Old 03-07-2012, 05:02 PM   #1
Njerseydevil
My Ride: 2005 325i
Sputtering, just changed lower intake boot
Ok, I just replaced my lower intake boot this past Friday. I cleared the codes p0171 p0174 bank leans 1&2. Today my car sputters only when I turn it on then, i turn the switch and i have to hold back for like a second or two to turn on. If i turn right off and turn it back on it starts up perfect. when I drive around or I'm parked it doesn't sputter. But my idol sits a little under 1. My car sits at 106700miles. Could it be spark plugs, fuel filter maybe??
Njerseydevil is offline   Reply With Quote
Old 03-07-2012, 07:45 PM   #2
j_block
My Ride: 2003 325i
Is everything original on the car? Such as spark plugs, fuel filter etc...
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 03-07-2012, 07:53 PM   #3
Njerseydevil
My Ride: 2005 325i
I want to say yes because the dealer said that I'm over due on an inspection 2.
Old 03-07-2012, 07:57 PM   #4
Njerseydevil
My Ride: 2005 325i
And that was last friday
Old 03-07-2012, 08:41 PM   #5
j_block
My Ride: 2003 325i
See if you have same results after inspection 2
Old 03-07-2012, 09:50 PM   #6
LivesNearCostco
My Ride: 2003 ZHP 6MT
Is it possible you didn't set the lower intake boot fully seated everywhere? It has to connect without leaks to the throttle body, ICV, and the coupler ring that goes to the upper intake boot. If it wasn't fully seated in all 3 places, you could have a new vacuum leak. Then the upper intake boot has to be fully seated on the same coupler ring and the MAF, and the little F connector with its 2 small vacuum hoses has to be plugged into the upper intake boot.
Otherwise as mentioned could be plugs, fuel filter, fuel pump, dirty ICV, possibly dirty MAF.
Lowering my car's resale value one track day at a time...
LivesNearCostco is offline   Reply With Quote
Old 03-07-2012, 09:59 PM   #7
Njerseydevil
My Ride: 2005 325i
I will check on that again just to make sure. I'm positive that I did secure everything. SES has not come back. If the boots are fine, I will go and start with the spark plugs and so on. I checked the MAF and it is very cLean.
Old 03-07-2012, 09:59 PM   #8
Njerseydevil
My Ride: 2005 325i
Ok, I will post up my results. I'm going to start with spark plug.
Old 03-07-2012, 10:00 PM   #9
Njerseydevil
My Ride: 2005 325i
Btw, BMW dealer told me inspection 2 will cost $825.
Old 03-08-2012, 02:55 AM   #10
LivesNearCostco
Re-reading your original post, I don't think it's your spark plugs, though you should replace them at 100,000 miles (some people replace them every 60,000). If turning the key to position 2/ON and waiting a few seconds always lets you start up and run smoothly, I'm thinking it's a fuel pressure issue, which points to either fuel pump or fuel filter (which includes the Fuel Pressure Regulator).
Old 03-08-2012, 05:45 AM   #11
Njerseydevil
My Ride: 2005 325i
Sometimes if I give it second it won't sputter as soon as I turn it on. But I will be looking into the fuel pump/filter. Thks
Old 03-08-2012, 12:23 PM   #12
LivesNearCostco
My theory is your fuel pressure is not maintained when fuel pump is off. I don't know fuel injection systems very well but my guess would be a) leaky/clogged injectors or b) failing fuel pressure regulator (inside the fuel filter). I think the recommended replacement interval for filter/FPR is 60,000 miles. If you suspect injectors, the cheap solution is run a few bottles of Techron or other injector cleaner through the gas and the expensive solution is send your injectors out for cleaning or replace them. If you think it's filter/FPR, that's about a $55 part and can be DIY if you have four jack stands and don't mind spilling a little gas. Letting the fuel pump run for a few seconds (Key in position 2) before starting could be a short-term solution.
Old 03-08-2012, 01:55 PM   #13
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
First, go check your work on the boot. If it's your first time to do it, you may not have lined everything up correctly. Also make sure that you didn't crack any of the hoses (rubber or brittle plastic) running to the boot.
After that, do a tuneup. Fuel filter, air filter, and spark plugs are super easy to change. Buy some MAF cleaner and clean your... MAF. Consider changing your CCV if it's never been done. This will be the hardest item to tackle, but very DIY.
Best of luck.
Old 03-08-2012, 01:59 PM   #14
Dirty Mike
My Ride: Fern Green 330ci
You guys help alot thanks
Dirty Mike is offline   Reply With Quote
