Old 02-18-2012, 06:06 PM   #1
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Building A New Custom 3" Exhaust, Quiet & Powerful !
As always, the quest for more WHP.
Right now I'm running the Magnaflow #16533, I really love this exhaust, but I'm going to try something different. My goal is simple: To have the quietest exhaust possible, but try to make race car like WHP; lofty goals I know.
Here's the plan: I'm going to start by coming off the headers with a Flowmaster #Y214300 http://www.summitracing.com/parts/FLO-Y214300/, this uses two 2.25" into a single 3" outlet. This will then go back a few feet using 3" tube to where the stock second resonator would normally sit. At that location it will feed into something like a Magnaflow #11219 http://www.magnaflow.com/02product/s...e=main&id=9311. Directly connected to the end of this 3" muffler/resonator will be a 3" exhaust cutout #SUM-670137 http://www.summitracing.com/parts/SUM-670137/, & of course an electric exhaust cutout will be mounted to it #SUM-670150-2 http://www.summitracing.com/parts/SUM-670150-2/. On the electric cutout side, I'll probably just come off it a few inches with a 3" tube & have it slightly turn down towards the road surface. On the other side of the cutout, (non electrical side) I'm going to reduce the 3" down to a 2.5" exhaust tube & continue back to the stock muffler location. At that point I'll install a Dynomax 2.5" turbo muffler #17749
http://www.dynomax.com/mufflers.php?muffler=superturbo, this muffer should be fairly quiet but still have reasonable flow.
So when the electric cutout is closed, I think this will provide a reasonably quiet exhaust sound, hopefully just a little louder than stock. If I still think it's not quiet enough, I'll install one of these Car Chemistry #3D125R 2.5" inserts http://www.summitracing.com/parts/CCI-3DI25R/.
When I open up the electric cutout, I figure all hell will break loose & it will make Maximum WHP. Time will tell, I of course will give this setup a before & after dyno. Your thoughts ?
Rob
Name:	Trick Exhaust.jpg
SUMMIT POINT WV 1:24:229 SCCA
Old 02-18-2012, 09:41 PM   #2
Iceman00
Banned User
My Ride: E90 6MT
LOL, love the drawing Rob.
Old 02-20-2012, 03:00 AM   #3
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
why put the cutout behind the 'muffler'? why not put it in front of it?
SL Blak Soldier is offline   Reply With Quote
Old 02-20-2012, 03:27 AM   #4
TiAg2247
My Ride: E39 M5 | E55 AMG
Awesome. I've been contemplating the same idea in my head using a Dynomax muffler for quietness. Do post clips when you are done. I'm very curious to see how these "quieter" Dynomax mufflers sound.
Imola Red M5 | Imola Red Interior
GT Exhaust, Custom BC Coilovers, 19x10 + 19x11 Rial Dayonta Race, Michelin PSS
Daily: 335i M-Sport Alpine White / Coral Red
Too many mods
Past:
'04 E55 AMG
'01 330Ci Titanium Silver / Coral Red
'96 328i Jet Black / Black
TiAg2247 is offline   Reply With Quote
Old 02-20-2012, 08:50 AM   #5
hassmaschine
My Ride: '91 325ix
replace the magnaflow with a borla, and you'll be onto something. :p
Also, why do a 3" exhaust to a 2.5" muffler? that doesn't make any sense. if you're doing 3", keep it *all* 3". reducing the size of the pipe isn't going to make any difference, except adding restriction where you don't want it. With good muffling full 3" isn't going to be loud. you have space to add another muffler or resonator, where a cat would be.. hell, even a high-flow cat really won't hurt.
I sort of agree with putting the cutout before the muffler - BUT - some tracks have noise limit restrictions. I dunno. I don't really see a huge benefit to the cutout on an N/A car anyway. Maybe put it in front of the muffler, and only use it when you can. Or ditch it because the weight and cost probably outweighs any benefits..
I have 3" exhaust, with a magnaflow ceramic cat (do NOT get a ceramic core cat! I wish I had a metal core one!), borla center muffler, and dynomax rear muffler. It's a tiny bit boomy at idle, but otherwise dead silent and it doesn't drone much at all (only really at like 1500rpm in 5th gear).
I'd much rather hear BMW intake noises, than exhaust noises...
btw, you're going to run out of space a LOT sooner than you think.
this article has a TON of good information, and was part of what convinced me to build a 3" exhaust:
http://www.superchevy.com/technical/...exh/index.html
this is an E30 M3, but still worth reading (and really, the same principles apply to almost any car/engine)
http://e30m3project.com/e30m3perform...haust/exh1.htm
I think you'll see why I say keep it full 3"...
hassmaschine is offline   Reply With Quote
Old 02-20-2012, 10:00 AM   #6
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I am going to have to look up the lengths of your mufflers. I'm worried it's still going to be too lout for you. I really think that if space/room isn't an issue, cutout should be closer to the motor, though.
