#1 |
both AC and Heater makes engine sound
They make sound when I turn on the AC or heather. The sound is like the engine sound. It's like there is a second mini engine in the hood and following the main engine sound. I hope I described it well. BTW, heather heats and AC cools well.
#2 |
like this sound
Noise coming from the AC system while compressor is ON. It ends ~1 sec after pressing the AC OFF button. It increases in intensity along with the engine RPMs. Last edited by eerener; 11-08-2012 at 07:26 PM. |
#3 |
No idea? anyone?
#4 |
Compressor on the way out maybe?
#5 |
it is a $1000 part, I don't know if it is worth to replace
#6 |
Read the description of the YT video. It posts a TIS link about this:
http://tis.spaghetticoder.org/s/view.pl?1/08/53/13
#7 |
Good find, im sure thats a fraction of the price of a compressor
#8 |
Here is a remanufactured compressor. Not as expensive as i thought. http://item.mobileweb.ebay.com/viewi...142&cmd=VIDESC
#9 |
Registered Gadfly
If I read the opening post correctly, this noise also happens when the heater is on and the AC off. That doesn't jive with a compressor problem.
Engineers do it with a torque wrench
#10 | |
How can it causes this noise? Is it clogged? |
#11 |
Straight from that TIS:
Cause: The vibrations of the engine are transmitted into the vehicle interior through the intake pipe of the air-conditioning compressor. Honestly, if it happens with A/C on, I would tend to suspect the compressor as well. not sure about the heater, unless you're doing something with an automatic setting where the heat turns on the compressor as well. I turned up this thread searching that part #, too: http://www.e46fanatics.com/forum/sho...d.php?t=513153 Good luck.
#12 |
Thanks a lot everybody.
#13 |
No problem, post back and let us know! Do not buy an oem compressor you will get butt raped! Fcp euro ftw
