Old 02-20-2012, 11:39 AM   #1
cyberlando
My Ride: 2002 M3
Post BRake pad advice UUC?
i bought some new slotted drilled rotors from uuc and I want to put them on today but i didnt buy pads.
pads confuse me...i lie to you not they have some many different combinations of them
all i want is a pad that has great stopping power without the over kill of dust!
should i go ceramic semi metallic...???
and if possible is it safe to say i can get good quality pads from autozone or advanced auto?
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
cyberlando is offline   Reply With Quote
Old 02-20-2012, 12:27 PM   #2
lcoleman
My Ride: '79 Massey Ferguson
If you track, then no, it isn't possible. if you just drive around, any ceramic from any of the reputable manufacturers will be fine. I've used Akebono and Hawk with great success personally.
Drilled/slotted won't really do anything but chew up your pads faster.
Old 02-20-2012, 01:24 PM   #3
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
+1
Drilled & slotted rotors are for track running where heat buildup is a problem and the pads are going to wear very quickly anyway.
Jim
Jim Murphy is offline   Reply With Quote
Old 02-20-2012, 01:27 PM   #4
Jim Murphy
Also, Bavarian Autosport (www.bavauto.com) has a good guideline for their different brake pads that they offer.
Jim
Old 02-20-2012, 02:24 PM   #5
invictus
My Ride: M3 (F80 & E46), S3R
it's one of those iron triangle situations.
CCW. Dunlop. Ground Control. StopTech. Hawk. Vorschlag. Rogue Engineering. Recaro. TCDesign. RaceTech. VAC. Motul. Vorsteiner.
Find me on track: 10/19-21 Sonoma Speedway // 11/10-11 Thunderhill
The story so far...
Fund my track car:
PM me about my: stock diffuser, stock trunk, e46 m3 part out
invictus is offline   Reply With Quote
advice, brake, brake pads
