Old 02-22-2012, 10:15 PM   #1
Locutus09
My Ride: Something Slow
Fluids for Track
Simple question.
I know OEM Brake fluid shouldn't be used because it has boiled before in our cars while on the track.
What should I replace it with? Making purchases shortly for Oil, just wondering what other fluids I should plan on replacing prior to DD, autocross, and HPDE season.
Locutus09 is offline   Reply With Quote
Old 02-22-2012, 11:54 PM   #2
Alan
Alan's Avatar
My Ride: 2006 M3
For HPDEs - I use RBF600.
Alan is offline   Reply With Quote
Old 02-23-2012, 12:46 AM   #3
LivesNearCostco
My Ride: 2003 ZHP 6MT
I'd drain and replace coolant if it's been in there more than 2 years. Same for power steering fluid, though draining that is a hassle because you have to unbolt one of the hoses from the rack or pump (or you can do the fluid exchange method). I would change manual transmission fluid and diff fluid every two years or 30,000 miles, but others change those anywhere from every season to every 60,000 miles (or every 100,000 miles if they don't track the car).
I did my first several track days on fresh generic Kragen/O'reilly DOT 4 brake fluid. I only got fade once and I think that was due to using street pads. But back then I was really slow. Then I switched to Ate Typ 200/Gold. It's not as boil resistant as the fancy Motul or Castrol stuff, but seems more than enough for my modest power levels. Of course Alan is rocking an M3 and drives at VIR, where I hear good drivers can get to the top of 5th gear, so maybe he has to handle more heat! (I never get past 120mph or 4th gear.)
Edit: I'm thinking of doing my transmission fluid at 15,000 miles since last change instead of 30,000 miles.
Lowering my car's resale value one track day at a time...
LivesNearCostco is offline   Reply With Quote
Old 02-24-2012, 05:22 PM   #4
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
If you are going to the track frequently or driving on tracks that are hard on brakes, I would recommend Castrol SRF. Motul RBF600 is great but its toast once you boil it...and you need to bleed more often.
I would give an even stronger recommendation for SRF if you plan to pay someone to bleed your brakes.
I wouldn't go cheap on brake fluid...not fun when your brakes start fading. I would HATE having my car sidelined because I used cheap brake fluid.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 02-24-2012, 05:34 PM   #5
MasterC17
My Ride: hates A/C & Sunroofs
PFC RH665 http://store.bimmerworld.com/perform...uid-p1702.aspx
A good in-between for the Motul RBF600 and the Castrol SRX.
MasterC17 is offline   Reply With Quote
Old 02-24-2012, 08:07 PM   #6
Ryan@GF-Performance
Past Site Sponsor
+1 on the PFC RH665, that's what we're running this season on our M3. We've been running Motul RBF 600/660 on our M3 and 330i for quite awhile with no issues too.
Ryan@GF-Performance is offline   Reply With Quote
Old 02-24-2012, 08:44 PM   #7
teamdfl
Slow in, slower out
My Ride: 325it
Originally Posted by Locutus09 View Post
Simple question.
BMW OEM brake fluid is actually pretty good. The problem is that it is too old if it has never been changed. New stuff from the dealer parts counter is pretty expensive. Ate Type 200 or Super Blue are perfectly acceptable for most track junkies.
You can't go wrong with Red Line oils for the engine, trans, and diff in appropriate weights.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 02-25-2012, 01:55 AM   #8
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
OP,
I've been S.C.C.A. Club Racing for a long time, I've never run anything but ATE Super Blue. My brakes consist of stock OEM rotors, braided brake lines, Hawk HT10 pads, ATE Super Blue, & brake backing plates with 3" ducts. Not only have I done my share of winning, but I've also set two different track lap records; Ate Super Blue never missed a beat.......Period.
Good luck.
PS, run your motor oil a half quart high on the dip stick.
SUMMIT POINT WV 1:24:229 SCCA
Old 02-25-2012, 01:59 AM   #9
PrittyM3
My Ride: E46 M3
subscribed for info
PrittyM3 is offline   Reply With Quote
Old 02-25-2012, 02:53 AM   #10
moranor
My Ride: 323i
this is what most people dont seem to get... forget BBKs... good pads, steel braided lines and brake fluid is where you need to spend your money... everything else is just race tinsel in most cases and not needed on our cars
moranor is offline   Reply With Quote
Old 02-25-2012, 05:49 PM   #11
MasterC17
I thought this was beneficial on E30/E36's but was actually not beneficial and potentially harmful for E46's?
