Sponsored by The Tire Rack
Old 03-06-2012, 10:27 PM   #1
Monte04ss
My Ride: 01 M3 Vert
proper fitment
hi gang, i am new the BMW world, just took delivery of a 2001 M3 vert this week.
I have done my research and have a question regarding fittment. I contemplating buying a used set of rims from this forum. But on the same hand, i am a little worried about used also.
Could you please review the fitment below and let me know what issues i could be running into. the offset seems wrong Vs the OEm specs.
thanks in advance for your input.
Corey
5x120
Fronts:
19x8.5
et15
235/35/19
Rears:
19x9.5
et22
275/30/19
Monte04ss is offline   Reply With Quote
Old 06-23-2015, 06:50 PM   #2
aris steez
My Ride: Z06
Those look like E90 specs - I'm curious if these will fit an E46 as well.
aris steez is offline   Reply With Quote
Old 06-25-2015, 07:24 PM   #3
indosoul
My Ride: 02 325ci Sport
Send a message via AIM to indosoul
Rears will fit no problems. Fronts will be a bit tight, but you're only doing 235/35 on the tire so you can make it work. Still may need a roll and some camber though. Low-mid 30s in the offset would be more ideal if you're looking to match the rears in aggressiveness.
indosoul is offline   Reply With Quote
