Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 03-09-2012, 07:41 PM   #61
DaytonaM3
My Ride: M3 E36 turbo
Very nice numbers Andreas,now the snow is the only problem
Bullseye power S372 835Whp@23psi
DaytonaM3 is offline   Reply With Quote
Old 03-10-2012, 02:23 AM   #62
Bmwandreas
My Ride: BMW:s
I have printed the dynosheet but didn't have time to put it on the server. Will do that next week.
Have a nice weekend=)
Bmwandreas is offline   Reply With Quote
Old 03-10-2012, 03:02 AM   #63
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
You as well Andreas. Can't wait to see it!
Old 03-10-2012, 03:51 AM   #64
Bmwandreas
My Ride: BMW:s
One more thing. With the small 76mm turbo stock vanos was the best! But the large one gained a lot with the cams opened a bit more before 6000 rpm.
Old 03-10-2012, 04:00 AM   #65
nickr519
My Ride: ZX-10R, Ram 2500
Would you mind going into a little more detail? I've always been curious as to how vanos and boost interact and there's been a decent amount of opinions thrown around either way. Thanks!
'99 323i - totalled
'87 supra - sold
'90 300zx - sold
'01 GSX-R600 - sold
'97 Ram 2500
'06 ZX-10R
nickr519 is offline   Reply With Quote
Old 03-10-2012, 08:28 AM   #66
Bmwandreas
My Ride: BMW:s
Sorry for my bad english but the short version are:
If you advance intake and retard exhaust camshaft you are creating more low rpm torque. That also helps the turbo to spool sooner. I tune this in steady state mode every 500 rpm and looking for where the engine makes the most power, and looks at egt ,backpressure and knocksensor numbers.
Old 03-10-2012, 12:16 PM   #67
Jason@proefi
Past Site Sponsor
My Ride: 05 M3
Our data agrees!
Jason@proefi is offline   Reply With Quote
Old 03-10-2012, 01:19 PM   #68
Littleturbo
My Ride: Car
Did you use the Oem cams with the larger turbo ?
Littleturbo is offline   Reply With Quote
Old 03-10-2012, 01:34 PM   #69
Bmwandreas
My Ride: BMW:s
Yes stock cams. Would be fun to test a couple of turbocams
Old 03-10-2012, 01:44 PM   #70
Littleturbo
My Ride: Car
It sure would be fun to see the power gain and the difference between them,do you also use your pyramid ring headgasket on the S54 engine?
Old 03-10-2012, 01:52 PM   #71
m3micke
My Ride: e46 m3
Yes, we're going to try some real turbo cams with much higher lift!
Then I think we're going to recieve more power.
m3micke is offline   Reply With Quote
Old 03-10-2012, 02:23 PM   #72
Bmwandreas
My Ride: BMW:s
Stock gasket so far.
Old 03-10-2012, 03:12 PM   #73
Cipri
My Ride: E46 M3 2002
Stock headgasket for over 1000whp? o.O
Gj BMW!
Cipri is offline   Reply With Quote
Old 03-10-2012, 03:27 PM   #74
Bmwandreas
My Ride: BMW:s
Yes it's stock with L19 bolts.
Old 03-10-2012, 03:35 PM   #75
jacobs323i
My Ride: blown 323i
Originally Posted by Jason@proefi View Post
Attitude? Wise guy? Whatever...LOL
I can show you proof...why? Because I have done the testing to show it. Not only with BMW's but with SEVERAL other platforms.
It's really easy to make statements and not back them up with data, but that doesn't fly with me. You can get by with that with the people who don't do this stuff or do the testing to prove their statements, but not with me. My testing disagrees with yours. So, if you want to back up your statements, then post proof...I did, why shouldn't you have to?
I encourage EVERYONE to do the testing themselves...don't take my word for it either. You just have to know how to do the testing properly, you can't start upsetting the stock ecu by removing sensors and expect it to run the cams in an optimal position. The cams move based on volume of air. They use this to optimize airflow through the engine on power demand. They ALSO use cam movement to reduce power when things aren't what they want.
1040 hub hp....your making about 50 more hp with an 82mm turbo than I make on my car with an 67mm turbo. All I have to do to beat that number is push a button!
I and alot of other people in the know disagree that vanos control does not net you power or at the very very least torque!
jacobs323i is offline   Reply With Quote
Old 03-10-2012, 03:54 PM   #76
02PRUV
My Ride: E46 M3 Turbo
I was just wondering that now some of the euro guys are getting on the forum that now I can say to all the non believers I told you so about what they do in europe :p
I have tested vanos and no vanos. The difference at the same boost levels was 100hp, near on doubles the torque and brings boost in 1000rpm sooner.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 03-10-2012, 06:46 PM   #77
SPDu4ea
My Ride: .
Coming from supras Ive never played with vcam tuning so im curious -- have you found any need to vary vanos based on load? Or does one setting at a particular rpm work from cruise through wot?
SPDu4ea is offline   Reply With Quote
Old 03-10-2012, 06:57 PM   #78
Bmwandreas
My Ride: BMW:s
It's load dependent. If you make the cams aggressive under cruise it doesn't run smooth.
Old 03-10-2012, 08:21 PM   #79
Jason@proefi
Past Site Sponsor
My Ride: 05 M3
There are also fuel economy implications as well...when you advance the intake cam at lower engine speeds...you bring in more air requiring more fuel. So typically you keep the intake cam out until power demands the cam movement.
Old 03-10-2012, 08:53 PM   #80
Commanderwiggin
My Ride: 900rwhp Turbo M3
When you did this was the OEM ECU controlling the cams and was it throwing any codes?
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
