Old 03-07-2012, 04:31 PM   #1
ECSTuning
ECSTuning's Avatar
My Ride: BMW
:: ECS Tuning :: Automatic Transmission Service Video DIY
The automatic transmission on most BMWs is said to have lifetime fluid... we here at ECS as well as many transmission manufactures recommend service every 30k miles.
Over the life of a vehicle, the transmission can often be overlooked when performing routine maintenance. If left unserviced, the automatic transmission fluid will break down, causing the valve body and filter to become contaminated with deposits and sludge. This will lead to poor shifting, slipping, and ultimately transmission failure.
Below is a DIY video explaining the Automatic Transmission Service process
Embedded video:
Protect your transmission.
update:
Hey guys! We've put together a pdf to help anyone out who's looking to service their transmission. Now remember this is a write up for the E39 525i but the process is very similar on other cars, this makes for a great guide!
HERE is a link to the pdf
Old 03-07-2012, 04:42 PM   #2
My Ride: 2016 Lexus
Sounds good... can't wait to watch the video (even though I don't have an auto) I like the encouragement of fluid replacment. Full support here.
Old 03-07-2012, 07:51 PM   #3
Mr_325
My Ride: 2007 X5 3.0Si
nice.. is that a 5-series?
is the e46 auto tranny look the same from beneath?
Mr_325 is offline   Reply With Quote
Old 03-07-2012, 08:15 PM   #4
Bimmage01
My Ride: 330ci ZSP, Duramax
Yeah definitely an easy job on a lift. I want one
Khoalty AE's | Smoked Turns & Sides | Matte Black Grill | OEM LED Tails | TRS Xenon Retrofit | No Money For Anything Else | College Debt FTW
Bimmage01 is offline   Reply With Quote
Old 03-07-2012, 08:48 PM   #5
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
great video. thanks for the contribution
Old 03-07-2012, 09:18 PM   #6
Blocked Out
My Ride: Imola 330i M-Sport
The procedure would be identical for all automatic transmissions
Original BMW Teile ///
Original BMW Parts for Sale - DISA, MAF, SAP, Coils, MS43 much more PM ME
IMG_1725
Old 03-07-2012, 09:41 PM   #7
Killabeast
My Ride: 01 325ci
I bought my car at 100,000 miles on the clock and wanted to change the fluid. I bought the filter and gasket but then decided not to change it because I was hearing so many horror stories about killing trannys by changing the the fluid when it has never been changed. So now, at 145,000 miles, should I change it? or should I leave it alone?
Also,
Awesome vid!
Killabeast is offline   Reply With Quote
Old 03-08-2012, 03:06 AM   #8
My Ride: 2016 Lexus
Just watched it. Excellent vid. Auto transmission fluid should always be changed regularly no matter what.
Old 03-08-2012, 07:21 AM   #9
325i'02
My Ride: 2002 325i
Which vendor do you suggest for filter/gasket? Maistersatz shows everywhere at a good price.
M - One letter, one dream!
325i'02 is offline   Reply With Quote
Old 03-08-2012, 09:40 AM   #10
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Correct it is a E39, but the procedure is the same on other automatic transmissions.
bingo
I have kits available but I'd like to keep this to just a DIY and other helpful info thread
Old 03-08-2012, 09:45 AM   #11
Viktimize
My Ride: 2002 325i,2003 330ci
I'm guessing the OP recommends ECS tuning.
Viktimize is offline   Reply With Quote
Old 03-08-2012, 10:06 AM   #12
shanneba
My Ride: 2003 330Ci
I'll add a little info, make sure you check your production date. There is a difference in the 330 transmission filter and the fill and drain plugs, 02/2003 and earlier uses one filter, 03/2003 and later another.
The older transmission normally has a hex drain and fill plug, the new models have a torx.
ECS shows these differences in their kits, the new transmission uses a more expensive filter.
Join BMWCCA
Old 03-08-2012, 11:58 AM   #13
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
lol. did you watch it. that is the first thing he says that it is a 2001 5 series.
Thanks ECS! This video is awesome!
What is the average labor cost for this?
delmarco is offline   Reply With Quote
Old 03-08-2012, 12:13 PM   #14
325i'02
My Ride: 2002 325i
This should be about an hour worth of work ~ $70?
Old 03-08-2012, 12:18 PM   #15
Kris.R
My Ride: 2012 Dodge Charger
How many miles were on that E39?
- Kris -
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-Abraham Lincoln-
Kris.R is offline   Reply With Quote
Old 03-08-2012, 12:20 PM   #16
My Ride: 2016 Lexus
i would guess around $80. the fluid is WAY more expensive. (good OE/OE-spec fluid)
Old 03-08-2012, 12:27 PM   #17
delmarco
really!
like how much more? $200, $500?
So if I buy my fluid and take it with the car to a shop they would charge me around $80 - $100 average labor?
thanks.
Old 03-08-2012, 12:29 PM   #18
My Ride: 2016 Lexus
I would think so. I can't see them charging more than an hour. Yeah my friend took in his wife's 330i to a trusted indy of mine (he does my alignments and tire balancing) and i think he paid well over $300 for the service including filter. If i'm not mistaken, I think it was $380. i can ask again. he used a german fluid made by Titan which apparently is the same spec as OE
Old 03-08-2012, 12:30 PM   #19
delmarco
$300 for the fluid and filter?
Old 03-08-2012, 12:33 PM   #20
325i'02
My Ride: 2002 325i
Labour ~ $80. Good OEM fluid no less than $160, filter around $100. But it shouldnt take more than an hour. Hell, with a stand like that you can change all the liquids yourself, skip the labour rate and learn something new.
diy, fluid, service, transmission
