Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Parting Out
Parting Out
Parting out your car? Post your entire list of BMW parts for sale in one forum. Single items should be posted in one of the other classified forums.
Old 02-22-2012, 02:16 PM   #1
Quivers
My Ride: E70 X5
E46 M3 partout, I cant edit the old thread
I could not edit my last post for some reason so I am making a new one. This is an updated inventory list. This list is not yet complete and I have an entire M3 left to strip.
I have stripped several harnesses and saved the pigtails, I also have hardware saved and organized.
Location- Plainfield, IL
Name- Dan Rivers
contact number-630-957-8798 text or call
Email DanRiversJr@gmail.com
Paypal Haidiux@hotmail.com
Local pick up is available otherwise I will ship anything to 48 states and most parts worldwide.
Description OEM Part # Unit Price Shipping
ALTERNATIVE POWER SIREN 65758383153 $60.00 $10.00
SUBWOOFERBOX TOP-HIFI SYSTEM 65106920857 $100.00 $10.00
TOP-HIFI SYSTEM WOOFER 65138368244 $30.00 $10.00
TWEETER/MID-RANGE LOUDSPEAKER TOP-HIFI 65138374698 $60.00 $10.00
TOP-HIFI MID-RANGE LOUDSPEAKER 65138368245 $30.00 $10.00
LOUDSPEAKER RECESS REAR LEFT 65138380565 $10.00 $10.00
LOUDSPEAKER RECESS REAR RIGHT 65138380566 $10.00 $10.00
AMPLIFIER HIFI HARMAN KARDON 65126920594 $100.00 $10.00
RADIO BMW BUSINESS 65126988275 $100.00 $10.00
RADIO BMW BUSINESS CD 65126921963 $200.00 $15.00
NAVIGATION COMPUTOR 65906920182 $500.00 $20.00
GPS ANTENNA 65908374297 $40.00 $10.00
AMPLIFIER 65256906075 $15.00 $5.00
ON-BOARD MONITOR WITH DISPLAY 65526934410 $400.00 $30.00
DOOR FRONT RIGHT 41517038092 $180.00 $100.00
DOOR FRONT LEFT 41517038091 $180.00 $100.00
TRUNK LID 41627065260 $150.00 $100.00
TRUNK LID 41627065260 $250.00 $100.00
SIDE PANEL, FRONT LEFT 41357894337 $250.00 $100.00
BRAKE MASTER CYLINDER 34317838638 $100.00 $20.00
BRAKE MASTER CYLINDER 34312282343 $100.00 $20.00
HYDRO UNIT DSC 34512229827 $150.00 $10.00
HYDRO UNIT DSC 34512282558 $150.00 $10.00
BRAKE SERVO UNIT 34332282622 $100.00 $20.00
BRAKE SERVO UNIT 34332282193 $100.00 $20.00
CALIPER REAR LEFT 34212282195 $50.00 $10.00
CALIPER REAR RIGHT 34212282196 $50.00 $10.00
CALIPER FRONT LEFT 34112282175 $50.00 $10.00
CALIPER FRONT RIGHT 34112282176 $50.00 $10.00
COMPRESSOR DSC 34511166087 $50.00 $10.00
HANDBRAKE LEVER LEATHER BLACK 34411164489 $25.00 $10.00
LEATHER HANDBRAKE LEVER COVER 34408227928 $15.00 $10.00
SMG HYDRAULIC UNIT 21532229715 $850.00 $25.00
OUTPUT CYLINDER,CLUTCH SMG 21522229841 $120.00 $10.00
CLUTCH KIT 21212282667 $80.00 $20.00
CLUTCH REL.FORK LEVER 21511223302 $10.00 $8.00
DRIVESHAFT 26112229240 $150.00 $40.00
RETURN PIPE 11537831528 $30.00 $10.00
WATER PUMP 11517838159 $100.00 $10.00
THERMOSTAT HOUSING 11537831103 $100.00 $10.00
VALVE "AIRPUMP" 11727830680 $40.00 $10.00
