Old 01-05-2011, 06:08 PM   #1
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
DIY for Bee Sting O-ring Gasket Replacement / REPAIR
First, I like to thank ~
(NicB.) for providing the pic which I added a few identification highlighted in 'RED'.
(dmax) for providing the part number 'DANCO #18 for the ~ O-ring / Gasket for the base.
UPDATE:
Finally I've disassembled my 'Bee Stinger' antenna. I wanted to tug in the antenna wire, but decided not to. The antenna is a screw itself to tighten down the plastic (black) cover antenna using a gasket / O-ring.
There are two part that needs to be replace with:
1. The O-ring / Gasket (DANCO #12) in the middle.
2. The O-ring / Gasket (DANCO #18) for the base.
Here is what it should look like after you've replaced with (DANCO) O-ring gasket #12 & #18.
For now, I will use the O-ring method and wait for my 'DUMMY' antenna cover to arrive.
BMW /// 323i /// Sedan
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// DEPO corners /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
Old 01-06-2011, 01:37 AM   #2
sellsellsell2000
My Ride: E46 seden
If all else fails! Carbon Fiber Wrap it!
Old 01-06-2011, 03:58 AM   #3
w0w
My Ride: '02 M3 Vert
how weird i was gonna try to do this tomorrow!
daron
w0w is offline   Reply With Quote
Old 01-06-2011, 04:07 AM   #4
Arty
My Ride: 1999 328i
Google Hirschmann. They supply BMW, VAG and merc. They will have a little puck antenna, a replacement beesting or a blanking plate.
Arty is offline   Reply With Quote
Old 01-06-2011, 02:27 PM   #5
ntense1
My Ride: 2000 328Ci
I was planning on removing my ugly Bee-Sting antennae, capping it with a grommet of some kind and placing a dummy shark fin on top of that for a better flow.
ntense1 is offline   Reply With Quote
Old 01-06-2011, 08:57 PM   #6
sellsellsell2000
My Ride: E46 seden
I've also found these
http://3rdstrikeperformance.com/imag...na%20Cover.jpg
UPDATE:
Check out: http://forum.e46fanatics.com/showthread.php?t=816151
For alterntive solution for replacing / delete 'Bee Stiner Antenna'
Old 01-06-2011, 10:28 PM   #7
Vinnie Vega
My Ride: 0032870Vette70Velle
Weld shut and paint?
Vinnie Vega is offline   Reply With Quote
Old 01-07-2011, 01:37 AM   #8
w0w
keep this thing updated, i would love to find a cheap solution with a grommet or plug.
daron
Old 01-07-2011, 01:45 AM   #9
sellsellsell2000
My Ride: E46 seden
Beeeeeeppp
Old 01-07-2011, 11:21 PM   #10
snowborder142190
My Ride: 08 335i coupe '09 m6
i want to do this! keep this updated so we can all find a solution to get rid of that stupid bee sting!
snowborder142190 is offline   Reply With Quote
Old 01-08-2011, 04:48 AM   #11
sellsellsell2000
My Ride: E46 seden
Why can't anyone create some generic / dummy 'Satellite Cover' beside sharkfin look alike.
All I am looking for is something like this:
some squarish looking; flat round button look alike dummy satellite antenna. OMG!
Old 01-09-2011, 06:38 AM   #12
sellsellsell2000
My Ride: E46 seden
(NicB.) for providing the pic which I highlighted in 'blue'.
UPDATE:
There are two part that needs be replace:
1. The O-ring
2. The O-ring / Gasket for the base.
Old 01-10-2011, 03:02 AM   #13
sellsellsell2000
My Ride: E46 seden
UPDATE:
Old 01-12-2011, 02:30 AM   #14
sellsellsell2000
My Ride: E46 seden
beeepppp
Old 03-17-2011, 09:40 AM   #15
Rafaelflopez
My Ride: E46 323i 1999
where i can find this damco o-ring #12 and #18
Rafaelflopez is offline   Reply With Quote
Old 03-20-2011, 04:34 AM   #16
sellsellsell2000
My Ride: E46 seden
You can find both at Home Depot.
BMW /// 323i
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// CCFL angel eye
Old 03-01-2012, 08:16 AM   #17
BigDRick323
My Ride: 2000 323i
Any updates, pics?
Old 03-01-2012, 04:27 PM   #18
sellsellsell2000
My Ride: E46 seden
I didn't find any alternatives. If it comes down to it, I would remove in internal wiring from the Bee Antenna and have Don wrap my roof. If notice the wrap he did on a trunk for the Subaru.
BMW /// 323i
Old 10-03-2014, 12:50 PM   #19
redlineclipse
My Ride: 2000 3 series
I know this is an old thread but here is the process in a quick video for anyone that might need it. _nr_
redlineclipse is offline   Reply With Quote
Old 05-15-2015, 03:42 PM   #20
Raf77
My Ride: 2000 BMW 328i
HI Everyone,
I am glad someone posted this issue...I've been trying to fix the problem and thought about buying a new one...I will try this cheap trick and will let you know, thanks NiceB - dmax.
Raf77 is offline   Reply With Quote
