Old 03-06-2012, 01:11 PM   #1
cnsxskillz
My Ride: 05 325i
Drive & Passenger windows down with remote. NCS Expert
My 05 325i sedan can already lower the lower all the windows and open the sunroof with they key but i how do take this off and have it only lower the driver and passenger window.
on NCS expert Translation "KOMFORTOEFFNEN_FB_O_FH_HI" is used for Comfort opening (power windows without rear side windows). Any ideas on how i would do this on NCS expert?
cnsxskillz is offline   Reply With Quote
Old 03-06-2012, 02:48 PM   #2
jeepo23
My Ride: 2008 X3, 6 Speed
You can't just do the the drivers and passenger window.
You can set it to do all windows. Or you can set it so that double tapping unlock does just the drivers window.
jeepo23 is offline   Reply With Quote
Old 03-06-2012, 02:52 PM   #3
cnsxskillz
My Ride: 05 325i
really? because i found this code "KOMFORTOEFFNEN_FB_O_FH_HI" thats used for Comfort opening (power windows without rear side windows). So theres no way to code this?
Old 03-06-2012, 02:53 PM   #4
jeepo23
Okay, well if you found that in NCS then set it to aktiv.
I am assuming it's set to nicht_aktiv currently?
Plus certain commands are for verts only.. So activating such a feature not sure what consequences will follow.
here is a list of all the options.. http://homepage.mac.com/ianlindvig/FSW_PSW.pdf
Old 03-06-2012, 03:00 PM   #5
cnsxskillz
My Ride: 05 325i
Ill test it out and see. And if the command isn't in NCS i cant just enter it in abd set it to aktiv? I just ordered the diagnostic cable so I havent tried it out yet. I just wanted to see if it was possible cause i know you can code it so it also closes the window.
Old 03-06-2012, 03:20 PM   #6
jeepo23
Yah I wouldnt add the command if its not there.
That command is under the GM5 module. Read your gm5 module and see if its in there and see what it's set to.
In that list of commands that command is there but the file is also from a e46 vert..
Old 03-06-2012, 04:18 PM   #7
cnsxskillz
My Ride: 05 325i
thanks alot man. ill be sure not to add it if its not there.
Old 03-06-2012, 04:24 PM   #8
Drewfus2101
My Ride: N/A
I was able to set it where the sunroof doesn't open using the key-fob.
Also set the key-fob closing at the same time.
Like they said, try it out and see what happens. NCSexpert reads/writes so fast that it won't take but a few minutes to find out if it works or not.
Drewfus2101 is offline   Reply With Quote
Old 03-06-2012, 04:34 PM   #9
cnsxskillz
My Ride: 05 325i
When you did the sunroof was the coding already in NCS and you set it to aktiv?
Old 12-19-2012, 02:08 PM   #10
bobdisk
My Ride: 323Ci coupe, E46
Mine will open both door windows (the rear vent opening is turned off) by the key-fobs remote, but I recently disconnected the battery for something else, and now the sunroof opens as well. It does this whenever the battery is disconnected, and after a week or so, the sunroof stops opening. I am sure I switched the control off without realising it, but dont know how. I want to find if there is a way of switching the sunroof control on or off (without having it re-coded). Anyone any ideas??
bobdisk is offline   Reply With Quote
coding, diagnostic, ncs expert, remote window, windows
