///M3 Forum
Old 02-11-2012, 01:53 AM   #1
TerraPhantm
My Ride: M3 & ZHP
Z4M electric fan retrofit?
I've been contemplating deleting the mechanical fan, but I don't really want to go with an aftermarket solution. I've been tempted to retrofit the non-M electric fan, but always held back because I'm not sure if it would be powerful enough (I think it'll fit though. Radiator brackets seem to be the same).
Now looking at the z4m - it has a 600W electrical fan (compared to the 390w fan in the non-Ms). Mounting points are identical to the e46 non-M fan. I'm thinking this should do the trick since it's from an s54 car. And it should into the existing connector. One potential issue is that the z4m comes with a different radiator (same radiator as e46 non-M actually). Another issue is that it's expensive ($500 shipped at thebmwpartstore.com)
Before I attempt this - has anyone attempted either this fan or the non-M electrical fan? Can they at least mount up? If not, how difficult would it be to retrofit whatever piece has the screw holes? (would I need a new radiator or can I just swap some plastic bits?)
Old 02-11-2012, 11:22 AM   #2
wilsel
My Ride: 05 AW M3 ZCP
Since they have an S54 too it has to be adequate to cool it. It may require making your own mounting brackets I'm not sure.
wilsel is offline   Reply With Quote
Old 02-11-2012, 02:11 PM   #3
TerraPhantm
My Ride: M3 & ZHP
Looking at the diagrams, I think it should fit with little to no problem.
E46 M3 Shroud Diagram:
Code:
No. Description Supplement Qty  From   Up To  Part Number Price Notes Photo
01 Radiator 43/9,4/66 1   17102228941 $385.75
02 Fan shroud  1   17112228943 $74.77
03 Air duct, left  1   17112228945 $31.72
04 Air duct, right  1   17112228946 $31.72
05 EXPANDING RIVET  3   17111712963 $0.27
06 SUPPORTING PART  1   17117530252 $13.42
07 SUPPORTING PART  1   17117530254 $13.42
08 GASKET LEFT  1   17111436247 $10.10
09 GASKET RIGHT  1   17111436249 $10.10
10 BRACKET F.RADIATOR  2   17117514402 $5.83
11 BRACKET F.RADIATOR  2   17111436264 $5.37
12 RUBBER BUFFER  2   17111178412 $1.68
13 Screw self-tapping D6X20 ZNS3 4   17117536971 $1.12
14 Screw self-tapping  1  07/2004 17111716600  ENDED
14 Screw self-tapping D6X40 ZNS3 1   17117536972 $1.12
15 Bracket, fan housing  1   17112282209 $5.82
Z4M Cooling Fan (integrated shroud):
Code:
01 Fan housing with fan 600W 1   17427542912 $621.50
02 Fan shroud  1   17427542913 $103.40
03 Screw self-tapping 5X1,23X10 5   17427514831 $1.12
04 Screw self-tapping D6X40 ZNS3 3   17117536972 $1.12
05 Mounting plate  1   17117836843 $54.97
06 Screw self-tapping D6X20 ZNS3 3   17117536971 $1.12
07 EXPANDING RIVET  2   17111712963 $0.27
The Z4M fan mount is basically the same design as the E46 non-M fan. The left side seems like it matches up reasonably well (at least the top screw should). However, part number 5 seems to function as some sort of adapter which makes the right side mounting points match up with the M3 points.
Now I gotta see if I can find who makes the Z4M fan since I'd rather not pay $500 through BMW. Or I suppose I can just risk the non-M fan...
Old 02-11-2012, 02:21 PM   #4
Tchleung
My Ride: 02 M3
I would look into mounting depth. As there is not a lot of room between the radiator and the snout on the water pump where the old fan mounted onto. This is the most common issue. I've been looking at doing this too and if I can find a fan replacement that would guarantee to cool BETTER then the factory fan, then I would cut off the threaded snout of my new water pump giving me an extra 1.5" clearance and making it permanently electric only.
I don't see why this won't work though. The biggest issue with people is that they don't realize how much an improvement having a full shroud makes. I have been contemplating using a Zirgo 3365cfm fan and modifying the factory shroud to seal around the Zirgo fan.
Follow me on Instagram @tommtomm84
03 Carbon Black X5 4.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
456whp/312wtq @ 8psi, No #'s yet at 9psi
4.10 / Headers / ESS VT2-550+
Tchleung is offline   Reply With Quote
Old 02-11-2012, 02:23 PM   #5
Snik
Snik's Avatar
My Ride: IR M3 Vert.
well, if you risk it and buy it form BMW. then if it doesnt work, assuming you dont get it dirty or damaged, you could return it, no?
Do you ride a sportbike?
Old 02-11-2012, 02:46 PM   #6
Tchleung
My Ride: 02 M3
You generally can not return special order parts, especially electrical components.