Old 02-20-2012, 02:42 PM   #7
murph1379
My Ride: 2006 M3
The 3" Borla Pro XS is nice a quiet, but reduces to 2.5" internally, just FYI.
murph1379 is offline   Reply With Quote
Old 02-20-2012, 04:59 PM   #8
TrippinBimmer
My Ride: Just Fast!
NICE! I will be doing something similar...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 02-20-2012, 05:39 PM   #9
Bmw_fever
My Ride: 01' 325i ZSP ZCW
woo I wonder how it will sound with the cutout open!
Bmw_fever is offline   Reply With Quote
Old 02-20-2012, 05:46 PM   #10
Iceman00
Banned User
My Ride: E90 6MT
I'm building one myself in the next few weeks. Best place to get a nice 3in muffler with dual tips? Or can I buy the tips sperately?
Old 02-20-2012, 05:49 PM   #11
hassmaschine
My Ride: '91 325ix
I think vibrant has a 3" muffler with 2 tips
Old 02-20-2012, 05:55 PM   #12
aggieE46
Keep it clean
aggieE46's Avatar
Rob, check your PM.
Old 02-20-2012, 05:57 PM   #13
mvrk10256
My Ride: E30 325i
This is sort of what I have on the M50 e30. Just ebay headers, to a custom y pipe with flex, and then a 3" tube all the way back to a cheopo turbo muffler from summit. On teh stock tune, you can tell the engine lacks backpressure when its cold. Need to get to the dyno soon,.
Old 02-20-2012, 07:11 PM   #14
Rob43
Rob43's Avatar
I am trying to still keep the noise levels down a bit, but because of space limitations I may need to move the cutout forward to where the first stock muffler/resonator would sit & suffer with the extra loudness.
Also, why do a 3" exhaust to a 2.5" muffler? that doesn't make any sense. if you're doing 3", keep it *all* 3"...............
I sort of agree with putting the cutout before the muffler -...............
I was thinking it would be easier to mount a 2.5" tube & muffler, also a little more back pressure & quietness. I might just stay with 3" all the way back, still thinking about it. You may be correct, I may run out of space & have to install the cutout before the muffler/resonator.
Like already stated, you may be correct. I just wanted the muffler in front of cutout for noise reduction, I figured any flow loss wouldn't be measurable.
REALLY LOUD !
Rob, check your PM.
Got it.
Old 02-20-2012, 09:18 PM   #15
TrippinBimmer
My Ride: Just Fast!
Originally Posted by Rob43 View Post
Got it.
Are you DTB?
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 02-24-2012, 07:20 PM   #16
jblack03zhp
My Ride: 330i zhp
I really am digging your idea here. I was actually sitting in physics the other day contemplating the exact same idea! I have some experiences with cutouts. Had one on my silverado I built before the BMW and now on my jeep, wonderful things they are. Only difference in my plan, a Borla 3" in the mid and a magnaflow tipped muffler, 2.5" inlet, on the the end.
Out of experience I can notably say that you do not want the cutout before the muffler, especially if you do not plan to run cats after the long tube headers. There will not be sufficient back pressure and you will actually lose power. The plan, as is, is perfect. MAYBE go with a short first muffler. Other than that, you have an ideal system IMO
UUC Stage II Aluminum Flywheel/Perfomance Organic__UUC Evo 3 SSK & DSSR__UUC Underdrive Pulleys__Magnaflow__H&R Sport Cupkit__TMS Rear Camber Arms
__And tooo much other stuff
Originally Posted by Penguin Koolaid View Post
The difference being men don't make excuses to rationalize why it's okay. We do as we please. No fucks will be given. You ma'am, give a fuck.
jblack03zhp is offline   Reply With Quote
Old 02-27-2012, 10:37 AM   #17
yetieater
My Ride: '03 330i
In for results. Hope this project works out well for you.
bulletproof one piece at a time
full listing of BMW Performance parts for the E46
yetieater is offline   Reply With Quote
Old 03-03-2012, 08:20 PM   #18
DarkJoker
My Ride: 01 330ci
defiantly want to see the results as im currently brainstorming an exhaust ideas for future use
DarkJoker is offline   Reply With Quote
Old 03-05-2012, 10:37 AM   #19
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
This is what I did to get it quiet with low back pressure, just with no cut-out.
3" Magnaflow parts from Summit Racing:
Y Pipe #10778 = $27.36
18" long/9" wide Oval Muffler #11249 = $92.70 (straight thru for resonator)
18" long/8" wide Oval Muffler #12259 = $147.00 (offset for lower sound)
5.5" wide Oval Tip $114.28 (pricey for a small item)
Subtotal = $381.34 + freight
The 3" stainless tubing (5 ft) and hangers and installation will need to be added in and this came to about $500. Total is well under $1K - not bad when compared to the alternatives.
It is very quiet as it passes the critical test - my wife approves.
Jim
Jim Murphy is offline   Reply With Quote
Old 03-06-2012, 02:43 AM   #20
jblack03zhp
My Ride: 330i zhp
Got a good chuckle of that..
Do you happen to have any photos or video clips of this set up?
