Old 03-02-2012, 10:40 AM   #1
Vic328CSi
My Ride: depends on the mood
Anyone sucessfully unlocked EWS for programming w/ PA Soft?
Hi, searched and scoured the internet to only find tid bits of info that I already know.
The mileage on my EWS is wrong, so me thinks its causing an error that makes me unable to read a pair of modules on my car with ncs expert that contain my VO. I am trying to correct it.
I get to ews programming, it says to short pin 4,8 on my EWS3 (046J mask) which i do, then press ok, and it says cant read and asks if i want to use dme sync to continue erasing? then everything looks fine, but ews3 status still locked and no changes are made. If i leave those pins shorted, then pa soft cant read my ews, so i assume it meant to temporarily short those pins... i tried both ways.
Has anyone actually used PA Soft to program EWS?
e46 328Ci 9psi SC
Vic328CSi is offline   Reply With Quote
