Thread Tools Search this Thread Rating: Thread Rating: 103 votes, 5.00 average. Display Modes
Old 10-30-2013, 06:53 PM   #141
SoloII///M
My Ride: Many
Originally Posted by TerraPhantm View Post
You are allowed to install equipment that was optional, aren't you? Not sure how that'd work with say.. a 3.38 or 3.64 diff (both of which were technically optional)
Neither of those ratios were optional on a manual-transmission 330i so they are not legal for a manual transmission 330i in STX.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 11-12-2013, 11:49 AM   #142
wanganstyle
My Ride: e36 M3 / E30 GTS1
Originally Posted by Vince_B View Post
@Wanganstyle, if you're still around I'd like to talk to you about an LSD for my ZHP. Although the OS Giken site lists a unit for the 330Ci, as you know the regular 330 has a 2.93 ratio, while the ZHP has a 3.07 ratio. I'm not sure I'm allowed to change the ratio in my SCCA Solo STX class.
for 188k units
2,65 / 2,79/ 2,93 / 3,07 use one offset of flange for the diff/ring gear relationship
3,15-4,10++ use a different offset of geometry. the measurement data is listed on Quaife and others websites
For solo rules one will not be able to legally change the final drive to a different one as there were no "options" for final drive ratios.
OS Giken does not make a LOW offset unit for 188K;
IF one was to fudge the truth a little......a 3,15 final drive would fit with OS giken directly into the 188k 330i case; and even I cant figure out the difference without unbolting the cover and checking the stamped ring gear code.
I'm not suggesting cheating or lying.....just suggesting being competitive
3,15 / 3,23 / 3,38 are all pretty common ratios for the 188K and very very close to the ZHP original 3,07.......
if you have a nationally campaigned car with good results OS even sponsors serious racers
Billet Original CNC LSD for 188K
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
Old 11-12-2013, 03:27 PM   #143
murph1379
My Ride: 2006 M3
I'm sure no company wants to sponsor cheating...
I may be looking to sell my Blanton-built 3.07 ZF LSD soon, need to send it to him to have a clunk checked out.
murph1379 is offline   Reply With Quote
Old 11-13-2013, 12:59 AM   #144
wanganstyle
E30/36 LSD into E46 Swap
If you are scared to compete in Motorsports then church may be a better location than the Scca solo event on Sundays.
If one wishes for faster times the ancient ZF would be replaced by a modern OS Giken. Doesn't matter who magically builds the ZF; I build them with unicorn special ramps here for each specific car/driver;
OS units product faster lap times from better engineering
Competition adapts to competition. If you are not cheating the rules in Motorsports you are not trying hard enough;
The Japanese tire companies are most famous for having "street rating tread wear" tires that look like the represented street tire at "180 wear" but seem to just have about the grip of a "60" tread wear dot R. I'm sure it's just a special spray or something.......not.
Somehow the top runner spec e30's and spec miatas always have quite a lot more acceleration although the dyno numbers are supposed to be within range. Have you ever listened to a spec race in person???
Spec cars have identical intakes and mufflers; but somehow the front runners engines produce significantly more volume from the spec muffler everyone runs. How does that work? Might someone or more than a third of the pack be cheating with a bigger built engine???
Old 11-13-2013, 08:47 AM   #145
murph1379
My Ride: 2006 M3
Wow dude, way to go off the rails...
Yes, an OS Giken should be faster, but given that everyone in grid knows it can't fit legally, showing up with OS Giken stickers and their name in your sponsor line is a great way to end up without valid times or a sponsor.
BS drivel from someone who clearly has never actually competed at a high level, especially in SCCA Solo!
I'm not interested in finding out who can cheat the best. I'm interested in finding out who can build and drive the best. Thankfully autocross is so heavily weighted toward driving skill that minor cheating like a 3.15 instead of a 3.07 is likely to be overshadowed by that chump's inability to turn a wheel competently.
Seriously, this isn't spec Miata, we're competing for $5 trophies, at the national level maybe they're $10 trophies.
I sit on the SCCA Street Touring Advisory Committee, and I'd suggest that maybe the local drag strip is a better place for you on a Sunday morning...
Old 11-13-2013, 12:33 PM   #146
wanganstyle
I race wheel to wheel; have you ever raced wheel to wheel with contact?
I find very few solo superstars dare to actually race. Even locals with solo national champ jackets don't handle 150++ cars wheel to wheel on a road course very well
Wheel to wheel Endurance racing is a much better use of time than Solo "racing"; solo is not racing.
I'll be at the road course where real motorsports happens. I only show up a few times a year to the local parking lot events for amusement and practice. You have obviously never watched a spec race in person if you don't believe in motorsports cheating - do you drive on road courses often?
Pay for the OS Giken out of pocket for solo then; and run it - you can obviously afford it. The sponsorship is only a 20% discount; if you can afford a Blanton unit you can afford an OS Giken - full price or 20% off.
Old 11-13-2013, 03:04 PM   #147
SoloII///M
My Ride: Many
This is a great thread, let's not turn it into a "my motorsport of choice is better than your motorsport of choice" please.