FAN COUPLING 11527831619 $25.00 $10.00
INLET CAMSHAFT 11317832194 $200.00 $20.00
CAMSHAFT EXHAUST 11317832195 $200.00 $20.00
TIMING CHAIN 11317830869 $40.00 $10.00
CHAIN TENSIONER 11311404438 $40.00 $10.00
CHAIN TENSIONER-TWIN CHAIN 11317830557 $15.00 $10.00
VIBRATION DAMPER 11237830475 $100.00 $15.00
COMPLETE HYDRAULIC BELT TENSIONER 11281722789 $35.00 $10.00
OIL FILTER HOUSING 11427833240 $160.00 $50.00
COVER IGNITION COIL 11127831253 $100.00 $15.00
AIR DUCT 11617830356 $20.00 $10.00
EXHAUST MANIFOLD WITH CATALYST 1-3 11627832063 $350.00 $50.00
EXHAUST MANIFOLD WITH CATALYST 4-6 11627832064 $350.00 $50.00
PROTECTIVE COVER "EXHAUST MANIFOLD" 11627831352 $25.00 $10.00
PRESSURE ACCUMULATOR VANOS 11367831323 $40.00 $10.00
AIR COLLECTOR SMG UP TO 10/04 11617830729 $130.00 $20.00
VIBRATION ABSORBER 23002282310 $50.00 $10.00
WIRING HARNESS, ENGINE IGNITION MODULE 12517831537 $90.00 $10.00
ENGINE WIRING HARNESS, ENGINE MODULE 12517831646 $150.00 $10.00
WIRING HARNESS, ENGINE TRANS. MODULE 12517831659 $100.00 $10.00
WIRING HARNESS, ENGINE TRANS. MODULE 12517831756 $100.00 $10.00
THROTTLE ACTUATOR 13627840537 $120.00 $10.00
STARTER MOTOR 12417835735 $45.00 $10.00
AT-COMPACT ALTERNATOR 12317831436 $100.00 $20.00
IGNITION COIL 12131712219 $20.00 $5.00
ENGINE DME WBSBL934X2JR14717 7833284 $300.00 $20.00
ENGINE DME WBSBL93443JR22295 7833892 $300.00 $20.00
ENGINE DME WBSBL93463JR22007 7833892 $300.00 $20.00
TOOL BOX 71111094903 $25.00 $10.00
CRANK 71121179953 $10.00 $10.00
TOWING HINGE 72158266616 $10.00 $5.00
SCREWDRIVER 71111179629 $3.00 $5.00
WATER PUMP PLIERS 71111179522 $10.00 $10.00
OPEN END SPANNER 71111126148 $5.00 $5.00
OPEN END SPANNER 71111112893 $5.00 $5.00
HEX KEY $5.00 $5.00
M-MOBILITY SYSTEM 71102229700 $50.00 $15.00
REAR MUFFLER 18107831783 $150.00 $100.00
INTERMEDIATE PIPE 18107832313 $150.00 $50.00
EXHAUST SYSTEM, FRONT 18107832909 $150.00 $60.00
RUBBER MOUNTING "EXHAUST" LARGE 18201401797 $15.00 $10.00
CONNECTING SUPPORT "EXHAUST" 18211436309 $10.00 $10.00
RUBBER MOUNTING "EXHAUST" SMALL 18207832991 $10.00 $10.00
PULSE GENERATOR, ABS FRONT UP TO 9/02 34521164651 $15.00 $5.00
KING PIN LEFT FRONT 31212229855 $100.00 $20.00
KING PIN RIGHT FRONT 31212229856 $100.00 $20.00
WISHBONE, LEFT FRONT 31122229453 $100.00 $20.00
WISHBONE, RIGHT FRONT 31122229454 $100.00 $20.00
STABILIZER, FRONT 31352229755 $90.00 $20.00
LEFT FRONT SPRING STRUT 31312283103 $130.00 $20.00
FRONT RIGHT SPRING STRUT 31312283104 $130.00 $20.00
T-SHAPE IDLE REGULATING VALVE 13411733090 $100.00 $10.00
INDIVIDUAL THROTTLE BODIES $400.00 $20.00
ADDITIONAL AIR LINE 13547831481 $30.00 $10.00
INJECTION VALVE 13647830975 $40.00 $5.00
HOUSING, PRESSURE REGULATOR 13537830368 $50.00 $10.00
INJECTION PIPE 13537830974 $25.00 $10.00
HOT-FILM AIR MASS METER 13627839014 $100.00 $10.00
