Old 02-20-2012, 11:51 PM   #1
katu
My Ride: '04 330ci ZHP
Angry 3.07 -> 3.46 Diff, Different Axle Flanges!?
I bought a 3.46 diff out of a 325i auto and am aware of having to swap the input flanges to match up to my 330.
However, my axle flanges are not matching up. Photos below:
3.07 (my original diff):
3.46 (new diff):
As you can see the 6 bolt pattern does not match up, what is the easiest way to swap these?
katu is offline   Reply With Quote
Old 02-20-2012, 11:52 PM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
buy different axles?
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 02-20-2012, 11:57 PM   #3
TX78666
My Ride: 330i ZHP, N55 135i
You can use the flanges off the old diff. Just be careful when you swap them. If you don't preload the bearings properly, they will go bad in 6,000 miles. I can't give you any more guidance than that, but Dan at diffsonline can, or you might be able to Google it and find a DIY for swapping the flanges properly.
Because... Grocery Getter.
TX78666 is offline   Reply With Quote
Old 02-21-2012, 12:04 AM   #4
katu
Looks like with some pry bars and some force it does pop out pretty easy. Updates on the 3.46 to follow!
Old 02-21-2012, 12:07 AM   #5
TX78666
Poppng it out is easy. Popping it in, the right way, is easy to screw up, at your peril. Seriously. If those bearings fail, you'll be replacing the diff.
Old 02-21-2012, 12:11 AM   #6
TX78666
Really. Seriously. Do some reading, or you'll be on here asking about a howling rear end in 6,000 miles, and you will not like the answer.
http://forum.e46fanatics.com/showthread.php?t=901282
Old 02-21-2012, 12:21 AM   #7
lab rat
My Ride: '02 330iT
The output flanges are easy to swap. The input flange is PITA.
Because sleeper.
Old 02-21-2012, 12:25 AM   #8
katu
TX78666 it sounds like you're talking about the input flange? I don't think you have to do any sort of preloading on the output flanges...
Old 02-21-2012, 12:52 AM   #9
TX78666
Could be. It's late, and I didn't do the swap on mine. The shop that did it, ended up eating the cost of another diff. If I had screwed it up, I would have paid more attention to what went wrong. :-)
Old 02-21-2012, 01:04 PM   #10
Alex323Ci
My Ride: M3 & 323Ci (sold)
Yes your 330 has beefier axles and different output flanges.
You just pop them out and swap. The INPUT flange is the tricky one.
OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK
CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF
Old 02-21-2012, 04:01 PM   #11
katu
Just an update, was at the shop until 1am but the diff is installed with no leaks! The difference is definitely noticeable! Considering I got the diff for $220 shipped this mod is worth it for sure! Wish it was LSD though, maybe down the road.
Old 02-21-2012, 06:07 PM   #12
katu
Alex you are like the diff guru, thanks for all the help!
