Old 02-22-2012, 05:33 PM   #1
alpine325coupe
My Ride: 2004 M3 SG/IR
Front End Clunk/Wobble....Help me diagnose!
So about a week or so ago I installed Tein SuperStreet coilovers. They are friggin' awesome. About 2-3 days later, I noticed a noise coming from the front driver's side. It sounds like something wobbling or clunking, which lead me to believe it was metal on metal.
At first I thought it was the bolt that anchors the bottom of the strut in the clamp. I checked that out the next day, it was as tight as can be. I also noticed that the 3 strut mount bolts were a bit loose. Tightened those bad boys up. Noise did not go away.
Next culprit was the control arm bushing. I went ahead and replaced the control arms and bushings. Noise did not go away.
After reading more threads on here, I saw that everyone mentioned checking the sway bar endlinks. I completely took out the sway bar, including endlinks, bushings, and brackets. Noise did not go away.
Today I noticed that the knob to adjust the damper on the driver's side is not clicking properly. It is either screwed in or it comes right out.....odd (pictures of this shown below).
If I had to guess right now, it would be the strut mount. I can switch the two of them to see if the noise transfers to the passenger side, but I'm too lazy. If I'm going to do that I'd rather install new mounts.
Any ideas?
Thanks in advance
2004 Silver Grey / Imola Red - 146k Daily Driver
ENGINE: Scoop, Filter, Elbow, Pulleys, Tune, fan delete+SAP delete
EXHAUST: Headers, Rasp sec. 1, res. x-pipe, TopSpeed muffler
SUSPENSION: BC, subframe reinforcement
WHEELS/TIRES: Hamann PG1, 19x9.5 +25, 19x10.5 +25
DRIVETRAIN: 4.10 gear ratio
LIGHTING: Orion V2, 3000k fogs
INTERIOR: Recaro SPG reps, Cobywheel, CF trim, Dynavin clone, Stealthboxes
alpine325coupe is offline   Reply With Quote
Old 02-23-2012, 11:10 AM   #2
alpine325coupe
Bump
Old 02-23-2012, 11:45 AM   #3
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
How many inches did you lower the car?
Old 02-23-2012, 12:36 PM   #4
alpine325coupe
Not too much. Maybe 1.5 in the front. I was already lowered on racelands so I don't know how much lower I am than stock
clunking, noise, suspension