INTAKE MUFFLER 13717839015 $200.00 $20.00
INTAKE MUFFLER LID ONLY 13717839015 $40.00 $10.00
INTAKE TUBE 13717830101 $10.00 $10.00
SUCTION HOOD 13717830100 $40.00 $10.00
ACTIVATED CHARCOAL FILTER 16136751759 $60.00 $20.00
SHIFT LEVER 25117527255 $30.00 $10.00
SHIFT LEVER KNOB, LEATHER, SEQU M-TRANS 25162282210 $40.00 $10.00
GEAR SHIFTING STEPTRONIC, SMG 25162282123 $60.00 $10.00
LEATHER GEAR LEVER COVER 25167904014 $25.00 $10.00
WATER VALVE WITH ADDITIONAL WATER PUMP 64118369807 $50.00 $10.00
COMPRESSOR SUPPORT BRACKET 64551432237 $25.00 $10.00
CONTROL UNIT, AUTOMATIC AIR COND.,AUC 64116956319 $50.00 $10.00
FRESH AIR GRILLE CENTER 64228361895 $40.00 $10.00
FRESH AIR GRILLE, LEFT 64228361897 $20.00 $10.00
FRESH AIR GRILLE, RIGHT 64228361898 $20.00 $10.00
HOUSING F HEATER/AIR CONDIT.UNIT 64118372792 $150.00 $50.00
RIGHT FLOOR HEATER DUCT 64228203882 $10.00 $10.00
LEFT FLOOR HEATER DUCT 64228203881 $10.00 $10.00
CONDENSER AIR CONDITIONING 64538377614 $80.00 $25.00
AIR-CONDITIONER COMPRESSOR 64526910458 $120.00 $25.00
INTERIOR READING LIGHT FRONT 63316962046 $15.00 $10.00
CHARGEABLE HAND LAMP 63318377861 $15.00 $5.00
INTERIOR READING LIGHT REAR LEFT 63316962049 $10.00 $10.00
INTERIOR READING LIGHT, REAR RIGHT 63316962050 $10.00 $20.00
HIGH BEAM COVER 63128384492 $10.00 $5.00
LOW BEAM COVER $10.00 $5.00
LEFT COVER GLASS 63128382191 $35.00 $10.00
RIGHT COVER GLASS 63128382192 $35.00 $10.00
BULB SOCKET, HIGH BEAM 63128380207 $5.00 $5.00
HEAD LIGHT VERTICAL AIM CONTROL 67168372381 $30.00 $5.00
WIRING LIGHT REGULATOR 61138373573 $5.00 $5.00
BRACKET,CONTROL UNIT, XENON LIGHT LEFT 63126924283 $10.00 $10.00
BRACKET,CONTROL UNIT, XENON LIGHT RIGHT 63126920166 $10.00 $10.00
IGNITION ELEMENT XENON-LIGHT 63126925648 $70.00 $10.00
CONTROL UNIT XENON LIGHT 63126925647 $90.00 $10.00
BI-XENON HEADLIGHT, LEFT 63127165823 $280.00 $25.00
BRACKET HEADLIGHT RIGHT 63128380188 $20.00 $5.00
BULB XENON LIGHT 63217160806 $20.00 $5.00
SUPPORTING RING F XENON LIGHT BULB 63126905323 $5.00 $5.00
SMG ACTUATOR 23412229789 $600.00 $15.00
GETRAG DME WBSBL934X2JR14717 2282515 $180.00 $20.00
GETRAG DME WBSBL93443JR22295 2282565 $180.00 $20.00
SMG MANUAL GEARBOX/TRANSMISSION 23002229786 $800.00 $150.00
ACCELERATOR PEDAL $60.00 $15.00
CLUTCH AND BRAKE PEDAL ASSEMBLY $80.00 $15.00
BRAKE PEDAL ASSEMBLY SMG $40.00 $15.00
PULSE GENERATOR, ABS REAR 34521164652 $15.00 $5.00
PULSE GENERATOR, ABS REAR 34526752683 $15.00 $5.00
TRAILING ARM, LEFT REAR 33322229685 $150.00 $20.00
TRAILING ARM, RIGHT REAR 33322229686 $150.00 $20.00
LOWER WISHBONE FITS LEFT AND RIGHT 33326770813 $25.00 $10.00
UPPER LEFT WISHBONE REAR 33326781625 $50.00 $10.00
UPPER RIGHT WISHBONE REAR 33326781626 $50.00 $10.00
REAR AXLE CARRIER 33312282490 $140.00 $40.00
PUSH ROD REAR SUBFRAME 33312229295 $40.00 $10.00
