Old 03-06-2012, 05:13 AM   #1
Mc 007
My Ride: 325ci Performance
Question 325ci trouble over 4000rpm
hello,i have one trouble with my 325ci,over 4000-5000 rpm the yellow motor light switch on and the motor work 5 cilinders,stop and restart the motor works fine
pc control tells trouble on the 4 cilinder,change the ignition coil and the same...
can be the trouble the spark plug or the injection valve?
spark plugs are ngk and have 20 000km
thanks
Mc 007 is offline   Reply With Quote
Old 03-06-2012, 07:19 AM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
It could be either the plug or the injector...you did change the coil boot with coil I assume? I'm not sure you can even get the coil without the boot, but I don't know.
Your plug might just be loose...
See me in June!
dmax on Facebook
Mangofy your E46!
Old 03-06-2012, 09:22 AM   #3
Mc 007
we have change today all 6 spark plugs,we have move the the injector and always the same on the 4 cilinder,trouble over 4000rpm
i have this
http://bmwfans.info/parts/catalog/E4...il_spark_plug/
Old 03-06-2012, 09:35 AM   #4
Drewfus2101
My Ride: N/A
I would try a compression test and a leak-down test. It sounds like there is something wrong with that cylinder head, valves, piston, etc.
Drewfus2101 is offline   Reply With Quote
Old 03-06-2012, 09:39 AM   #5
Mc 007
compression test made 12,5-13 on all the cilinders...
the car works fine,no noises,goes perfect to 4000rpm in all the speeds
Old 03-06-2012, 10:21 AM   #6
AquaRelliux
My Ride: 330ci 03 M-sport
Maybe a longshot but since u checked everything else, hows your fuel filter and pump doing?
AquaRelliux is offline   Reply With Quote
Old 03-06-2012, 10:27 AM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Any rattling with your DISA?
Old 03-06-2012, 10:29 AM   #8
Mc 007
the fuel filter has maybe 20 000km,the pump is old 5 years(i change it 1 year after i buy the car),the disa has 2 years
Old 03-06-2012, 10:31 AM   #9
straight_beamin
My Ride: 2000 bmw 323i
swap cyl 4 coil with cyl 5 if the misfire moves with the coil you have your answer. i had same prob, tried everything. turns out its a 60 dollar coil
straight_beamin is offline   Reply With Quote
Old 03-06-2012, 10:34 AM   #10
Mc 007
i have try this solution,change coil,spark plug,injector...and always cilinder 4 error
maybe is a trouble with engine wiring harness
http://bmwfans.info/parts/catalog/E4...trical_system/
Old 03-06-2012, 11:14 AM   #11
Drewfus2101
My Ride: N/A
Was the compression test done correctly? Dry or wet? Hot or cold? Also, we have no idea what those numbers mean, so we can't really tell if those are within spec. But usually if all cylinders are within a few % of each other, thats a good sign.
Also, a leak down test is more accurate than a compression test, but the tester is much harder to find.
Old 03-06-2012, 11:28 AM   #12
Mc 007
all 6 cilinders have the same compression
Old 03-06-2012, 12:48 PM   #13
jasonbimmer
My Ride: 2001 BMW 330xi
injector?
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 03-06-2012, 12:52 PM   #14
Mc 007
injectors are ok,tested,engine wiring tested and are ok,error code is P1349
tomorrow we can test the disa,we can put the disa of my fathers 320i on my 325
Old 03-06-2012, 12:54 PM   #15
jasonbimmer
usually with that specific kind of missfire/fuel cut off, its caused by compression.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 03-06-2012, 01:22 PM   #16
Mc 007
compression is perfect,all 6 cilinders have the same compression
Old 03-06-2012, 01:48 PM   #17
Mc 007
tomorrow we can control the disa...other is perfect
Old 03-06-2012, 11:06 PM   #18
///Mostarac
///Mostarac's Avatar
My Ride: 370z & Cbr600rr
neznam sta bi ti reko brate, nikad nisam cuo za ovo. maybe a vacuum leak?
Eurowerkz | East Coast
-Benny
///Mostarac is offline   Reply With Quote
Old 03-07-2012, 04:34 AM   #19
Mc 007
my fathers car is now in the mechanic station,we must test
Old 03-07-2012, 08:41 AM   #20
Drewfus2101
My Ride: N/A
This doesn't mean that there isn't a problem. A true leak-down tester can show you more specifically where a potential problem is. Google it. They are cheap.
Or...just keep throwing parts at it...
