E46 Xi Forum
Old 08-22-2012, 09:56 PM   #81
john311tran
My Ride: awd + 5 doors
also: http://www.ecstuning.com/BMW-E46-325...rame/ES128604/ will this fit on my touring?
john311tran is offline   Reply With Quote
Old 08-22-2012, 10:56 PM   #82
SamDoe1
My Ride: 4cyl of fury
Originally Posted by john311tran View Post
i talked to my mechanic today. really trustworthy local guy and always takes care of me if i don't have time to do the work myself. he quoted me 150 for the fronts and 75 for the rears to do all shocks, struts etc. he said to take the car to townfair near us because they have a 150k machine and the guys at that shop are not nitwits like the other townfairs..
thoughts on 225 for labor for 4 shocks? i'm guessing it'll take me a full day to do all 4. first time with this car. not to mention the springs are a pain in the rear to compress without the machine.
john
$225 to install everything is a steal, I'd do it if you trust the guy.
where are you guys going to buy koni shocks and ebauch springs? i'm not finding them on tire rack or pelican
Tire Rack has everything you need for Koni and Eibach, check that place out.
http://www.ecstuning.com/BMW-E46-325...Kits/ES252806/
can anyone tell me the diff between this set and a ebauch spring with koni shocks? ride quality etc? there really needs to be an informative thread about this stuff once and for all and have it stickied!
john
This has been discussed 7 billion times, maybe even in this thread. H&R springs will have a more harsh ride than Eibach. Shocks and struts do not factor into ride quality that much. Difference between Bilstein and Koni is adjustable vs non adjustable and cost.
Please search for such routine questions.
Based on the application guide, no. The under body panels on RWD and AWD cars are different therefore this should not fit all E46 cars anyway.
Old 08-22-2012, 11:25 PM   #83
john311tran
sam,
can you help me find suspension for a touring on tire rack. i'm not sure what i'm doing wrong, but i'm not finding it. 03 325xiT.
why would it not fit on an xi. ecs tuning lists that it's for a 325xi = awd. i just was wondering if it works with xiT or if i need a diff one for a touring.
john
Old 08-23-2012, 10:09 AM   #84
SamDoe1
sam,
john
Just put it in as a regular Xi sedan and the parts will show up. If you go to Koni's website, it lists the shocks and struts as compatible across both sedan and touring. I'm not sure why tire rack doesn't list that...
It won't fit the Xi because the Xi underbody panels are completely different from the non-Xi panels. There's no way they can fit both cars therefore I'm assuming it will fit the RWD and not the Xi. Also, there doesn't appear to be a channel for the axle to go through either.
Old 08-23-2012, 05:36 PM   #85
Rickna
My Ride: '01 330xi - '09 IS-F
Eibachs you can find almost anywhere. The same for the Konis.
http://www.koni-na.com/
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 08-23-2012, 06:06 PM   #86
Dreamliner330
My Ride: 330xi
sam,
john
Simply follow my thorough parts list in my sig. :cool:
Dreamliner330 is offline   Reply With Quote
Old 08-23-2012, 08:50 PM   #87
john311tran
sam,
i'm still confused about the plate not fitting. the link i sent you says it's for a 325xi yet you say it won't work for xi? is something else showing up?
dreamliner,
great! too bad link doesn't work..
john
Old 08-23-2012, 10:22 PM   #88
SamDoe1
sam,
john
The application guide is wrong. Just like it is for Tire Rack telling you the Konis won't fit on your touring.
Old 08-23-2012, 10:25 PM   #89
ShootyzGruve
My Ride: 2003 325i
Originally Posted by SamDoe1 View Post
You have reached the Xi forum, unfortunately we are away right now but would like to remind you that your suspension is entirely different from ours and our opinions and experiences will not reflect the results that you would get. Please try the general forum for your RWD suspension questions. Leave a message after the beep.
All kidding aside, yes Sachs is the OE manufacturer. I don't think it's available in a kit. You can buy the parts individually, there aren't that many of them.
Sachs shocks are not bad at all if you're not looking to lower.
Sam,
Thanks for the insight. I was on mobile and totally didn't realize this was the xi forum. Sorry for polluting with RWD content.
Cheers
ShootyzGruve is offline   Reply With Quote
Old 08-24-2012, 04:46 AM   #90
Kubica
My Ride: 2003 325xi
Which rear suspension parts are different on a wagon, do you know? Swaybar?
