   #153
Cipri
You have it? Some hints on who could help me set it up?
Thanks!
Old 06-17-2013, 02:54 PM   #154
Twin_Turbo_S54
My Ride: M3
Cipri,
have you logged 60-120 times?
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 06-17-2013, 03:57 PM   #155
Commanderwiggin
Thanks!
My 2 step is enabled around 4k iirc...not sure who would be best to go over the details on setting the anti-lag up...a local tuner would be my recommendation.
Old 06-17-2013, 04:43 PM   #156
Twin_Turbo_S54
My Ride: M3
John Reed.
Old 06-17-2013, 06:03 PM   #157
Commanderwiggin
Originally Posted by Twin_Turbo_S54 View Post
John Reed.
Not so local but yep that would work
Old 06-17-2013, 08:07 PM   #158
being3
Modded ///Member
being3's Avatar
The HPF AEM has a spare output that u could use to hook up a switch. Then setup the 2step in the AEM and have it use that. U could even have it hooked to the clutch so when u pushed it in the rev limiter activate and then release with the clutch. AEMpro documentation has the instructions on how to set it up. I can help u with what pin to use.
Old 06-17-2013, 08:10 PM   #159
being3
Modded ///Member
being3's Avatar
There is also a drag strip anti lag setup in the Aempro software for the AEM. Also the 2 step can be setup without a switch and run off of VSS input then set the lowest speed as the activation point. It's all in the AEMPro manual
Old 06-19-2013, 11:04 AM   #160
Cipri
Re: S54 custom turbo setup
My AEM doesn't read the vehicle speed, is this normal?
