Engine & Performance
Old 06-04-2014, 05:32 PM   #1
LAWLence
My Ride: '01 M3 Coupe
Send a message via AIM to LAWLence
Manual 5-Speed Swap Kit
Transmission was pulled from a running but totaled Touring.
Includes:
- Getrag 250G 5-Speed, 175k miles with no synchro issues, fluids changed with Motul Synchromesh every 25k
- Shifter carrier
- Selector rod
- Driveshaft
- Transmission crossbrace
- Master cylinder
- Shift lever (worn out)
- Clutch line
- E46 M3 transmission mounts
- Guibo
- Center support bearing
- Shift lever rubber boot
- Shift lever foam surround
- Clutch pedal
- Clutch pedal switch
You will need:
- Clutch/flywheel/pressure plate/throwout bearing
- Slave cylinder (stock was leaking)
- Shift lever (you probably don't want the worn one)
- Shift carrier bushing (the rubber chassis one)
$300 OBO picked up in Irvine, CA. Will not ship. No trades.
LAWLence is offline   Reply With Quote
Old 06-06-2014, 01:18 PM   #2
LAWLence
bump
Old 06-12-2014, 10:05 AM   #3
LAWLence
bump
Old 06-12-2014, 10:38 AM   #4
Jalaly25
My Ride: BMW 325Ci
If it wasn't such an expensive swap I'd be all over this. Bump for solid seller & price.
Jalaly25 is offline   Reply With Quote
Old 06-13-2014, 03:11 AM   #5
LAWLence
I am lowering the price down to $300. Need this out of my garage.
Old 07-15-2014, 12:48 PM   #6
DonaldE
My Ride: 2002 330i
Do you still have any of this stuff? I need the majority of it for my 6 speed swap
Jet Black 2002 BMW 330i
Swapped M3 Interior
OEM Style 71s
Dropped on Koni/Vogtland
Locked/Loaded/Loud
DonaldE
DonaldE is offline   Reply With Quote
Old 07-21-2014, 08:06 PM   #7
Hollywood516
My Ride: 02 330i
I need a few items off the list myself .
Hollywood516 is offline   Reply With Quote