Old 02-25-2012, 08:07 PM   #12
Rob43
Rob43's Avatar
Well maybe you know something that I don't, it wouldn't be the first time I got something wrong.
I'll look into this, I'm friends with two different E46 330Ci/i race teams. I'll place calls & find out definitively. When I find out what they say, I'll report back; probably 2 or 3 weeks.
Rob
Old 02-25-2012, 08:19 PM   #13
dan_1337
My Ride: 330CiC
I use RBF600
dan_1337 is offline   Reply With Quote
Old 02-25-2012, 11:34 PM   #14
LivesNearCostco
I sometimes run my motor oil 1/2 qt high in my E46 to stop lifter tick during AutoX. I don't know of any other problems from running it at the normal full mark instead of above the full mark, but I don't have an oil pressure gauge so who knows if I'm starving the motor or not. (My oil warning light never comes on during track days--maybe I'm not cornering hard enough.)
Old 02-26-2012, 12:10 AM   #15
bigjae1976
bigjae1976's Avatar
A good BBK with race pads will make a significant improvement in braking performance. If anything, the consumable parts last longer. You more significantly more heat dissipation and (don't give a crap what people think)...you can stop shorter over and over and over. Not that I am racing but we all like to pass...at the end of a session, I know I can catch most cars in a hard braking zone by braking much later.
But you've got to pay to play...probably not a worthwhile investment for the occassional HPDE.
Rob
Someone told me that you will ruin an S54 by running it a quart over. I've ran my M54 about 1/2-1 qt over and never had an issue so far.
I have no knowledge about this...just putting it out there as a theory.
Old 02-26-2012, 01:08 AM   #16
moranor
My Ride: 323i
I partly agree but where im from most guys run blanks or M3 brakes because its cheaper to run... also if your car is setup right you can carry way more speed in the corners so less braking is required... almost no track cars here run a BBK...
If it offered such an advantage im sure they would switch over... dont get me wrong if you have heat problems you should definitely go BBK, but to fit them just because all the cool kids have them or you think you need them is counter productive and the money should rather be spent in other areas...
Old 02-26-2012, 08:11 AM   #17
MasterC17
I'm thinking with the S54 it may have something to do with the fact that it is a "dry" sump.
If you want to have great brakes without going full BBK look into PFC products and a brake ducting kit from Bimmerworld or Turner. Unfortunately, PFC doesn't makes their 2-Piece rotors for the 323, but they do make pads for it.
Old 02-26-2012, 11:42 AM   #18
bigjae1976
bigjae1976's Avatar
You can carry more speed longer is the advantage. At the point where I can start my braking is always later than the guy in front of me. The problem I have is I'm usually almost running into the back of the car in front of me before my braking begins.
Don't get me wrong, the OEM brakes are good and adequate for HPDE session. The reason that many shy away from a BBK is probably the cost. When you need new rotors discs...you can get OEM blanks for $200-$300 a pair. Stoptech rotor rings run from $200-$350 each. I'm not sure the ST rotor rings last THAT much longer than OEM rotors (or quality aftermarket versions) where the ST rings are cheaper of the long run.
The reason why I have the ST 4 wheel BBK is reliability. I've already been through the experience of losing your brakes doing 135mph trying to turn down into the carousel at Texas World Speedway...and then once in Korea going from 130mph to about 50mph.
IIRC, the guy said (I think) it floods the engine and something bad happens (can't remember what).
The S54 is a dry sump? Didn't know that.
Old 02-26-2012, 12:32 PM   #19
moranor
My Ride: 323i
ducting is a must it really helps alot... I just get very annoyed that alot of street cars run 19"+ rims just to fit a bbk because they "need" them and at the track they are hardly seen here sorry dont know why i felt i had to vent here
Old 02-26-2012, 01:52 PM   #20
HiHoBrian
My Ride: 05 M3
Endless RF-650 Racing Super Fluid as per European Car Magazine review. I haven tried it,but it was highly rated.
HiHoBrian is offline   Reply With Quote
