Old 02-12-2012, 09:01 PM   #1
CJBrick
My Ride: '05 325ci
What kind of replacement bulb?
I'm extremely confused after reading through forum after forum.. I have a 2005 ZHP with the factory projectors.. I don't want to do the swap for the fx-r, I just want to keep the factory stuff. I want HID's though. I bought a cheap set at a car meet and they burnt out after a few months and they weren't any good. I know my car uses an H7 bulb... So why is everyone saying get these 66240 OSRAM which says it fits a DS2 slot?
CJBrick is offline   Reply With Quote
Old 02-12-2012, 09:46 PM   #2
TerraPhantm
My Ride: M3 & ZHP
If your car has factory HIDs, it takes D2S bulbs. If it has halogens, it takes H7 bulbs. If you do have halogens, then the Osram/Philips recommendations don't apply. I would just get whatever H7 bulb review well. I personally like the Osram Rallye 65W bulbs. Technically they're not legal since they're 65W (instead of 55), but they are quite a bit brighter, last longer, and retain the same focus point as the stock H7 bulbs. The car's wiring should be able to handle it without much issue.
Old 02-12-2012, 10:17 PM   #3
CJBrick
My Ride: '05 325ci
Okay thank you for that! That clears up all the confusion.
Old 02-13-2012, 12:16 AM   #4
CJBrick
My Ride: '05 325ci
Just checked my headlights and molded into the plastic it says H7 or DS2 so does that mean a DS2 HID Kit will fit properly?
Old 02-13-2012, 12:28 AM   #5
TerraPhantm
My Ride: M3 & ZHP
Do your projectors say something like "Xenon" or "BMW Xenon" on the ring surrounding the lens? If so, they'll take D2S bulbs.
to make this easier, if your car is a sedan, then it has xenons (halogen sedans didn't come with projectors). If it's a coupe or convertible, then look at the projectors.
Old 02-13-2012, 12:59 PM   #6
CJBrick
My Ride: '05 325ci
Got it figured out now! Thank you. Just ordered some Morimoto Elite H7 5000k HID's from The Retrofit Source!
Old 12-27-2012, 01:39 PM   #7
1hot325
My Ride: Bmw 325i
Are 35w d2s bulbs good?
1hot325 is offline   Reply With Quote
Old 12-27-2012, 01:44 PM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Xenon bulbs do not get rated in watts, the ballasts do.
Xenon bulbs get rated by color/temperature.
What color bulbs you want? OEM yellow or white?
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 12-27-2012, 02:02 PM   #9
1hot325
My Ride: Bmw 325i
Like that white that is almost blue but white. Like a baseball park lol
Cause I saw some d2s bulbs that say 6000k 35w
Also can I use 6000k with my stock ballast
Old 12-27-2012, 03:13 PM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
Jeez get your thoughts together before making a million posts.
I told you, bulbs are not rated in wattage. Any D2S bulb will work with your stock ballasts.
Aftermarket bulbs suck, they are made of very bad materials and have bad light output. For yellow oem bulbs get Philips 85122+ and for white get Osram CBI. If not try Philips Ultinon. Then again my sticky in this section has all of that info.
Old 12-27-2012, 03:23 PM   #11
1hot325
My Ride: Bmw 325i
Thanks! And apologies for the extra posts
Old 01-03-2013, 09:57 PM   #12
1hot325
My Ride: Bmw 325i
Just wanted to say thanks for your advice I got the 6000k Philips and they look exactly like I wanted very much appreciated
Old 01-03-2013, 11:07 PM   #13
Solidjake
Zero. Leaks.
Solidjake's Avatar
Awesome!!!