ROD REAR SUBFRAME 33312229899 $60.00 $30.00
STABILIZER, REAR 33552282181 $50.00 $20.00
REAR SHOCK ABSORBER 33522283105 $50.00 $10.00
DIFFERENTIAL 33102282481 $500.00 $100.00
OUTPUT SHAFT LEFT 33207839467 $200.00 $25.00
OUTPUT SHAFT RIGHT 33207839468 $200.00 $25.00
FRONT LEFT SEAT $400.00 $100.00
FRONT RIGHT SEAT $400.00 $100.00
REAR SEAT BOTTOM $100.00 $40.00
RIGHT REAR SEAT BACK $100.00 $40.00
LEFT REAR SEAT BACK $100.00 $40.00
LATERAL TRIM PANEL RIGHT 8099514 $60.00 $25.00
LATERAL TRIM PANEL LEFT 8099513 $60.00 $25.00
STEERING COLUMN 32303450159 $80.00 $20.00
STEERING RACK 32132229397 $180.00 $20.00
OIL CARRIER POWER STEERING 32411097164 $15.00 $10.00
AT-VANE PUMP POWER STEERING 32412229679 $100.00 $10.00
COOLING COIL POWER STEERING 17102282339 $40.00 $10.00
STEERING WHEEL MANUAL 32342282020 $250.00 $15.00
STEERING WHEEL SMG 32342282222 $350.00 $15.00
LOWER TRIM PANEL 32311094679 $35.00 $15.00
TRIM PANEL UPPER PART 32311094678 $20.00 $10.00
PASSENGER DOOR HARNESS 61126913096 $20.00 $10.00
DRIVER DOOR HARNESS 61126913090 $20.00 $10.00
DRIVER DOOR HARNESS 61126913092 $20.00 $10.00
PASSENGER DOOR HARNESS 61126913098 $20.00 $10.00
SWITCH UNIT, LIGHT / FOGLAMPS 61319133024 $40.00 $10.00
WINDOW LIFTER SWITCH, PASSENGER SIDE 61316902178 $30.00 $5.00
SWITCH TURN SIGNAL,DIP-DIM CONTROL 61318363668 $20.00 $10.00
WIPER SWITCH 61318363664 $20.00 $10.00
SWITCH HAZARD WARNING/CENTRAL LCKNG SYST 61318368920 $15.00 $5.00
SWITCH SMG 61357832033 $30.00 $5.00
SWITCH F MIRROR ADJUSTMENT 61318373691 $20.00 $5.00
SWITCH UNIT, CENTER CONSOLE 61316925520 $80.00 $10.00
SWITCH SLIDING ROOF 61316907288 $10.00 $5.00
LIGHTER ELEMENT 61346969134 $15.00 $5.00
SWITCH UNIT STEERING COLUMN 61318379091 $40.00 $10.00
TRUNK UNLOCKING SWITCH 61318365579 $15.00 $5.00
HEADLINER, SUNROOF ITS 51447902807 $150.00 $100.00
FRONT WINDOW GLASS 51317019544 $200.00 $120.00
REAR WINDOW GLASS 51318208469 $100.00 $100.00
RIGHT FRONT WINDOW 51328204178 $50.00 $40.00
RIGHT REAR WINDOW 51364334946 $50.00 $40.00
LEFT FRONT WINDOW 51328204177 $50.00 $40.00
LEFT FRONT WINDOW 51364334945 $50.00 $40.00
BUMPER CARBON BLACK NO PDC 51122695267 $220.00 $120.00
CARRIER SYSTEM, REAR LIGHTWEIGHT BUMPER 51127894853 $180.00 $40.00
COVER, INNER MIRROR TRIANGLE, LEFT 51328204175 $5.00 $5.00
COVER, MIRROR TRIANGLE, RIGHT 51328204176 $5.00 $5.00
REARVIEW MIRROR EC / LED / RADIO 51169142225 $200.00 $20.00
CONSOLE UPPER 51168218307 $15.00 $15.00
ARMREST LEATHER 51168238223 $90.00 $15.00
CONSOLE, CENTER ARM REST 51168218305 $25.00 $15.00
CUP HOLDER 51168217953 $30.00 $10.00
ODDMENTS TRAY WITH COINBOX 51168217957 $30.00 $10.00
ASHTRAY WIHT ROLLER 51168268340 $15.00 $10.00
FRONT INSERT WITH COVER 51168202188 $25.00 $10.00
STORING PARTITION COVER SMG 51167896461 $30.00 $10.00
INSTRUMENT PANEL, SWITCH CENTRE 51167001410 $40.00 $10.00