Old 02-11-2012, 02:54 PM   #7
Snik
Snik's Avatar
would it be a special order? its a cooling system component for a BMW id assume theyre on the shelves we all know how bulletproof our cooling systems are. lol
Old 02-11-2012, 03:23 PM   #8
TerraPhantm
My Ride: M3 & ZHP
Yeah that's one concern I had. I think it should work simply because e46 non-Ms convert from mechanical to electric all the time without issue, and they have the same mounting mechanism. If you think about it, there's enough room to back the mechanical fan out all the way without it getting stuck, and the electric fan wouldn't have that 32mm nut sticking off it.
One of these days I should borrow one of my non-M friends' fans and see how the fitment is
Old 02-11-2012, 06:29 PM   #9
Tchleung
My Ride: 02 M3
I think it might be close.
You can use the fan control box on the right of the shroud(left side on ours) as reference to size. It might just clear.
Old 02-11-2012, 06:37 PM   #10
Tchleung
My Ride: 02 M3
After looking at pics. Looks like #5 is used on all of them from the factory on Z4M's
Old 02-11-2012, 06:56 PM   #11
TerraPhantm
My Ride: M3 & ZHP
Well only reason I mentioned #5 is because that's one piece the Z4M has that the E46 non-M doesn't have, and it seems like the cirlced bits below correspond to one another. If that is indeed the case, it seems like there are at least 2 mounting points that will line up with our cars. The bottom holes might line up too
Old 02-11-2012, 06:59 PM   #12
Tchleung
My Ride: 02 M3
Ohh okay sorry I misunderstood you. Hrmm, you may be on to something. It's a shame it costs so much money. :s
Old 02-11-2012, 08:23 PM   #13
TerraPhantm
My Ride: M3 & ZHP
I know =/. I'm thinking about ordering that piece number 5, borrowing my friend's electric fan (he has a 330i), and see if it's at least possible to mount everything. Since the dimensions without piece #5 are the same between the Z4M and 330i fans (or at least they appear to be), that should give an idea if everything can be installed with a factory-like fit and finish.
Old 02-11-2012, 08:47 PM   #14
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
hvac sensor or whatever is on the opposite side as well.
Old 02-11-2012, 09:17 PM   #15
Tchleung
My Ride: 02 M3
That's correct, but extending wires and making a mount is not a big deal. You'd have to do wiring anyways to run the fan so.
Old 02-11-2012, 11:43 PM   #16
TerraPhantm
My Ride: M3 & ZHP
^ maybe not. The connector seems to be the same as what the pusher fan uses. It definitely is the same connector in the case of the non-Ms. Moving that hvac box should be trivial though.
Edit: You know, the fan + adapter plate certainly looks big enough. Even if the mounting holes aren't there, the parts covering them are just plastic. Could easily just drill a hole in the right spot, and you'd have a cooling fan that plugs into the factory connector and hooks upto the radiator securely.
Old 03-01-2012, 06:52 PM   #17
trive2
My Ride: 1989 BMW 535i
We still haven't found a cheaper place to source this beast from? I've got to put my parts order in next week for my auto 330i and I might stick with a 390w fan.
Our temperatures get up to 100 farenheit but don't go below 50 or so here in Brisbane. I haven't found anyone who can tell me for sure whether the 390W fan is strong enough for an autoboxed car in a high temp environment or not, but I guess It's about my turn to be a Guinea Pig.
But still... If anyone can get a Z4M fan for less than $400 I'll be sold on it.
trive2 is offline   Reply With Quote
Old 03-01-2012, 07:33 PM   #18
TerraPhantm
My Ride: M3 & ZHP
I don't really know where to look. Pelican only has the "Genuine BMW" listed, and most other sites don't even list the part. Z4M isn't exactly a common car, so I guess the demand for non-BMW branded OEM parts isn't very high (and I doubt the fan fails very often). Cheapest I've found is thebmwpartstore.com at $500 shipped. I haven't really tried asking any local dealers, but I doubt they'd be much cheaper. I'm tempted to just try the 390W version. I can't imagine running into any issues with the temperatures we get around here
Old 03-02-2012, 04:47 AM   #19
Snik
Snik's Avatar
Terra, any junkyards near you. maybe you can find one that spun out and the nose is untouched. see if you can google some and make some calls.
Old 03-15-2012, 07:39 PM   #20
trive2
I might add that according to Realoem.com, all the Z4's had 490W fans and the "hot-climate" versions (hopefully the Australian cars!) had 600W fans like the Z4M.
Basically, the 600W fan wasn't just on the Z4M and a plain E85 fan is still an upgrade on an E46 fan.
EDIT: I just paid $7.50 for a 600W Z4 fan off ebay. *WIN*
