Old 03-05-2012, 02:50 PM   #1
ZeroSum
My Ride: 05 325
The dangers of overboring an M54
Picked up my M54 block from the machine shop - had it overbored .5mm to 84.5mm.
Found this when cleaning it up:
Yes that is a casting flaw in the cylinder liner, exposed after boring / honing.
Currently looking for a new block
ZeroSum is offline   Reply With Quote
Old 03-05-2012, 03:13 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
What are we looking at ?
Is that a hole that goes straight through to the water jacket, or just a small hole that stops & does NOT go all the way through, maybe about 1mm inward ?
Rob
SUMMIT POINT WV 1:24:229 SCCA
Old 03-05-2012, 03:34 PM   #3
ZeroSum
My Ride: 05 325
Does not goes all the way through, approx 1/3 into the liner and opens out on the inside. If it was further down the bore I might have risked leaving it but it sits directly over the oil ring.
Until it happens to someone else I think we can say I am just unlucky?
Old 03-05-2012, 05:00 PM   #4
fastjasonbmw
My Ride: 330Xi
Sleeve it and apply boost.
fastjasonbmw is offline   Reply With Quote
Old 03-05-2012, 05:07 PM   #5
xixixi
Banned User
My Ride: 01 330x-xi
I wouldn't have gone this route. I would abandon this block. Keep the motor mostly stock, if anything an intake cam change. Edit: if you need a cheap block PM me. I can break one down for you.
Old 03-05-2012, 06:20 PM   #6
ZeroSum
My Ride: 05 325
Sleeving is an option, but it's cheaper for me to get a new block, plus my machinist said it might not work (distortion). Boost is planned
Yeah ..... I don't know what to say, I don't even remember when my engine was stock it was that long ago. Pretty sure I have sourced a block, but thanks for the option.
Old 03-05-2012, 06:33 PM   #7
Rob43
Rob43's Avatar
Before giving my thoughts, two questions:
1) Is that pic. of two different holes, the pictures look slightly different ?
2) What is the approximate length & width of in mm, (2mm X 1mm); bigger or smaller ?
Rob
Old 03-05-2012, 07:19 PM   #8
ZeroSum
My Ride: 05 325
Rob, appreciate your thoughts - the 2 pictures are of the same hole, I would say the hole is at max 1mm x 0.5 mm wide probably less but it looks like it could get bigger as it hollows out.
Old 03-05-2012, 08:48 PM   #9
Rob43
Rob43's Avatar
I talked to my motor builder today & mentioned your hole on a side note. I asked him: "assuming the hole doesn't go through & it was Very small (2mm X 1mm), could the block still be used", answer, Yes. Keep in mind he never looked at any pics, but I did give a good description.
My personal thoughts would be to either: 1) Run it as is. 2) Buy a bottle of Moroso Ceramic Engine Sealer & fill the hole, then use a heat gun to seal it.
I'd keep & run that block.
Good luck in your decision,
Rob.
Old 03-06-2012, 01:23 PM   #10
ZeroSum
My Ride: 05 325
Thanks Rob, I wish I had held off getting a new block but it will be here on Thursday now.
Anyway I have always wanted an engine block coffee table
Old 03-06-2012, 03:15 PM   #11
fastjasonbmw
My Ride: 330Xi
VAC Motorsports has sleeves: http://store.vacmotorsports.com/vac-...-mm-p2442.aspx
