Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
Old 02-17-2012, 08:24 AM   #1
hoang031
My Ride: 01 325i
Dynavin Clone Review
unboxing video
closeup shot of the dynavin clone
finished install video
Image and video hosting by TinyPic
Detailed review
Review of usb/movie/backup-camera-feature/navi-music
some interesting things you should know:
1. iGo8 (on microsd) is set to port 1 but needs to be set to port 2 for gps to work properly. It doesn't save when you switch it but if you take the microsd and plug it into a computer, go find the gps settings file and change port=1 to port=2, it'll work
2. headunit will resume from where you left off. If you had radio on, itll turn radio back on. If you have ipod on, it'll turn ipod back on. Ipod will resume from where you last played.
3. LEDs that lightup the buttons are always turned on. They are not dependent on the headlight switch.
4. When using the iGo8 software, set the gps to port 2 (it's set to port 1) so you can start using it.
5. When synced with bluetooth, you can control your phone's pandora and music app. Your address book will sync.
6.Music is displayed song,artist,album. Displays 6 songs in playlist at a time, scrolling down thru the playlist is super fast.
7. You need to unscrew 2 screws located on the top of the unit to allow cds to enter into the cddrive. The screws are there to prevent anything from entering the drive before purchase.
Backup camera review
Ebay buyer/listing: http://www.ebay.com/itm/280821986752...84.m1439.l2649
Be very careful when buying your camera, there are 4 different types you could buy and they are:
1. sedan 2 wire
2. sedan 3 wire
3. coupe 2 wire
4. coupe 3 wire
I bought the sedan 3 wire- 1 power wire for license plate light, 1 power wire for backup camera and 1 video feed wire for backup camera.
If you have a sedan, I would recommend 2. If you have a coupe, I would recommend 4. Wiring is much easier and functionality is exactly as it should be i.e. license plate light turns on when you have your night lights on and backup camera turns on when you put it in reverse gear.
Easier way to wire backup camera-no need to splice to rear reverse lights
Reverse camera mount and wiring complete, pictures below.
Trunk without trunk lip
Trunk lip removed.
Removed right license plate light and housing
Hotglued the camera onto the back. Housing requires you to cut the back of the trunk lip license plate light housing since there's not enough room but I found that hot gluing it in place is adequate for mounting. Make sure you get a lot in the back but not enough that it comes out the front so it has a stock look.
Wiring is as follows for license plate light
power to gray/brown and negative to both brown/red and gray/yellow.
Hooking up everything for testing. I highly recommend you putting an in-line fuse on the ground when you ground it to the chassis. I probably will ground it to the trunk chassis exactly where I have it now after I route my wires through the grommel/tube on the rightside
yellow led matches my yellow light on the left side
The parking lot I was in is on a hill so it's curved, fyi.
A lot of you are wondering if you can easily modify the LED illuminations that are constantly turned on to be turned on only when you have the headlights turned on. I've found that you CANNOT do it.
Wire 13 (orange) is the illu., it goes from the e46 connector to the canbus control. When I removed the canbus control, the LEDs were still on. When I cut the orange wire, the LED was still on. I believe the LEDs are wired to the main dynavin clone accessory power and cannot be modified unless you open up the unit. Hope that clears up everything.
hoang031 is offline   Reply With Quote
Old 02-17-2012, 08:39 AM   #2
daki_bmw
My Ride: 330Ci
Hoang, thanks for everything. Maybe you should just add that it is WinCE version (Enco-B146).
daki_bmw is offline   Reply With Quote
Old 02-17-2012, 09:17 AM   #3
polishracing95
My Ride: 2000 323
i have been wondering if it has source out for a sub? and what is the site you ordered from?
polishracing95 is offline   Reply With Quote
Old 02-17-2012, 01:23 PM   #4
rellik
My Ride: is too slow...
Hoang.....Nice work. You say that you bought it from a Hong Kong reseller (rather than direct from manufacturer). What did you discover for purchase options? Reseller the best IYO?