The Giken is a great diff once it's set up. Out of the box I'm not sure it's appreciably better than anything else out there. Some people have had pretty bad experiences with the out of the box setup (essentially getting a drift diff for a roadrace car... not good).
John V
Old 11-13-2013, 04:07 PM   #148
murph1379
My Ride: 2006 M3
I'll add that at least in my own opinion (and while I've competed nationally for a number of years, I have only a couple trophies and none at Nationals, so take my opinion for whatever it's worth) the less lockup the better for autocross. We make tight enough turns that a diff set for road racing might think it's seeing wheelspin, and then it's push city. (accel or decel)
Some people like that though, they'll set it up with virtually no lock under decel to get it to rotate, then lots of lock on acceleration so they can power out once the car is pointed in the right direction. My feeling is if I wanted to drive that way, I would buy a civic.
I want both ends of the car to turn a bit while braking, and to continue to rotate on both ends a bit as I add power out of the corner, without getting too crazy on either entry or exit. It took three iterations of my ramps and preload before I got it where I like it.
Old 11-14-2013, 10:30 AM   #149
wanganstyle
PRO Drift setting for an OS Giken would be a 2.0 way; none of the BMW units ship normally in 2.0 way; one would have to special order the ramps cut for you. Standard OS is 35/65 ramp angles (accel/deccel) for nominal 1.5 way action. Same for Kaaz; deactivating pairs of plates is common practice.
Any aftermarket many clutch + ASYM ramped diff has that issue; the OEM BMW unit is very mild and is a great setup for 1 size fits all; almost impossible to beat it out of the box for a BMW application. 25% locking 2 way equal ramps can rock it out on track, solo, etc.
AutoX is an extremely interesting diff setting that is unique to autoX; Nobody else really enjoys this diff setting. High lock accel and minimal lock deccel. If one desired to customize an OS the negative springs could be changed to very stiff and ramps ordered in 1.2 way (aggressive accel and almost open diff deccel).
Road race cars can run 1.5 AND OR 2 way settings depending on chassis setup / driver.
Old 09-07-2014, 12:32 PM   #150
M3J0N
My Ride: See Sig
Send a message via AIM to M3J0N
sorry to come in late, but I just saw waganstyle's link in his signature. Did any non-M e46s come from the factory with LSD that bolt into a touring? I was considering swapping in a m3 diff, but there is way too much work and parts required for that retrofit.
-M3J0N
98 M3/4/5Arctic/Dove (Sold)
99 M3/2/5 Titanium/Black (Sold)
04 M3/2/6 Carbon Black/Black (Sold)
95 M3/2/5 Carbon Black/Black (Sold)
95 M3/2/5Avus/Dove Grey 3.2L Swap (Current)
90 M3/2/5 Diamond Black/Black 3.0L Swap (Current)
96 M3/2/5Estoril Blue/Black (Current)
01 325iT Wagon Auto Titanium Silver/Red Sport (Current)
M3Forum Is a Joke (lifetime ban):
http://m3forum.net/m3forum/showthread.php?t=500115
M3J0N is offline   Reply With Quote
Old 09-07-2014, 01:10 PM   #151
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
There currently is a Group Buy going on with forum sponsor M-Factory. A helical lsd which is great for the street is $799. If you want M-Factory to professionally install it for you, just add $400, now you'll have a ready to use diff that has been setup properly.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 09-07-2014, 05:42 PM   #152
M3J0N
My Ride: See Sig
Good luck,
Rob43
thanks. so no e46 came with LSD from the factory?
-M3J0N
Old 09-07-2014, 05:47 PM   #153
Llink78
My Ride: 2002 330i
Nope
234HP/197TQ Just bolt ons :) New Numbers Coming Soon!
Llink78 is offline   Reply With Quote
Old 09-08-2014, 11:09 AM   #154
wanganstyle
only:
E46 M3
E46 M3 Cabrio
e46 non-M cars and E60/ E39 non-M and e90/92 non-M...... are all screwed.
No OEM LSD avail;
Old 08-31-2015, 02:12 AM   #155
Taper
My Ride: Espaņa
any update?
Taper is offline   Reply With Quote
Old 10-06-2015, 09:11 PM   #156
02m3blkblknavi!
My Ride: S/C-M5 S/C-Z3M M3-WB
Ok old thread but i have random question. I have a non-m e46 widebody im building. Have an s54 motor/trans full wiring harness ect. I also have a wrecked 98 z3-m for parts. The question is, can i use the diff, subframe, axles, ANYTHING from the z3m or do i just need to go ahead and buy a rear drop out from an e46 m3? Thanks!!
02m3blkblknavi! is offline   Reply With Quote
Old 10-09-2015, 09:27 AM   #157
SoloII///M
My Ride: Many
None of the Z3 stuff will be of use to you.
John V
Old 01-01-2016, 06:13 PM   #158
Taper
My Ride: Espaņa
After few years you got the solution to fit the e36 lsd into e46 diff case?
Old 01-06-2016, 11:15 PM   #159
Gerry O Neill
Does this work is it much work?
Gerry O Neill is offline   Reply With Quote
e36, lsd