Old 08-24-2012, 09:38 AM   #91
SamDoe1
Sway bar is the same on all Xi's and the convertible. Looks like the OE shock has a different PN though...but I'm guessing that has more to do with valving for extra load carrying than the actual dimensions since the upper and lower shock mounting components are the same.
Old 08-24-2012, 05:12 PM   #92
john311tran
on another note.
anyone think a xi wagon 325 can tow a 16 foot fiberglass boat with a 2 stroke 90hp mercury?
john
Old 08-24-2012, 05:19 PM   #93
e46alfonso
My Ride: 330xi MT, mustang gt
^ no it can't. It can barely push its own weight.
Old 08-24-2012, 05:52 PM   #94
john311tran
that's what i thought. i was trying to explain to a patient of mine that the wagon couldn't handle it and he was pretty confident that it could. i guess i could always check the towing capacity and the weight of the boat. but figured this was easier.
john
Old 08-31-2012, 05:24 PM   #95
john311tran
hey folks,
so i'm real real close to ordering but i have a few more questions.
1)http://www.pelicanparts.com/BMW/cata...pg4.htm#item18
are the oem strut mounts really worth FIVE times as much as the aftermarket ones? i mean damn, that's another 230 bucks i didn't plan for.
2) i'm ordering:
KONI Adjustable Front / Rear Shocks/Struts BMW E46 sedan / coupe
SKU # : bmw-e46-shocks003
Front Shocks : E46 325xi / 330xi Sedan / Touring (8741-1481LSPORT)(8741-1481RSPORT)
Rear Shocks : E46 325xi / 330xi Sedan / Touring (8040-1343SPORT)
and Eibach Pro-Kit Springs for BMW E46 3-Series / M3
SKU # : bmw-e46-springs001
Vehicle Model : 325xi, 330xi sedan 6cyl. (2089.140)
i was told that the springs are good for the touring as well (eibach site doesn't show any springs for the touring). can i order oem spring pads and they should fit fine or do the eibachs come with their own spring pads.
3) do i need guide supports and new locking collar nuts?
4) do koni's make non adjustables that people were referring to? none of the sites, (tire rack, modbargains) had them.
i guess that's it. my car is back from the shop next week and i want to install the new suspension asap. driving anymore on the busted rear strut can't be good for the car.
thanks everyone.
also, i plan on getting 17's or 18's for this eventually. shouldn't have any problems right? i'll probably get the wheels and get it aligned all together.
Old 08-31-2012, 05:42 PM   #96
Kubica
My Ride: 2003 325xi
^ you didn't even order parts yet?
You're looking at m3 strut mounts. No, springs pads aren't included and usually not necessary. Nuts come with struts. Need new strut pinch bolts, rear shock mounts, and gaskets.
Old 08-31-2012, 05:49 PM   #97
john311tran
haven't had to. the car has been in the shop and i've been swamped with work. i know excuses, excuses. i'm full of them. having a spare care is nice because i don't have to rush things.
i'm looking at 897 (free shipping) then minus 25 bucks for labor day sale at mod bargains. anyone know of a better price for the combo (i'de rather order all from the same place).
otherwise i'm good to go right? ugh, i might save the 275 bucks and install them myself. we'll see how long i can drive the spare car for (90 accord with 280k miles)
john
Old 08-31-2012, 05:55 PM   #98
john311tran
is there another name for strut pinch bolts? can't find them on pelican parts.
john
Old 08-31-2012, 06:14 PM   #99
Rickna
john
M12X1,5X60-10.9
Part # 31356778832
2001 BMW 330xi
2009 Lexus IS-F
Old 08-31-2012, 06:19 PM   #100
john311tran
thanks rick..
just read up on kubica's thread on end links and how he replaces every 2.5 years (seems extreme to me) but i'm at 10 years and 98k. i really can't be under my car much next spring/summer as i have 2 really big races in the fall that i'll be busy training for (ironman wisconson and ironman cozumel back to back).
does anyone suggest changing anything else while i'm here? the car has 98k miles and i live in boston. these roads SUCK. i'm thinking about doing my end links while i'm here (front and rear) what about sway bar bushings, control arm bushings etc?
money is tight, but time is tighter. i'de rather be under my car once while i have the whole suspension gutted.
john
