Old 03-10-2012, 09:33 PM   #1
thecarguy
My Ride: ZHP Sedan
Ticking from engine after 8th run at autocross last weekend??
So I did my first autocross in my 04 zhp 330i last weekend. In my run group I was able to get 9 runs in and the last two runs when I came in the engine had a very loud ticking. Almost sounds like noisy lifters from a pushrod V8. Drove it home and the sound was gone. Has not repeated this since. Is this just a trait of this motor? What could it have been??
Obviously the engine didn't like something about pushing at the autocross, but then decided all is ok after some normal driving. Very odd. Makes me question the durability of the motor.
thecarguy is offline   Reply With Quote
Old 03-10-2012, 10:15 PM   #2
darksideracer69
My Ride: 01 325ci
Vanos? Maybe got the oil a little to hot? Idk something like that.
Sent from my SGH-T959V using Bimmer App
IMAG02051
Old 03-10-2012, 10:19 PM   #3
mvrk10256
My Ride: E30 325i
When the M5x get hot they tick. Happened to me every autoX on the e46. Totally normal, let it cool a bit before driving home.
Old 03-10-2012, 10:27 PM   #4
thecarguy
My Ride: ZHP Sedan
Thank you, this is what I was hoping to hear. I feel much better now knowing it's normal under those conditions.
Old 03-11-2012, 12:13 AM   #5
Steven747
My Ride: 05 330ci
Super normal it happens after every canyon run for the past year
Old 03-11-2012, 11:12 AM   #6
thecarguy
My Ride: ZHP Sedan
Unfortunate it is part of the car, but great to hear nothing is wrong!
Old 03-11-2012, 11:23 AM   #7
Scooby24
My Ride: '03 330i ZHP Sedan
what weight oil are you using? Sounds to me like you should be using something thicker.
Scooby24 is offline   Reply With Quote
Old 03-11-2012, 11:34 AM   #8
ccodybrown
My Ride: '03 330i ZHP sedan
Had the same thing happen to me. I believe the oil pump briefly starved during cornering after my 4th run. My oil level was fine but I topped it off to the 'max' on the dipstick & let the engine idle & cool after each run. Hasn't happened since. I might add some additional baffling in the pan one day.
ccodybrown is offline   Reply With Quote
Old 03-11-2012, 10:03 PM   #9
thecarguy
My Ride: ZHP Sedan
Mobile 1 0w40 - what is recommended by most.
I added about an 1/8 of a quart before I left for the autocross to get the oil to the middle of the has marks. Maybe next time I will put it to the top of the hash marks or at least look into it.
Old 03-12-2012, 02:28 AM   #10
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
its the hydraulic lifters. overfill by a bit and it will stop.
SL Blak Soldier is offline   Reply With Quote
Old 03-12-2012, 10:18 PM   #11
thecarguy
My Ride: ZHP Sedan
Would that be to the top of the has marks? I don't want to have too much and run into other problems from overfill.
Old 03-13-2012, 08:50 PM   #12
F1004fun
My Ride: '02 330Ci
I have run into this before with the M5x engines and yes it is from the lifters, but I have found it to be from whipping up the oil in high speed turns. I would look into a crankshaft scraper and possibly a better oil pan baffle. VAC sells the baffles and crank-scrapers.com sells the scrapers.
F1004fun is offline   Reply With Quote
Old 03-13-2012, 09:29 PM   #13
thecarguy
My Ride: ZHP Sedan
Good to know, I'll look into this for sure.
Old 03-13-2012, 09:36 PM   #14
JohnBlaze
My Ride: Black Sunshine
I used to run an extra .5+ quart of oil and it always worked for me to eliminate the tick. If you run a low tank of gas, get the M3 fuel pump baffle to reduce the fuel sloshing problems.
JohnBlaze is offline   Reply With Quote
Old 03-13-2012, 11:06 PM   #15
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
I followed the build on Vorshlag's website of their trials in autoxing a 330Ci and they mentioned they would also add an extra .5 to 1 whole quart over the full line, and I believe they ran 20w50 which is thicker to quiet those ticks. But after going thru a few oil pumps and motors, they called it quits.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 03-16-2012, 09:01 PM   #16
thecarguy
My Ride: ZHP Sedan
Did they contribute blowing through the oil pumps and motors on the heavier weight or overfilling by a quart, OR a combo of both?
Old 03-16-2012, 09:03 PM   #17
Gheybe
Gheybe's Avatar
My Ride: F80 M3
Happened to me at the track. I've been told a few times it's because it got a bit hot.
Gheybe is offline   Reply With Quote
Old 03-17-2012, 01:53 AM   #18
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Neither.
SUMMIT POINT WV 1:24:229 SCCA
Old 03-17-2012, 09:30 AM   #19
TerraPhantm
My Ride: M3 & ZHP
Might be worth trying castrol 0w-30 or even BMW's 5w-30. Mobil1's 0w-40 tends to sheer down to a 30 weight pretty quickly, so it actually ends up being thinner than most other 30 weights. I know Castrol's is pretty stable. I'm sure there are other good oils from total or lubromoly... But I'm not very familiar with their product lines.
You absolutely should fill to the top of the line. For auto-x, it's sometimes beneficial to go a little above
Old 03-18-2012, 01:49 AM   #20
thecarguy
My Ride: ZHP Sedan
Is top of the line considered ok all the time...for every day driving?
