Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 01-08-2013, 02:20 PM   #41
bimmerguy055
My Ride: M3
Send a message via AIM to bimmerguy055
Legally, the purpose is for eliminate the codes. (as a peace of mind in-case other codes are present) but, I've been told that others who have used it(for example, from link I provided earlier) to try and pass emissions succeeded.
Originally Posted by ac_2007 View Post
What reason would you have for saying they donít work?
I'm curious also.
Without Failure There is No Success
bimmerguy055 is offline   Reply With Quote
Old 01-08-2013, 02:26 PM   #42
Guest021715
Account closed.
I sent you a PM btw
Old 01-08-2013, 02:31 PM   #43
bimmerguy055
My Ride: M3
I sent you a PM btw
check your personal email
Old 01-08-2013, 04:37 PM   #44
daewon774
My Ride: 2002 330xi
Originally Posted by bimmerguy055 View Post
It will be very similar, remember, I have to make these by hand.
Originally I used a resistor and capacitor to show the ECU a consistent voltage (.415v) witch seams to keep the ECU happy and keep the car in open-loop right before the closed-loop mark (.45v) so logically speaking the car stays at a perfect balance between rich and lean ~ 14.7 AFR. This method I found out was a hit or miss, as the spark plug defouler method (taking the 02 sensor out of the exhaust flow) was.
A more complex circuit would need to be built so the ECU does not flag the consistent voltage. This would call for a oscillating signal generator (witch I currently use), that would oscillate the voltage signal from .11v to .81v greatly mimicking what a typical working post-cat 02 sensor should be doing, and in-turn, keeping the ECU happy.
alright, my bad... I didn't read this till now. I was under the assumption you were running a single voltage that other O2 sims out there do. What you're doing seems to be correct. My apologies
2002 E46 330xi
Active Autowerke Stage I Supercharger
Magnaflow 11378 exhaust
Bilstein shocks/struts + H&R springs
Style 71s
Soon to be installed Bimmerbrakes headers + LC1...
daewon774 is offline   Reply With Quote
Old 01-08-2013, 04:38 PM   #45
daewon774
My Ride: 2002 330xi
btw, what's the price on these?
2002 E46 330xi
Style 71s
Old 01-08-2013, 05:48 PM   #46
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Might have to pick this up, I don't think my normal o2 sim takes care of the heater code.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 01-08-2013, 06:40 PM   #47
bimmerguy055
My Ride: M3
daewon774 + secono330ci PM sent.
Old 01-16-2013, 09:46 PM   #48
straight_beamin
My Ride: 2000 bmw 323i
Bump this guys simulators are very neatly done up, i recommend !
straight_beamin is offline   Reply With Quote
Old 01-16-2013, 10:01 PM   #49
Guest021715
Account closed.
Did you ship him your connectors?
I want these sims but don't feel like ruining 2 perfectly good sensors.
Old 01-16-2013, 11:34 PM   #50
777eThOd*
My Ride: spins too much
I got mine the other day But I will install them maybe tomorrow or next day when I have a Chance, Then I will run scanner to see if my codes go away..
2007 BMW 335i FBO 6MT - Current
2013 Nissan Nismo 370Z - Current
2004 Non-M Facelift Coupe - SOLD
2006 BMW M3 - SOLD
777eThOd* is offline   Reply With Quote
Old 01-16-2013, 11:41 PM   #51
straight_beamin
No i ruined 2 good sensors, bought em for 15 a piece on ebay not bad tho...
Old 01-16-2013, 11:51 PM   #52
Guest021715
Account closed.
What the heck is a "eurocharged aggressive tune"?
Sounds mean LOL
Old 01-16-2013, 11:55 PM   #53
777eThOd*
Sounds mean LOL
Lmao. It's one of Eurocharged's tunes which is the Best performance tune and they call it the aggressive tune, but hey it's a 18-20hp gain depending on bolt ons.. it's good. And it is mean LOL..
2006 BMW M3 - SOLD
Old 01-19-2013, 09:57 AM   #54
straight_beamin
Checked up on it they have an amazing tune for the N54 335i and 135i
Old 01-20-2013, 03:46 AM   #55
E46Snowball
My Ride: 330i
Originally Posted by drumbum624 View Post
do you mind me asking what your heater circuit consists of? Is it just inline resistance?
Could you post this for us to see? I would like to know more about this product to have any interest in buying it...
E46Snowball is offline   Reply With Quote
Old 01-20-2013, 01:02 PM   #56
bimmerguy055
My Ride: M3
For the heater emulation, its just a in-line resistor. Are you just in need of simulating the heater function?
Old 01-25-2013, 10:08 PM   #57
BWOODM3
My Ride: 2002 M3 convertible
I want this. PM me
BWOODM3 is offline   Reply With Quote
Old 02-10-2013, 10:40 PM   #58
serdar255
My Ride: '01 325ci / '90 325i
I want it! Msg me!
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 02-12-2013, 01:23 AM   #59
bimmerguy055
My Ride: M3
PM Sent
Old 02-12-2013, 01:36 AM   #60
bimmerguy055
My Ride: M3
Note that I will probably not be making these much longer, as I have gotten busy with other things, since I first posted about this.
