#1 |
Brake Booster Hose Removal on 330ci
I need to replace the brake booster hose on my son's 330ci. The hose is collapsed and the vacuum seems to have pulled the sidewalls toward the inside. How do you remove the hose from the booster? Do I need to replace the valve also? See diagram below.Thanks.
http://www.realoem.com/bmw/diagrams/y/j/126.png |
#2 |
My Ride: '06 330CiC, '03 M5
This is a common problem that I have seen, however, I personally have never had to change one.
Looking at the parts diagram, it appears the hose is sold separately. If so, you could just replace the hose. The vacuum check valve probably pulls straight out of the rubber grommet in the booster? If the hose has the OEM clamps, I usually use side cutters and just cut the clamp then remove it. I would probably then use a utility knife to slit the hose to make removal easier. If you want to buy the OEM clamps, I use the side cutters to carefully pinch the new clamp close, but it usually is just easier to use standard worm drive hose clamps as a replacement.
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
#4 |
I need to remove 7 from 5 and then the other end of the hose that is not shown to what it attaches to. I can cut the OEM clamps off and buy new but how do you crimp these clamps to close. I am wondering if the valve is bad adding to why the hose is collapsing. Thanks for the replies.
#5 |
Hose collapsing has nothing to do with the brake booster check valve. Gasoline vapors, high temps, age and tight bends is what causes the hose to fail.
As for the OEM clamps, you can either buy a special tool of just use side cutters to pinch the clamps tight.
#7 |
Thanks for the replies. I will just buy a new hose and standard hose clamps that tighten with a screwdriver or ratchet . If this does not work, I can just loosen the clamp and change the valve.
#8 |
I replaced the brake booster hose today. I used the www.furiousmethod site to research the part for the best price. This search engine is a great tool to save some money. I ended up getting it online from the BMW store in Cincinnati. I arrived in 1 day. The hardest part was taking off the factory hose clamps. I was able to just pull hard on the brake booster end and the hose came out. On the other end that goes down by the engine you cannot pull it out. I had to twist the hose to expose the end of the clamp and pryed it off with a screwdriver. Replacing was much easier than removing the old one. I used regular clamps that you can tighten with a screwdriver when installing.
#10 |
#11 |
So the piece that the hose connects to on the engine side, is that suppose to come off? I took the clamp off but when I pulled the 'piece' came with it. When I re installed the hose it doesn't really 'snap' in or anything, just sits there. It doesn't fall off and gets snug once vacuum pressure is there, is that piece broken or is it OK? Should I put some silicone sealant around it?
My Flickr! Blog! Follow Me!! **Some people are like slinkies, they are not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs** |
