Old 02-13-2012, 07:59 PM   #1
EzTwitch
My Ride: 2002 325i
Rough Shifting
Hey guys,
I recently bought an 02 e46. Did most of the fluid swap myself but still having a rough time pinpointing what is the cause of my bad shifting. Was hoping that the transmission fluid (used Redline) will cure all problems but it hasn't.
Car is still experiencing, rough 1st-3rd gear, shifter poping out, reverse gear difficulty.
Would changing the clutch (bleeding the brakes?) help with this problem.
Any help or tips appreciated!
EzTwitch is offline   Reply With Quote
Old 02-14-2012, 03:01 PM   #2
jared_wiesner
My Ride: 1999 328i (M54b30)
Well it could possibly be shift linkage related, or I hate to say it, but sounds like it might be time to swap in a good used tranny.
jared_wiesner is offline   Reply With Quote
Old 02-14-2012, 03:04 PM   #3
jared_wiesner
Should have mentioned, look for a bent shift fork in terms of the linkage.
Otherwise its probably the syncros giving up and not properly locking it into second.
Old 02-14-2012, 03:06 PM   #4
Wayne's World
My Ride: 2005 325i Sport 5spd
I had this prob on a 98 318ti. It would pop out of 2nd violently and scare the shit out of me. Turned out it was the shift fork. Replaced and all was good.
Sent using BimmerDroid
Wayne's World is offline   Reply With Quote
Old 02-14-2012, 03:15 PM   #5
jared_wiesner
Have you noticed that it grinds or otherwise makes some bad noises if you pull the shifter around side to side in gear?