02' Black Sapphire Metallic Dinan 330i
* Dinan TCAI * Dinan Stage III engine software, Tranny software, Throttle Body and Strut Bar * UUC TSE3 * ///M3 Steering wheel * ///M3 lip spoiler * UUC Slotted Rotors * KONI FSD's * 35% tint * OEM (ULO) clears * 5000k bulbs * NGK Iridiums * Stewart WP * Delmarco's Bluetooth retrofit * LED Angel Eyes * 3K HID Fogs * USA Spec * P3Cars Vent Gauge * Hotchkis Sport Suspension Sway Bars *
rellik is offline   Reply With Quote
Old 02-17-2012, 03:01 PM   #5
hoang031
My Ride: 01 325i
It does have a sub out rca. I got it on ebay.
He ships dhl it from hong kong to Penn, USA in 5 days (including weekends). Very responsive. I found that there are different wince versions of the gui. The most simplistic and nicest looking gui is that one that he's selling.
link is here. http://www.ebay.com/itm/290594709860...84.m1439.l2649
Old 02-17-2012, 03:22 PM   #6
rellik
Thanks again hoang. I thought I read that it (clone) has the OBC also like the Dynavin. Can you confirm and if so, how is it?
Old 02-17-2012, 03:37 PM   #7
hoang031
My Ride: 01 325i
I don't think it has OBC or ODB.
Old 02-17-2012, 07:41 PM   #8
Welke
My Ride: 2002 330ci
So the mic on the unit works? When i asked jolly she stated that i would have to buy a mic for the device because it didnt come with one.
Welke is offline   Reply With Quote
Old 02-17-2012, 08:03 PM   #9
hoang031
My Ride: 01 325i
Mine doesn't have an external mic port, only the internal mic located on the bottom left.
Old 02-17-2012, 08:04 PM   #10
mattrc51
My Ride: ///M3
The 4X50W maximum power output scare me. Would it work with the Harman Kardon package?
mattrc51 is offline   Reply With Quote
Old 02-17-2012, 08:04 PM   #11
Welke
My Ride: 2002 330ci
So is yours a different unit than the one from the site on the non eBay link above?
Old 02-17-2012, 08:16 PM   #12
bmwomgdj
Account Under Review
My Ride: M3 bmw e46
Support Harmon Kardon Premium sound system ???
bmwomgdj is offline   Reply With Quote
Old 02-18-2012, 01:42 AM   #13
hoang031
My Ride: 01 325i
I just made a call with the internal mic and they said it was like talking regularly on the phone. The over-the-air (ota) mic seemed to work really well. I just took a leap and bought a backup camera/license plate light for 29usd+free s/h. Hopefully I can get it installed by the end of the month. I plan on routing the ipod/auxin/usb/backup camera wiring through the center console tomorrow.
Old 02-18-2012, 04:22 AM   #14
hoang031
My Ride: 01 325i
The unit will come with 2 screws at the top of the unit. You need to remove these with a philips so that the CD can go into the CDplayer. The screws are there to prevent things from going in before they're shipped off.
Old 02-18-2012, 08:49 AM   #15
hoang031
My Ride: 01 325i
ebay seller is this guy if anyone wants.
FYI: the automatic turn-on backup camera function wire is cut when you get it. If you want to install a backup camera, you need to splice the 2 pink wires coming from the headunit to the canbus. This will enable the auto turn-on camera whenever you place your car into reverse gear. All functions are disabled and music is muted when you are in reverse. I do believe you can have the music turned on if you enable that in settings. But for the time being all the buttons are disabled when you go into reverse.
Old 02-18-2012, 09:42 AM   #16
tko200
My Ride: 01, 325i
Does this thing comes with a manual
tko200 is offline   Reply With Quote
Old 02-18-2012, 09:45 AM   #17
hoang031
My Ride: 01 325i
an operations manual but no install manual. Install is pretty straight forward.
Old 02-18-2012, 10:15 AM   #18
engtariq
My Ride: 2001 325i
Amazing info, thanks.
engtariq is offline   Reply With Quote
Old 02-18-2012, 04:11 PM   #19
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Wow! Awesome write up!
So this is the Dynavin's Dynavin?
Hoang can you do anything for that glare or is it not as bad as it looks?
delmarco is offline   Reply With Quote
Old 02-18-2012, 04:17 PM   #20
hoang031
My Ride: 01 325i
The glares not bad, I didn't remove the protective sticker over the lcd yet.
