E46 Xi Forum
Old 06-13-2012, 12:40 AM   #41
john311tran
My Ride: awd + 5 doors
thanks edwagon.
rickna, i only need rear shocks and springs. when replacing do i need to replace all 4 if i'm going oem? i assume i need to do all 4 if i get koni and ebauchs for the rear.
john
john311tran is offline   Reply With Quote
Old 06-13-2012, 10:24 AM   #42
SamDoe1
My Ride: 4cyl of fury
Originally Posted by john311tran View Post
thanks edwagon.
john
If you are replacing OEM with OEM, you can do just two. But remember that now your rears are going to be stiffer than the fronts and you'll just want to change them out anyway.
Old 06-13-2012, 10:29 AM   #43
Rickna
My Ride: '01 330xi - '09 IS-F
^What Sam said.^
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 06-13-2012, 01:42 PM   #44
EDWAGON
My Ride: 2004 325xiT
Here is the list recommended by Pelican for 2004 325XI Wagon OEM shocks,struts,springs,parts:
31-31-6-759-647-M9 Strut, Left Front
31-31-6-759-648-M9 Strut, Right Front
31-33-1-091-867-M269 Upper Front Spring Pad, 2 Per Car
31-33-1-096-664-M269 Lower Front Spring Pad 2 per car
31-33-6-760-943-M69 GUIDE SUPPORT 2 per car
31331093084-BOE : BMW OEM Part 2 per car- springs
33536750760-BOE : BMW OEM Part 2 per car - springs
33-52-6-752-506-M10 Shock Absorber, Rear- 2 per car
33-53-1-136-385-M9 Spring Pad 5 mm 2 per car
33-53-1-094-518-M9 Spring Pad, Rear Lower - 2 per car
33-52-1-092-362-M810 Upper Rear Shock Mount x 2
07-11-9-904-295-M58 Collar Nut, 8 mm (Locking) x 4
33-52-6-772-864-M30 Gasket, for Rear Upper Shock Mount to Body x 2
33536753520-BOE Genuine BMW Part: Additional Shock Absorber, Rear x 2
EDWAGON is offline   Reply With Quote
Old 06-13-2012, 04:51 PM   #45
jasonbimmer
My Ride: 2001 BMW 330xi
get stock shocks.
I went for Bilstein Sport, they are very bouncy when the road is rough.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 06-13-2012, 09:37 PM   #46
john311tran
thanks ed. where can i find a 2003 xit list? i'de rather not do all 4. but i can see how it makes sense... i love my car, but sometimes i wish i got a honda civic for commuting (i drive a on ton of miles) and saved up for an m3 for my weekend driver.
john
Old 06-14-2012, 03:49 PM   #47
EDWAGON
I am sure they will all appy to your car just double check with realoem.com
Old 06-14-2012, 04:43 PM   #48
Rickna
john
Sensible, but could you resist the temptation of the M3...
2001 BMW 330xi
2009 Lexus IS-F
Old 06-20-2012, 08:27 AM   #49
EDWAGON
Hey John I just had some work done( rt cv axle again) and found out my front struts are leaking. I may go with eibach springs and konis or oem. Just still reading and figuring it out.
Old 06-20-2012, 11:37 AM   #50
EDWAGON
I think I'm leaning towards oem and eibach to lower 1 inch all around on my wagon. I think that will keep ride comfortable I hope.
Old 06-20-2012, 12:07 PM   #51
SamDoe1
^ The springs make much more of a difference in terms of comfort than the shocks/struts do. You might as well go aftermarket with the shocks as well since it'll be cheaper.
Old 06-20-2012, 12:51 PM   #52
EDWAGON
Sam what brand shocks,struts you think?
Old 06-20-2012, 01:34 PM   #53
SamDoe1
I personally have Konis. I can vouch for them being great in terms of both reliability and ride quality but can't vouch for other brands. I know certain Bilstein models are prone to leaking but I can't speak to their overall reliability.
Old 06-20-2012, 05:54 PM   #54
EDWAGON
I called tire rack and they said they don't have koni or eibachs that fit the 325xiT??? Any suggestions on where to find them for my wagon? I think the guy on the phone is wrong but their website didn't provide options either for my ride.
Going to call manufacturers and see what they say.
Old 06-20-2012, 06:09 PM   #55
SamDoe1
I'm fairly certain that it's the same as a sedan...the front for sure is.
Old 06-20-2012, 09:09 PM   #56
EDWAGON
I was able to sort it out on Koni and eibachs websites. What additional hardware do I need? Tks
Old 06-20-2012, 09:56 PM   #57
e36-2.0
My Ride: 330xi
will be swapping out my Koni adjustable/H&R xi setup next month if anyones intersted
'02 330xi
Konigsport/Ground Control/DPE/BMW Motorsport/Eurosport/Turner Motorsport/PowerFlex/RacingDynamics/Hotchkis/UUC/Beisan/Bimmerworld/Dinan/Conforti/RPI/GroupN/Technik/Dynavin
Alberta's BMW enthusiast forum.
-Projecttechnik.com
e36-2.0 is offline   Reply With Quote
Old 08-15-2012, 04:58 PM   #58
john311tran
hey ed and folks,
from the last few reads it sounds like the koni springs and shocks will give me a more comfortable ride than the oem ones? i personally don't care about ride height. in fact, i'de rather be higher than lower since i do a ton of commuting and tons of winter commuting. the extra clearance will always help.
i'm going to switch out the front and rears. the fronts have 98k on them now and are most likely going to go in 1-2 years anyways. time is money and i'de rather do it all now.
i'm hearing so much about so many different combo's i don't really know what to do. i've read, i've read again and i've reread and it seems everyone says something different.
things i'm looking for:
quality handling (oem or better)
comfort (oem or better)
durability (i'm willing to sacrifice comfort but not handling for durability)
welcome to more suggestions.
also: what other parts do ya'll suggest replacing. i'm sure it's more than just springs and struts. i'm sure all the little things here and there should be changed as well.
bests,
john
Old 08-15-2012, 05:03 PM   #59
john311tran
actually answered some questions when i re-read the thread (ding ding).
time is money right now. in the next 4 months i have 2 half ironmans, 2 marathons, a half marathon, a 24 hour 200 mile relay race, a 5k and a 10k race...
anyone have an estimate on what shop prices (local garage) will cost for labor?
john
Old 08-15-2012, 05:20 PM   #60
SamDoe1
time is money right now. in the next 4 months i have 2 half ironmans, 2 marathons, a half marathon, a 24 hour 200 mile relay race, a 5k and a 10k race... anyone have an estimate on what shop prices (local garage) will cost for labor?
john
Just fix your car and you can drive all of that distance instead of running it.
