Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 02-12-2013, 02:33 AM   #61
AudiEtr
My Ride: 330i
pm sent, will pay over retail
AudiEtr is offline   Reply With Quote
Old 02-18-2013, 02:06 PM   #62
VitalyZHP
Ukrainian
My Ride: 04 330CI
PM'd
VitalyZHP is offline   Reply With Quote
Old 03-11-2013, 02:57 AM   #63
///Mostarac
///Mostarac's Avatar
My Ride: 370z & Cbr600rr
anybody have problems NOT passing inspection with these? I need to pass inspection somehow
Eurowerkz | East Coast
-Benny
///Mostarac is offline   Reply With Quote
Old 03-11-2013, 08:22 AM   #64
straight_beamin
My Ride: 2000 bmw 323i
Fml
straight_beamin is online now   Reply With Quote
Old 03-11-2013, 08:24 AM   #65
straight_beamin
Im going today... My monitors were showing incomplete a few days ago so i did some driving to cycle it. Cel is gone but i think i am going to fail.
Old 03-11-2013, 09:36 AM   #66
BWOODM3
My Ride: 2002 M3 convertible
My car was throwing these codes. I cleared the code, put the stock air intake on it. Drive it for a day or two. Smogged it, and passed. After passing I out the KNN intake back on it and sure enough the sel came back on.
BWOODM3 is offline   Reply With Quote
Old 03-11-2013, 09:52 AM   #67
Guest021715
Account closed.
Just so we understand what you’re saying here, you blame a conical air filter for causing your post-cat O2 efficiency codes.
There is no logical relationship between the two elements, unless you dipped your filter in oil.
More than likely you’re sending power to one or more sensors (MAF) while they are disconnected, or your catalytic converters/post-cat sensors are indeed bad – and the code was thrown without any correlation to the intake variable.
Old 03-11-2013, 10:33 AM   #68
straight_beamin
Update: had 4 incomplete monitors before weekend. I now have 3. 1 less and i can get my etest!!!
Old 03-11-2013, 10:45 AM   #69
Guest021715
Account closed.
Which monitors are incomplete?
Are you saying we're allowed 2 monitors to be with issues?
Old 03-11-2013, 11:28 AM   #70
straight_beamin
Catalyst o2 heater and another o2 thingy. Evap went away after 300km's of driving. If you have a 2000 or older you can have 2 incomplete my mechanic says
Old 03-11-2013, 11:36 AM   #71
straight_beamin
They are the precats i believe. I just bought them also. They were from a scrapyard and were marked bank 1 sensor 1 and bank 2 sensor 1. I didnt pay attention to that when installing them just plugged em in. I hear from friends that it is all "universal" so it doesnt matter if they get switched around? Anyone! Ive noticed some sputtering at low rpms so could that be it?
Old 03-11-2013, 11:42 AM   #72
Guest021715
Account closed.
Universal O2's definetly exist for the BMW as well, but my bet is they will be terrible at their job.
We tried these universal solutions on an old family car, and they lasted about 2 weeks before switching to OEM.
Old 03-11-2013, 12:00 PM   #73
777eThOd*
My Ride: spins too much
I went yesterday too And said I couldn't pass as well, my O2s, and Evan wasn't ready but now for sure I won't pass, I got this wierd code
"296B Oxygen sensor after cat. conv. : mixed up"
2007 BMW 335i FBO 6MT - Current
2013 Nissan Nismo 370Z - Current
2004 Non-M Facelift Coupe - SOLD
2006 BMW M3 - SOLD
777eThOd* is offline   Reply With Quote
Old 03-11-2013, 01:35 PM   #74
straight_beamin
Do u have the simulators? If not u need a new rear o2 im assuming. It took 250 miles to get rid of evap!
Old 03-11-2013, 02:43 PM   #75
BWOODM3
No I am not "blaming" the conical air filter. However, after I put the stock air filter on the car the code went off an stayed off. Ran it through smog and passed with flying colors. After I put the KNN filter back in ( I am assuming the oil from the filter was throwing the MAF off and it started running rich AND lean) causing it to throw the bad cat code.
Old 03-16-2013, 08:09 PM   #76
straight_beamin
anybody have any luck? i have been trying the drive cycle but either have to speed up or do something which cancels the test. best way to get evap to complete anyone?
Old 04-15-2013, 10:37 AM   #77
Guest021715
Account closed.
So what's the deal with these O2-sims? From what I've lurked through the fourms, it seems the post-cat O2's check for a lean condition after you let off the throttle. These O2 sims do not produce this signal and therefore you get the CEL again.
Straight beamin, I'm looking at you, what was the final outcome of trying to pass your e-test?
Old 04-15-2013, 01:35 PM   #78
bimmerguy055
My Ride: M3
Send a message via AIM to bimmerguy055
The truth is the CEL stay's off and the DME is tricked. But in the past, there where issues with the monitors not in a ready state. the 02 sims DO produce the correct signal, its the monitoring test for when people go take their emissions test that seams to be a hit or miss. I would have mitigated the issue, but my car is lazy at detecting, and I don't have anyone l local to be the ginnie pig
Without Failure There is No Success
bimmerguy055 is offline   Reply With Quote
Old 04-15-2013, 01:41 PM   #79
NumbaOneNewb
My Ride: 2003 330CI Silver
I don't think the OEM o2s were interchangeable. If you skipped BMW and went straight to bosch to purchase your o2s, the pre cat and post cat have different part numbers. for the most part, visually they look the same. the only difference that i could see visually is the length of the wire, since they have to go different distances.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-15-2013, 02:53 PM   #80
bimmerguy055
My Ride: M3
I'm not following why your talking about 02 sensors pacifically? The pre + post 02's are different on how they read, along with their connectors pre is (female) and post is (male) on non-Ms
