E46 Xi Forum
Old 03-10-2012, 05:34 PM   #1
tl227
My Ride: -
Front End Noise/Vibration
I just replaced my front axles and left front wheel bearing. I had vibrations while under acceleration on highway as well as what i assumed was similar to the beginnings of "clicking" while turning. The noise is similar to something vibrating but I don't feel it as if it were an seriously unbalanced tired or something along those lines. Just the noise mostly. Speed/acceleration does not seem to effect it but it does seem to need to hit a certain "spot" to start happening. Occurs while straight or turning. Also it seems to happen when its relatively cool/ in the morning when first go out.
Any ideas? Sway bar bushings?
tl227 is offline   Reply With Quote
Old 03-14-2012, 01:08 PM   #2
pjo33us
My Ride: 03 330xi
Could be anything... Maybe a sticky caliper?
pjo33us is offline   Reply With Quote
Old 03-14-2012, 02:29 PM   #3
SamDoe1
My Ride: 4cyl of fury
What's the certain spot?
Old 03-14-2012, 02:41 PM   #4
mxchris727
My Ride: E39, E93 335
Send a message via ICQ to mxchris727 Send a message via AIM to mxchris727 Send a message via MSN to mxchris727
Front control arm bushings. Check them by trying to move the wheel at the 3 and 9 o'clock positions. Any movement of the control arm in the bushing means they are bad. Also, check for a sticky caliper by driving without using the brakes and feel the temperature of the wheel. If one is hotter than the others, you have a sticky caliper.
-Chris
I have a computer set up with DIS, TIS, SSS Progman, INPA, NCS Expert, WinKFP, and Tool32 with an EDIABAS interface; PM me if you want to stop by and code your car.
ISTA/P & /D is up and running!
mxchris727 is offline   Reply With Quote