INSTRUMENT PANEL, SWITCH CENTRE 51168268892 $40.00 $10.00
INSTRUMENT PANEL, UPPER PART 51458237560 $35.00 $15.00
SUN VISOR, CLOTH, ILLUMINATED LEFT 51167902799 $40.00 $10.00
SUN VISOR, CLOTH, ILLUMINATED LEFT 51167902800 $40.00 $10.00
LATERAL TRIM PANEL, M FOOT REST,FRNT LFT 51432695411 $35.00 $15.00
LATERAL TRIM PANEL FRONT RIGHT 51438227952 $10.00 $15.00
COVER STRIP, ENTRANCE, INTERIOR, LEFT 51478239957 $10.00 $10.00
COVER STRIP, ENTRANCE, INTERIOR, RIGHT 51478239958 $10.00 $10.00
COVER, ENTRANCE, LEFT 51477891927 $30.00 $10.00
COVER, ENTRANCE, RIGHT 51477891928 $30.00 $10.00
COVERING COLUMN REAR LEFT 51432699059 $20.00 $10.00
COVERING COLUMN REAR RIGHT 51432699060 $20.00 $10.00
COVERING HEADLINING REAR 51442699061 $10.00 $10.00
LATERAL TRIM PANEL REAR RIGHT 51437890744 $50.00 $20.00
LATERAL TRIM PANEL REAR LEFT 51437890743 $50.00 $20.00
LATERAL TRIM PANEL REAR RIGHT 51437890780 $50.00 $20.00
LATERAL TRIM PANEL REAR LEFT 51437890779 $50.00 $20.00
LATERAL TRIM PANEL REAR LEFT 51437890727 $50.00 $20.00
LATERAL TRIM PANEL REAR RIGHT 51437890728 $50.00 $20.00
DOOR TRIM PANEL RIGHT 51417890888 $100.00 $20.00
DOOR TRIM PANEL LEFT 51417890887 $100.00 $20.00
DOOR TRIM PANEL RIGHT 51417890876 $100.00 $20.00
DOOR TRIM PANEL RIGHT 51417890948 $100.00 $20.00
DOOR TRIM PANEL LEFT 51417890947 $100.00 $20.00
DOOR HANDLE INNER RIGHT 51418237588 $25.00 $10.00
DOOR HANDLE, INSIDE LEFT 51418237587 $25.00 $10.00
FRONT RIGHT ARM REST 8241094 $30.00 $10.00
CONSOLE, CENTER ARM REST 51167902635 $120.00 $20.00
TRIM PANEL LEFT 51478266569 $20.00 $20.00
TRIM PANEL RIGHT 51478212400 $20.00 $20.00
TRUNK LID TRIM PANEL 51498208511 $30.00 $30.00
REMOVABLE PANEL FOR LUGGAGE COMPARTMENT 51478225327 $30.00 $30.00
TRUNK MAT 51478232347 $30.00 $30.00
THROUGH-LOADING CROSS MEMBER TRIM 51468204266 $15.00 $25.00
COVERING REAR 51478204070 $20.00 $25.00
BREATHER COVERING REAR 64228377280 $5.00 $10.00
LEFT ODDMENTS TRAY 51478230573 $5.00 $10.00
TRUNK TRAY LEFT 51478162577 $10.00 $10.00
DASHBOARD $120.00 $120.00
HEATER DUCT RIGHT 51478204106 $10.00 $10.00
HEATER DUCT LEFT 51478204105 $10.00 $10.00
REAR WINDOW SHELF 8204245 $15.00 $20.00
LEFT OUTER KICK PANEL 51717890011 $50.00 $50.00
RIGHT DOOR SILL TRIM PANEL 51717890012 $50.00 $50.00
FLOOR COVERING FRONT 51478213974 $150.00 $60.00
FLOOR COVERING REAR 51478231334 $130.00 $50.00
TRIM PANEL LEFT, PAINTED 51130001069 $40.00 $10.00
TRIM PANEL LEFT, PAINTED 51130001067 $30.00 $10.00
TRIM PANEL RIGHT, PAINTED 51130001070 $40.00 $10.00
AUDIO HARNESS
TRIM PANEL ABOVE HEADLIGHT SWITCH 8196101 $20.00 $5.00
Quivers is offline   Reply With Quote
Old 02-22-2012, 03:04 PM   #2
luthers4
My Ride: 02 330ci/ 04 M3
What color are the outer kick panels ... if TiAG dibs on the right. Also need some other parts but rocker panel is most important.
