Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 02-17-2012, 01:09 PM   #1
JOEG830
My Ride: '03 330xi
Re-Setting the Clock
I recently installed a new battery in my '03 330xi. All my settings were saved and restored without any problem.
My problem is that everytime I turn the car off and re-start, the clock goes back to --:-- and my tripometer also goes back to 0.
I have disconected and re-conected the battery and tried setting the clock with key in different possitons but nothing works.
Any suggestions?
JOEG830 is offline   Reply With Quote
Old 02-17-2012, 07:50 PM   #2
ImSoFreaknWhite
My Ride: '06 M3 SMG VERT
Send a message via ICQ to ImSoFreaknWhite Send a message via AIM to ImSoFreaknWhite Send a message via Yahoo to ImSoFreaknWhite
umm yes, dont post it in the "New member Introductions" thread.
Trying searching it...
Jordan
My Build Thread
l Status Gruppe One-Piece Lip l Anodized CCW Classics w/ Polished Lips l Black Grills/Gills & Emblems l Carbon Fiber Roundels
Status Rear Section l K&N 57 Series CA Intake l OEM JB Hardtop l TM Drilled/Slotted Rotors l D2 Coilovers w/Camber Plates l VIS CSL VERT Trunk
ImSoFreaknWhite is offline   Reply With Quote
Old 02-17-2012, 08:32 PM   #3
JOEG830
My Ride: '03 330xi
Totally new to this. Thanks for the info.
Old 02-17-2012, 09:24 PM   #4
wdc1959
My Ride: 2005 325ci
Setting the Clock
I posted this in response to a post on the difficult controls of this car and thanks to a fellow forum member for improving my instructions, here is my post with that addition in bold.
"I looked at the manual and tried every way I knew how to get the clock to set. The manual for the car directed me to the clock manual and the clock manual directed me to the car manual.
There are two clocks in this car (at least in my car) and the master clock is in the center of the instrument cluster. Set that clock and the radio clock is set.
Ignition off, key in position 1. You set the master clock by using the program stalk. Press that stalk in until the time (or if the clock has lost power --/--) shows up in the center of the instrument cluster then adjust the time using the button/knob sticking out of the cluster by turning it clockwise or counter clockwise as appropriate to get it to read the proper time (if memory serves me correctly it is the right button/knob: someone please correct me if I recall incorrectly, as it was two weeks ago I did this). Once the master time (the program time in the center cluster) is set, it is displayed only when you cycle through the program functions of the trip computer--however, the slave- radio clock-- which is on all the time-- is automatically set."
I'm new too- Welcome
wdc1959 is offline   Reply With Quote
Display Modes
