Old 02-16-2012, 09:22 AM   #1
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee
Question When Can I change ATF fluid.
Before you rape the search button up mah bunghole just here me out.
I have to do a ATF change on my Daihatsu Terios WITHOUT DOING A FLUSH and just swap out as much as I can. Should I change the Fluid when its cold? or when its warm? When will there be less fluid in the Torque converter so I can just drain it out and Fill it up. The owners Manual says that a drain and fill takes 2 quarts and The transmission is so small that I don't think it even has a filter.
I know its not a BMW question but a general Transmission question.
1999 328i Sport Package, Premium Package, 5 speed, Alpine white.
RockLee is offline   Reply With Quote