Thanks,
luthers4 is offline   Reply With Quote
Old 02-22-2012, 03:27 PM   #3
BigDRick323
My Ride: 2000 323i
Seats, color, price?
Old 02-22-2012, 05:37 PM   #4
Quivers
My Ride: E70 X5
Thanks,
I have the left and right in carbon, the left in Alpine, and a titanium silver left. I also have a set of aftermarket skirts but I'm not sure of the brand.
Old 02-22-2012, 05:41 PM   #5
Quivers
My Ride: E70 X5
Black only, $400 per front seat. If you need the whole interior or individual parts I can give you a quote for that.
Prices and approximate shipping cost are in the list. I have part numbers as well, some of the part numbers I used are for factory refurbished parts but you can use them to look up fitment and diagrams on the oem sites.
Old 02-22-2012, 05:54 PM   #6
MADEYOULOOKM3
My Ride: E46 M3
Do you have a
Left rear L.E.D tail light (outer)?
MADEYOULOOKM3 is offline   Reply With Quote
Old 02-22-2012, 06:28 PM   #7
e40Blitz
My Ride: 2000 328ci
How much for titanium silver sideskirt? I didn't see that
Sent from my HTC Sensation Z710e using Bimmer App
e40Blitz is offline   Reply With Quote
Old 02-22-2012, 06:34 PM   #8
Quivers
My Ride: E70 X5
Originally Posted by MADEYOULOOKM3 View Post
Do you have a
Text message replied.
Old 02-22-2012, 06:36 PM   #9
Quivers
My Ride: E70 X5
50 plus shipping, send me your zip code and I'll get a quote. It has to go USPS parcel due to length. No one else will take it.
Old 02-22-2012, 07:07 PM   #10
iwanna
My Ride: 5 series
Hi the price listed for 65138374698 does it include both L & R?
iwanna is offline   Reply With Quote
Old 02-22-2012, 07:18 PM   #11
e40Blitz
My Ride: 2000 328ci
My zip code is 11203... Send me pics please xxblackiechanxx@gmail.com
Old 02-22-2012, 07:26 PM   #12
jack.chris328
My Ride: is a truck.
For what its worth, UPS will ship them, and for cheaper that USPS. I shipped a set from San Diego to New York for about $35.00. I made the box to fit, 1" larger on each side than the skirts.
jack.chris328 is offline   Reply With Quote
Old 02-22-2012, 09:00 PM   #13
dishwab
My Ride: 2002 330ci
Send a message via AIM to dishwab
Do you have any of the the exterior shadowline trim available? Mostly looking for PNs 51717003935 and 51717003936 (the top trims). Let me know, thanks
dishwab is offline   Reply With Quote
Old 02-22-2012, 11:14 PM   #14
BigMase45
My Ride: 02 325i
PM sent on steering wheel.
BigMase45 is offline   Reply With Quote
Old 02-23-2012, 12:59 PM   #15
Quivers
My Ride: E70 X5
This is for 1, I could not find any for sale used to compare prices except 1 guy selling a set of speakers. At least ninety five percent of my prices are equal to or cheaper than the lowest price on ebay but feel free to make an offer if you don't think my price is fair.
Old 02-23-2012, 12:59 PM   #16
Quivers
My Ride: E70 X5
Pictures sent
Old 02-23-2012, 01:05 PM   #17
Quivers
My Ride: E70 X5
I have these for $120, please send me a zip code if you would like a shipping quote.
Old 02-23-2012, 01:07 PM   #18
Barbaros
My Ride: 02 TIAG M5
No steering wheel? In for the steering wheel. Let me know please pm me.
Barbaros is offline   Reply With Quote
Old 02-23-2012, 01:14 PM   #19
Quivers
My Ride: E70 X5
I tried using smaller dimensions like you said and it worked. I hate to package something with so little padding but these are pretty tough, I'm sure they'll be fine.
Old 02-23-2012, 03:09 PM   #20
TheSho007
My Ride: BMW 325I
PM me for details on 64116956319. I really.. really.. wanna pick this up!
Also 51167001410. Wanna grab them both
TheSho007 is offline   Reply With Quote
